just be sure to push the axle as far forward as ou can to keep your tires off the firewall when flexed out lookin good so far
i was thinking about welding another box steel in between the frame and front spring hangers good or bad?
you mean like a "drop" style hangar? cool screen name btw
yeah just give it a little more lift with that.and thanks.
depends...are you building a mud truck or a rock crawler? Personally, I would keep it as low as possible
... the only thing U need lift for is to clear tires
looks good also like the fj40 next to it off topic are you going to build that cruiser
reading your first post was hilarious. here is my build up. you might want to check it out since your starting out EXACTLY how i did. ive changed up a lot of things since 3 years ago but here you go. http://board.marlincrawler.com/index.php?topic=15616.0as far as the 3" block on the back with the 63s, yes it should sit dead level, mine did. i used the double shackle setup forever, toy shackle and chevy shackle, and yes i also ran the 4" marlin springs up front for 3 solid years till a few months ago. now its toy rears mixed in with them. i also started out with 35 BFG muds then got some 37 mtrs next. just read through my thread our trucks are very similar. cya edit: dont add some box tubing to lower the hanger, youll regret it. you already have a 2" BL. just weld the hanger on and use the shackles they give you. your truck will be as tall as a sky scraper, it will suck. \
your truck is nice.i like the bob on it.i also saw how you made your own felt knuckle seals. i wish i would have thought of that before i dropped $50
thanks. hey it also looks like your PS pump is pretty blown and in need of a rebuild. i just did mine and its on my thread if you need want to do it yourself.
...why buy when you can build?
Off Topic: The FJ40 in the last pic belongs to yours truly. Parked there at his house cause he has the tools. I'm thinkin' about doin' a build thread on it as well.
BOB!!!!!! what up its KC, I'll be over tomorrow to cut that off then its grindin time for you guys! Have you seen my build up thread?If not check it out http://board.marlincrawler.com/index.php?topic=43389.0
looks like a good truck.... i would ditch the rear blocks... blocks suck.....does that happen to be a harbor fright floor jack with an adjustable screw up/down saddle? and how does it work? i am in the market for a floor jack
as for the blocks, i hear they are good to use if you run the 63's because how you have the front spring hanger on the low part of the frame it gets it up more to aviod hitting it on rocks. im not sure though?
sounds good man. ive gotten everything off excet the pitman armyeah i was looking ive been looking at yours for a while.how much was your hydro assist ram?and kev is wampum
Whens kev gonna start on the cruiser?
Started by wsuweston Rigs For Sale
Started by 51504ROCK Parts For Sale
Started by weirdtimes_7 Rigs For Sale
Started by AreYouSure Rigs For Sale
Started by 874runnertoys Parts For Sale
