Author Topic: auto trans adapter  (Read 3809 times)
thetrekkerguy
  • Turtle Points: 7
  • Male Posts: 23
  • Member since May '08
auto trans adapter
« on: May 08, 2008, 11:17:48 AM »
Does anybody know of an adapter to use the auto trans in my 85 4Runner with a gear drive case this is my new project truck time to retire my my trekker the fiberglass is starting to show some serious wear so it will be only used for lite trail duty from know on but if anybody has any ideas on the adapter thanks :turtle3:
« Last Edit: May 08, 2008, 11:26:18 AM by thetrekkerguy »
TOYOTA:BECAUSE I UNDERSTAND THAT JEEP THING
1982 TREKKER 5 INCH LIFT 4:88'S 22RE HALF DOORS CUSTOM SOFT TOP
1985 4RUNNER 5 INCH LIFT 4:88'S SPOOLS FRONT AND REAR KC HID 8 INCH LIGHTS 5;29'S ON WAY AND AUTO TO GEAR DRIVE ADAPTER
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: autp trans adapter
« Reply #1 on: May 08, 2008, 11:24:32 AM »
for that auto,  the Inchworm  adapter is your only choice
thetrekkerguy [OP]
  • Turtle Points: 7
  • Male Posts: 23
Re: auto trans adapter
« Reply #2 on: May 08, 2008, 11:30:10 AM »
how strong are the auto trannys will it handle some mild offroad use with my 35's
lucky7
  • Turtle Points: 303
  • Male Posts: 778
  • Member since Sep '07
  • CAN'T POLISH A TURD!
« Reply #3 on: May 08, 2008, 11:30:32 AM »
Talk to marlin if you can that tranny is a little different than most. :shocking: :turtle:
lucky7
  • Male Posts: 778
« Reply #4 on: May 08, 2008, 11:33:05 AM »
Or you can do what i did and go with 4-7 gears mine works great :thumbs:
« Reply #5 on: May 08, 2008, 11:38:09 AM »
yes,  with mild use  it will be fine with alot of rock crawling  it will give up on ya
i have a good friend with a 4runner  that  does  quite well offroad with 33's
he  does   have problems  on  45 degree or more hills
thetrekkerguy [OP]
  • Turtle Points: 7
  • Male Posts: 23
« Reply #6 on: May 08, 2008, 11:48:26 AM »
is the problem with angles because lack of fliud in the tranny
thetrekkerguy [OP]
  • Turtle Points: 7
  • Male Posts: 23
« Reply #7 on: May 08, 2008, 11:50:54 AM »
trying to get it ready for its first trip out since i got it last weekend just had concerns about the auto tranny and the crawl ratio will be alot diffrent then my trekker for sure
lucky7
  • Male Posts: 778
« Reply #8 on: May 08, 2008, 12:04:24 PM »
Only if you're t-case and tranny share fluid good chance your's does'nt
thetrekkerguy [OP]
  • Turtle Points: 7
  • Male Posts: 23
« Reply #9 on: May 08, 2008, 12:40:28 PM »
does your second gen have an auto trans are you using an adapter to gear drive case or do you still have the chaincase in it
lucky7
  • Male Posts: 778
« Reply #10 on: May 08, 2008, 01:02:22 PM »
Mines out of a 95 t-100 truck wich took a 3.0 adapter to go with a geared t-case your t-case may be a geared you need to look and see if it is divorved or combined. If you call marlins and he's there he can probably answer that for you i've seen them botth ways :thumbs:
thetrekkerguy [OP]
  • Turtle Points: 7
  • Male Posts: 23
« Reply #11 on: May 08, 2008, 01:06:26 PM »
mine is a chaincase for sure it has the little tranny type pan on it i have an toyota trekker with dual gear cases in it
« Reply #12 on: May 08, 2008, 02:45:00 PM »
85 4runner auto,
YES  it has  the combined unit, aka  tcase and tranny share atf
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
  • Member since Sep '06
  • out from under my rock, and ready to roll
« Reply #13 on: May 08, 2008, 08:48:53 PM »
There are ways to make that adapter work without loosing fluid on severe angles. My frien mike runs that setup with AA5to1 in the rear case and stock ratio in the front, on 40s. Once you work out all the bugs that inchworm didnt account for its an awesome setup.
Alot of people diss the early autos but with gear drive cases all the downfalls are removed, along with the chain case, and extra clutches in the tcase.
My friend and I built a thin plate that bolts between the transmission, and the origonal reduction housing of the old tcase which is retained when using the inchworm adapter. He would have to sit on an extreme angle for a long amount of time in order to starve the transmission of fluid. He does still over fill the transmission, but only by a quart or so. Its my thought that that extra quart is constantly filling the otherwise empty space caused by removing the guts from the reduction part of the origonal t case.
I belive skyway makes an adapter that also works with the early autos. I used to have a crawl mag that listed tcase adapters. It had a link to a website for skyway, but now I cant find it or a link. I do know there is another adapter avaliable though.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
« Reply #14 on: May 08, 2008, 10:29:35 PM »
Skyway Transmission makes the gearslug.  Don't know anything about it though.
http://www.gearslug.com/
Quote
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #15 on: May 08, 2008, 10:40:31 PM »
Marlin wouldn't copy it because he has ethics and morals.... i wouldn't be too sure about a certain competitive company though....
thetrekkerguy [OP]
  • Turtle Points: 7
  • Male Posts: 23
« Reply #16 on: May 09, 2008, 06:17:27 AM »
Thanks for all the help now when I do that I'm going to swap out my gears for 5:29's because i smoke my precision gear 4:88 rear pinion over the weekend just found that last night any suggestions on gear brands I don't want to buy them a third time
Last post Nov 01, 2003, 10:07:37 PM
by toyotaboy
Last post Apr 18, 2008, 09:35:28 PM
by paulybee
Last post Dec 31, 2011, 06:38:21 PM
by 4.3 headache
Last post May 15, 2013, 09:33:32 AM
by 4corredor
Last post May 27, 2018, 03:11:10 PM
by 300k
