And here she is mounted back on the axle:And regarding the shaft getting damaged, nope, nothing. It didn't leave any mark or any kind. Plus, the washer and bump stop are in that area, so really, even if I had damaged it, I bet it would still be very much usable. But the press trick is perfect and does not damage a Bilstein shock shaft
those look like ford body mount bushings
I was going to say something else about what I did on the 22nd, but my memory just threw a rod. I'll swing back later if I remember what it was
It's about damn time you got your arse in gear on your truck there Mike! Hey, what's it say on your front fender in PINK?
A couple days prior to that night, I was moving my my driver's seat forward to get some stuff out from behind it, when something under the seat was preventing it's movement. I was in a hurry and also not thinking and I pulled the seat reallllly hard and something just gave away and broke.I ended up crushing my front e-locker control circuit. I was really pissed because it was a prototype I've been working on that I had never mounted or had even finished for that matter. And now I broke the only part I had, and the Tin Bender's Jamboree Hammers trip was right around the corner!I knew I needed a front locker for the hammers, so I forced myself to spend a very tedious hour and got the circuit fixed.I don't have any pictures of the repair or the circuit, but here is the control module that does all the E-Locker work for me Thanks little guy, at least now I won't go around breaking ya any more And that is it from April 22. Yup, that was a loooooong night for sure Definitely well worth it
These are some links from Marlin's electric locker page!http://www.4x4wire.com/toyota/tech/electric_locker/http://67.122.16.97/carterman/4runner/mods/locker/
Moose Lover!! Your a funny guy Mike!
Thanks for posting the links, but I am not using any of the wiring harness diagrams on the net. I am using a system that only requires 1 signal wire to operate the entire circuit.
...why buy when you can build?
Update??
These are some links from Marlin's electric locker page!http://www.4x4wire.com/toyota/tech/electric_locker/http://67.122.16.97/carterman/4runner/mods/locker/Moose Lover!! Your a funny guy Mike!
at least its not "moose knuckle lover"
Mike, just get to the front end please.
Started by HFCRAOffroading « 1 2 » Project Research and Build-Ups
Started by 88Rokyoat « 1 2 3 » Project Research and Build-Ups
Started by AaronB « 1 2 ... 7 8 » Project Research and Build-Ups
Started by Rainer « 1 2 ... 6 7 » Project Research and Build-Ups
Started by SKULLYOTA Transfer Case/Drive Line
