I did not use the butt connectors provided, but instead soldered the wire on with double shrink tubing over it. I did this because the O2 sensor only sends a maximum of a 1 volt self-generated signal, and I believe that the soldered connection doesn't have as much resistance as the butt connectors, and is less likely to corrode, which would provide a poor signal to the computer. I then routed the wire under a heat shield to protect the plug in, and then ran the wire along the fram
Started by Skinny_Pedal General 4WD Discussion
Started by benman General 4WD Discussion
Started by KDXSR5 « 1 2 ... 6 7 » Toyota Pickup/4Runner Tech 1979-95
Started by 1st_gen_runner Parts Wanted
Started by 79coyotefrg Toyota Pickup/4Runner Tech 1979-95
