Author Topic: BigMike's Big Project  (Read 713045 times)
  • Administrator
  • Turtle Points: 2124
  • Male Posts: 18,289
  • Member since Apr '02
  • 511:1 Club
« on: Jul 04, 2004, 08:35:48 PM »
This Project is featured in our Official 3RZ Knowledge and Database Thread
BigMike's Build Navigation
Pages        Active Date Range
FirstBigMike's Big Project  (currently viewing)    38+July 2004 - April 2005
Second     BigMike's Big Summer Project19+May 2005 - Sept 2007
ThirdBigMike's "Return of the Project"12+May 2008+
Picture Gallery Thread
~ Misc. Trail Gallery -- Click each image for larger view ~
Project Thread Navigation Links:
Page 2 - Checking out the truck
Page 3 - Pulled 22R Engine
Page 5 - Cleaned and Painted Engine Bay
Page 6 - First 3RZ Test fit and Built Engine Mounts
Page 7 - First pictures of Wiring
Page 8 - Pulled 3RZ back out to finish Mounts and Engine bay. Pulled all wires into cab
Page 9 - Connected Clutch Slave, Installed Turbo Radiator, 22R vs 3RZ Clutch Fans
Page 10 - Mounted Gas Tank, Ran Fuel Lines, Starter Contacts, Painted Hood,
Page 11 - Built 1" Chassis Lowering Kit, Mounted P/S Cooler, Talked about Water/Alcohol Injection
Page 13 - Built Exhaust, Wired in O2 sensors, Mounted Optima Battery, Wired in main Hot and Grounds, First time Cranked!!
Page 14 - Tested Fuel Pump, GOT THE TRUCK RUNNING!! First Video of 3RZ Running, Cleaned AFM, Talked about Front Diff Clearance.
Page 15 - Talked about Smog Checks
Page 16 - First Test Drive!!, Battling a Power Problem
Page 17 - Found out the engine had no Thermostat, Talked about Cracked AFM, First good picture of Engine Bay, Mounted Air Filter and Air Temp Sensor
Page 18 - Mounted Engine Bay Fuse Box, Explained my EFI Fuel Tank mounts and line routing, Talked about TRD SC
Page 19 - Installed a New AFM, Worked on Wiring, More Engine Bay Pics, Started Wiring Interior Circuits, got OBD-II-to-Computer Interface, Drove her home for the first time!
Page 20 - OBD-II discussion continues, got a ton of little things done
Page 21 - MC shackles, installed 30" tires, wheel spacer, Denso Iridum plugs, Electric Fan, Misc pics
Page 23 - Nology Hotcore Spark Plug Wires, Got some used 33" tires
Page 24 - First pics of the truck on dirt, acquired my RV2 Compressor
Page 25 - Talked with a Smog Referee, had to reschedule appointment
Page 26 - Passed Smog Referee Inspection on first attempt!!
Page 27 - Preparing for and installed Triple Marlin Crawler Transfer Cases, IFS rear axle, 5.29s + E-Locker, 12" Bilstein shocks, U-Bolt flip, brake lines, FROR Cross Member, front drive line
Page 28 - First time testing out 4WD, installed front Lock Right locker
Page 29 - Installed used 35" MTRs
Page 31 - Good info from toyhatsu's 3RZ Conversion
Page 32 - Repositioned Radiator forward, Rock Lights, Longer rear shackles
Page 33 - Installed Marlink
Page 34 - New rear lower shock mount design, Engine bay pics, Discussed plans for my Next Build Thread
Page 35 - Discussed a rear center heavy load spring
Build progress in this thread is now finished. Please see my 2nd Project Thread for my project's continuation: BigMike's Big Summer Project
Well, after wheeling with my old man since he bought his truck in the fall of 83', I've finally acquired my very first truck, a stock 1981 Toyota shortbed pickup  :greengrin: :biggthumpup: :best:
« Last Edit: Feb 16, 2022, 03:59:23 PM by BigMike »
BigMike [OP]
  • Administrator
  • 511:1 Club
Re: BigMike's Big Project
« Reply #1 on: Jul 04, 2004, 08:36:47 PM »
The story on this truck is pretty interesting.
About 3 years ago this kid brought the truck in for some work, and even after giving the permission for the work that Marlin did to it, the kid could not afford to pay the bill and just abandoned the truck. Pretty crazy, but now its mine!
It definitely needs a good deal of TLC. It was last registered in 1999 so the DMV is gonna chew me up :wall:
« Last Edit: Jul 04, 2004, 09:00:11 PM by BigMike »
BigMike [OP]
  • Administrator
  • 511:1 Club
« Reply #2 on: Jul 04, 2004, 08:37:52 PM »
The tach says 62k and Im wondering how many times that's gone over and over.... :dunno:
The engine has been replaced and the guys got it running a couple of months ago, but I've personally never tried to start it. I dont care about this engine  :psss:
« Last Edit: Jul 04, 2004, 08:41:47 PM by BigMike »
BigMike [OP]
  • Administrator
  • 511:1 Club
« Reply #3 on: Jul 04, 2004, 08:38:24 PM »
The coolest thing about this truck, is it's a SR5 with a factory sunroof! I've heard about these but I've never seen one, and here all along Marlin had this truck just waiting for someone to build it.. :clap:
Pretty sweet!
Also, the shop was in the middle of installing this W56 the kid brought in, so it's pretty much prepared for what Im about to do to it  :psss:
« Last Edit: Jul 04, 2004, 09:02:50 PM by BigMike »
BigMike [OP]
  • Administrator
  • 511:1 Club
« Reply #4 on: Jul 04, 2004, 08:45:44 PM »
:psss: And here's the bread and butter of this project!!
Just picked up today!
:bowdown: :bowdown: :bowdown: :best:
« Last Edit: Jul 04, 2004, 09:05:22 PM by BigMike »
BigMike [OP]
  • Administrator
  • 511:1 Club
« Reply #5 on: Jul 04, 2004, 08:48:31 PM »
Yes folks, that is a 3RZ-FE in my rear view as I trek across the fierce Mojave Desert in scorching tripple digit heat (in a V8 Tundra with A/C :yupyup: ). And I've got it all. ECU (coming in the mail), Harness, fuse boxes, relays, air flow meter, o2, yadda yadda yadda
I'll be pulling the 22R + W56 out and giving them to Marlin, after which I will spend a long time getting the wiring figured out and will build a W56-HD using a W59 bellhousing. :best:
Along with the 2WD 95' T100 engine, I will be converting the interior to a 3rd gen (1989-1995) interior courtesy of WHITE_TRASH. So I'm envisioning a 1981 bobbed shortbed Hilux, 1995 3RZ-FE 150hp/177tq engine, 90-series interior, 35" tires (I don't have enough $ for 37s yet), trying to keep it as low as possible with about 3" or 4" lift, Toyota e-lockers front and rear, and of course a Marlin Crawler Ultimate.
My goal is to have all this done by Thanksgiving so I can play with Brandon on the 'Day after Thanksgiving Run'
Stay tuned for many pictures and updates!!
:biggthumpup: :thumbs: :thumbsup: :disturbed:
« Last Edit: Jul 04, 2004, 09:11:25 PM by BigMike »
SWAMPER
  • Turtle Points: 790
  • Male Posts: 3,599
  • Member since May '04
  • Semper Fi
« Reply #6 on: Jul 04, 2004, 09:09:19 PM »
You b*std, youve gone and done it  :thumbs: Good job and good luck Mikey :thumbsup: and post a bunch of pics and stuff for lil o Swamper to see  :biggthumpup:
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
« Reply #7 on: Jul 04, 2004, 09:22:33 PM »
Wow I cant believe thats your first truck, I'd have figured you to have plenty of "projects" with where you work and all. Keep us posted. BTW theres a guy in Fresno that has a shop that does some pretty amazing stuff with Toyota trannys and t-cases, you might look him up :joke:
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
« Reply #8 on: Jul 04, 2004, 10:10:48 PM »
WAY TO GO MIKEY, looking forward to see all the juicey details on the eng. swap! I had some ideas about trying it last year when I had to do "something" about my eng just before vacation. butt felt the with the trip coming up in three weeks it just was not the time for it  :-\\  hope it goes well for ya, we'll all be watching over your sholder! oh and take LOTS of pics.!  :beerchug:
  • Turtle Points: 679
  • Member since Feb '03
  • Don't blame me, I didn't vote for this crap.
« Reply #9 on: Jul 05, 2004, 01:14:42 AM »
Hmmm tell ya what you give me the truck and all the parts, in 3 months you can come pick up one sick wheeler!  Betcha I could do that one for about $500 total :yupyup:
Skinny_Pedal
  • Turtle Points: 89
  • Male Posts: 2,833
  • Member since Apr '04
  • work so I can support my lifestyle
« Reply #10 on: Jul 05, 2004, 01:51:32 AM »
wow can't believe this truck actually exists. sounds like its gonna be a sweet machine
Im an OG
kyle_22r
  • Turtle Points: 530
  • Male Posts: 1,233
  • Member since Dec '03
  • yellow beast
« Reply #11 on: Jul 05, 2004, 02:10:42 AM »
that's gonna be pretty bad ass :beerchug:  i wouldn't mind the 90s interior...but i like the 1st gen dash better than any of the others!  the '84-88 ones are really sterile looking and the 90s ones are kinda too modern for me
i can't wait to see how that 3RZ swap turns out :bowdown:
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
« Reply #12 on: Jul 05, 2004, 07:08:34 AM »
                                  :idea: hummmmm (me thinking that mikey sould take WT up on he's ofer, just
                                                              put $500 in the bed and ship it to wash)
         NAHHHHHHHH   what was I thinking!  :hammer:
SWAMPER
  • Male Posts: 3,599
  • Semper Fi
« Reply #13 on: Jul 05, 2004, 07:12:35 AM »
 :laugh: :laugh: Hey for 500 bucks I would take my truck to WT.....after hes done with it Swamper would proly not be pretty but for 500 bucks who cares  :greengrin:
BigMike [OP]
  • Administrator
  • 511:1 Club
« Reply #14 on: Jul 05, 2004, 07:54:55 AM »
But then I would miss out on all the fun!
lowgeared
  • Turtle Points: -1
  • Male Posts: 556
  • Member since Oct '03
« Reply #15 on: Jul 05, 2004, 08:09:47 AM »
I'm not real knowledgable on this-is that a Supra engine?  Are they a direct bolt in or something??  I have sure seen a lot of these in trucks on the net.  What is it? A v-6, straight six, four??
SWAMPER
  • Male Posts: 3,599
  • Semper Fi
« Reply #16 on: Jul 05, 2004, 08:14:53 AM »
I....dang I was thinking of a different thing sorry I dont know for sure  :dunno:
88runner
  • Turtle Points: 756
  • Member since May '03
  • Click me!
« Reply #17 on: Jul 05, 2004, 08:22:36 AM »
 :biggthumpup: congradulation BigMike, the body look straight and don't seem's to have rust it's a real good start. :thumbsup:
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
kyle_22r
  • Male Posts: 1,233
  • yellow beast
« Reply #18 on: Jul 05, 2004, 09:30:31 AM »
it's a 95.5-up t100 and tacoma engine, 2.7l 4 banger.  good for about 150hp stock :bowdown:
BR
  • Turtle Points: 20
  • Male Posts: 22
  • Member since Mar '03
  • Diesel is the thing
« Reply #19 on: Jul 05, 2004, 09:40:34 AM »
Nice truck Mike. My first truck was a `79 RN36 with a 20r eng. I worked the springs a litle put on 33"ers, and had a lot of fun in it, belive yours will be a killer. Mine ended up being a convertible after a holiday roll-over and it even had a homebuilt stepside bed, looked pretty ugly in fact. But it did do the job as daily driver and weekend toy. Congrat`s with your projekt :thumbs:
1990 hilux 4door dobb.cab.;rear leaves up front;HP 4.88`s; rear airlocker; inside cage; 35" bfg mt/36"tsl`s ; Marlin 4.7 # 1321
lowgeared
  • Turtle Points: -1
  • Male Posts: 556
« Reply #20 on: Jul 05, 2004, 09:42:03 AM »
Sounds like it should be a fun project.
FIREBALL
  • Turtle Points: 190
  • Hi Ho Marlin....u talkin to me
« Reply #21 on: Jul 05, 2004, 11:44:28 AM »
Right on Mike! Looks like a great truck to start with. Can't wait to see it on the road. I might be coming down for a visit soon, i'll let you know. If I can help with anything let me know.
BigMike [OP]
  • Administrator
  • 511:1 Club
« Reply #22 on: Jul 05, 2004, 12:50:54 PM »
Hey FIREBALL,
Since I know your good with molds and fiberglass, wanna help me make a hood? I want to buld a hood with a reverse scoop towards the passenger's side to allow air to escape from under the hood right at the windshield, can you picture what I wanna do? Instead of using a standard scoop that forces air inside, I want to have some sort of air directors near the exhaust header (after I get it pased the smog ref, I plan to get a header and modify it to clear the front driveline) and convince/encourage the air to exit via an inverted scoop above the rear of the engine on the passengers side of the hood... Have you done anything larger then that air scoop you made on your old 2?
BigMike [OP]
  • Administrator
  • 511:1 Club
« Reply #23 on: Jul 05, 2004, 12:53:01 PM »
Also, does any1 have any pictures of their engine bay after removing the inner fender walls? I want to do this for increased cooling, and 2 things, 1, I have not looked at the inner fenders yet, and 2 I've never seen up close in detail what needs to be done to remove them. How much does this weaken the cab and do you ever use some braces to help support it?
So if someone could post some pics of removed engine bay inner fender walls, let's see em! :scared:
SWAMPER
  • Male Posts: 3,599
  • Semper Fi
« Reply #24 on: Jul 05, 2004, 12:56:51 PM »
Why dont you make a hood with 3 scoopes 1 in the middle forcing air in and the other 2 by the exhaust headers to release hot air...thats what Ive been wanting to do but dont know anyone who makes fiberglass hoods  :rivers:
BigMike [OP]
  • Administrator
  • 511:1 Club
« Reply #25 on: Jul 05, 2004, 01:04:36 PM »
I dont want to look like its all :bling: but thanks for the suggestion. It would actually be only 2 in my situation since its an inline 4-cylinder, I only have one exhaust manifold.
Im going back to work, lunch break's over- will check back in later tonight
SWAMPER
  • Male Posts: 3,599
  • Semper Fi
« Reply #26 on: Jul 05, 2004, 01:07:57 PM »
Well I dont really care if it looks :bling: As long as it does it work and beside I think it would look cool  :dunno:
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
« Reply #27 on: Jul 05, 2004, 01:49:08 PM »
well do keep in mind that if the "scoop" is close to the windsheld then at freeway speeds , and below that the scoop will let air IN, not out! thats how the chev "cowl indution" hood works. high presser is formed in front of the windshield at speed. if you want to help cooling on the trail how about a elect. fan pointing at the header?
           JUST ANOTHER  :idea: FROM THE     SUPER HUMAN FOOL!    :yupyup: :wave:
SWAMPER
  • Male Posts: 3,599
  • Semper Fi
« Reply #28 on: Jul 05, 2004, 02:19:25 PM »
oh ok and just to finish it off why dont I just coat my headers with liquid nitrogen Mr. know-it-all!!! :fakeflip: jk thanks Brainless....so My idea wonlt work? :headscratch:
yotaboy79
  • stuck in the shop
  • Turtle Points: -19
  • Male Posts: 2,838
  • Member since Aug '03
« Reply #29 on: Jul 05, 2004, 02:20:42 PM »
 :dunno:
Last post Jul 05, 2004, 11:49:49 PM
by donkeykong
Last post Nov 17, 2004, 07:11:30 PM
by gturismo
Last post Feb 09, 2012, 03:47:05 PM
by 83 Crawler
Last post May 04, 2009, 05:35:49 PM
by 46&2
Last post Jul 25, 2006, 01:54:20 PM
by *FFC*
