Well I recently acquired a 93 4wd Sidekick with Automatic locking hubs. To my disappointment, its not a "shift-on-the-fly" system. You have to bring the vehicle to a complete stop shift into 4wd (to engage the front driveline) then once the vehicle starts moving again the hubs will sense the front axles are now turning, which inturns engages the front hubs. Then its my understanding that if you back up, the hubs will unlock and relock.
Anyways - I like the good old manual locking hubs that I know are engaged at a turn of the dial, so I wanted to swap them out. Warn and Superwinch makes locking hubs for this application, but they are around $100+ for a set. Also Warn hubs use straight through bolts which are known as a weak point since the bolts can loosen up with use and shear off. While the Superwinch ones use the nicer factory style cone washers (like Aisin hubs) and are known to be more reliable.
But with me being a cheap skate - I wanted an inexpensive solution. Locking hubs was a factory option, so you can find them in wrecking yards that "swap right on". But the sidekick/trackers seem to be fairly rare in my local wrecking yards plus they would probably charge me close to what they want for new aftermarket hubs. Again thinking with my empty wallet I looked for other options.
I've "heard" of people swapping on Samurai hubs onto the Sidekick/Trackers since they both have 22 spline front axles. Searching around on the web I found this post explaining thats is possible. but unfortionately there isn't a bunch of good pictures showing what teh guts of these hubs look like and possible solutions since teh sami hubs are not a 100% bolt on.
http://bbs.zuwharrie.com/content/topic,45247.msg477906.html#msg477906So I called around my buddies to see if anyone had some Sami hubs they could donate for the cause. Well lucky for me I found 3 freinds that had bits and pieces of Sami and random Aisin hubs that I got for free, Thanks guys. Sami's and Sidekicks have a 22 spline count, IFS Toyota's have a 27 spline count, and Solid Axle (SA) Toyota's have a 30 spline count. But "basically" everything else is the same in the Aisin hub. I believe Isuzu's use Aisin hubs also, but I haven't messed with those.
Please note that I haven't cleaned up and rebuilt my hubs yet, but if you want to know how, check out this thread:
Rebuilding 1979-1985 Toyota Manual Locking Hubs
http://www.pirate4x4.com/forum/showthread.php?t=281879So it was time to tear into it. First I removed the Sidekick Auto hub.
