Pages: [1]   Go Down
  Print
Author Topic: New bumper install, first attempt=FAILURE  (Read 969 times)
KDXSR5
Poser Shot Extraordinaire
The 2.5K Group
Turtle Points -74
Offline Offline
Gender: Male
Member since Dec 06
The Good Ol' Days
« on: December 22, 2007, 11:11:59 PM »
 Help!
OK, I finally got around to trying to install my Marlin front bumper. I got the six front bolts on, I tightened the large bolts to 55 ft-lbs, and the smaller two bolts to 30 ft-lbs (is this enough? I don't want to break them). Now the two bolt holes with welded on nuts that are on the added mounting brackets don't line up at all. The are too narrow, and are too far back.
On the passengers side, the factory hole is at the bottom of the line, and the hole with welded on nut is at the top of the line if the bottom of the line is the front of the truck (I hope this makes some sense).
The driver's side is the exact opposite. Bottom is factory hole, top is where welded nut + hole is located, if bottom of line is the front of the truck.
So, what should I do? I am thinking I should drill the factory holes the make them 45* angled ovals towards the middle/rear of truck, then use the welded on nut. The problem is that the body mount is in the way of doing that, so I would have to modify the rubber part of the body mount.
____________
l /O            O\ l   LOOKING DOWN FROM THE TOP
FRONT OF TRUCK
The / and \ are the oval cuts I will have to make, with the bottom of the cuts being the factory hole. The Os are the body mounts, the / and \ will interfere with these. The rest of the stuff is making a very rough diagram of the frame.
The other option is grind off the welded on nut, drill out the added bracket on the bumper, and use a new nut. This would mess up the powdercoating, plus it is thicker metal, so it would be harder to drill. It is not my first choice.
Any other ideas?
 Help!
« Last Edit: December 28, 2007, 10:45:22 PM by KDXSR5 » Logged
Gold Turtle Award
Turtle Points -58
Offline Offline
Gender: Male
Member since Oct 04
Are you threatening me?!
« Reply #1 on: December 22, 2007, 11:17:04 PM »
Have you tried installing all the nuts/bolts loose before tightening anything up?  Would that get you close enough to atleast get all the bolts started?
Logged
SEARCH!!!  Remember, if you have what you feel is a brilliant idea, chances are thousands of others have asked the same question!
Supra LSD install in v6 3rd:   http://gearinstalls.com/supralsd4.htm
I would rather put ifs back on than buy from TG - pickemup81
KDXSR5
The 2.5K Group
Turtle Points -74
Offline Offline
Gender: Male
Member since Dec 06
The Good Ol' Days
« Reply #2 on: December 22, 2007, 11:28:49 PM »
Yes. I spent from about noon until about an hour and a half ago trying to line them all up. I first installed the six front bolts loosely, then do the PITA bolts, but they would not line up. So I had my dad (this was out at his shop) push on the bumper while I tried to line the PITA upside down bolts up. Would not work. So I took all the bolts off, and tried to line up just the passenger's side PITA bolt, but it interfered with the body mount. So I removed the body mount, and tada, the bolt finally went into the nut. I then tried to line up the other PITA bolt (after removing the other body mount), but guess what? It was so far off that I couldn't even see 1/4 of the hole for the driver's side bolt. So, I again removed the bumper, then bolted it on with the six bolts I could get to work, and torqued them down. It is still sitting out at the shop (I was also working on the front axle and tailights, so no street ready.), and I am trying to figure out what I should do. On the plus side, it looks so much meaner with the bumper installed! Ideas?
Logged
Thomas P
The 2.5K Group
Turtle Points 30
Offline Offline
Gender: Male
Member since Feb 06
Its not just beer, its man water
« Reply #3 on: December 23, 2007, 07:24:13 AM »
would it work with a body lift?
Logged
'85 EFI X cab SR5. 42" & 39.5" IROKS, 5.29's, spool r, lock right fr, 30 spline longs and hub gears, marlin hi steer, skys widening kit, FJ rotors w/V6 calipers, Putney custom cam, intake, 92 22re, thorley header 2.25 exhaust with magnaflow hi flow cat and muff, hybrid toy waggy fronts, f-150 rears, JL 12W6, Marlins dual ultimate cases, skys dual t-case crossmember, high angle CV drivelines, optima, onboard air, 96 prelude buckets, 2wd bed, homebrew bumpers, 8k lb warn winch, hydro assist, 5th stud knuckle http://board
Gold Turtle Award
Turtle Points 124
Offline Offline
Gender: Male
Member since May 02
Solid axle Toys Rule ! ! !
WWW
« Reply #4 on: December 23, 2007, 08:21:11 AM »
Worthless without pics
Logged
AR-TTORA president 22R bored.060,LCE stage II race cam 32/36weber, Driving Marlin 1200 NON ceramic clutch, L52SHD+dualcase #2919, cable-locker, Yukon 5.29 gears, 35's, Allpro ebrake, front springs, and high steer, F150rears RIP Nitro 9-29-07 MarlinCrawlerInc IS NOT affiliated with TrailGear in any way[/url
KDXSR5
The 2.5K Group
Turtle Points -74
Offline Offline
Gender: Male
Member since Dec 06
The Good Ol' Days
« Reply #5 on: December 23, 2007, 10:42:04 AM »
The body mount isn't the big problem, the holes are not lining up is the problem, so I think a body lift is unnessesary. I am still kicking around the idea of a one inch body lift though, but that is another topic. Are those torque specs ok? I will try to mess around with a pic to show what I am talking about.
These are the holes that line up. The red ones work, the blue one is not used
These are the holes that do not line up. The red is the hole that the bolt is supposed to go through, the blue is the welded on nut on the bracket. As one can see, they do not line up. The way I want to fix this is make the red hole into an oval so I can get a bolt into the bumper. The problem is that I can not get a drill up in there from the bottom, and I really don't feel like pulling the cab just to drill two holes.
Logged
aka: Momentum Man
Gold Turtle Award
Turtle Points -518
Offline Offline
Gender: Male
Member since Jul 04
Shut-Up And Drive
WWW
« Reply #6 on: December 23, 2007, 10:46:02 AM »
Marlin doesn't make a bumper for a bodylift.
Logged
Just Because You Know How To Build It Doesn't Mean You Know How To Drive It
This Ain't A Place For Gentlemen On A Sunday Drive
It doesn't matter how many hats you wear, it's what you do with the one you've got on right  now
Ninja
KDXSR5
The 2.5K Group
Turtle Points -74
Offline Offline
Gender: Male
Member since Dec 06
The Good Ol' Days
« Reply #7 on: December 23, 2007, 10:50:04 AM »
That wasn't the question. Head Scratch Screwy
Logged
aka: Momentum Man
Gold Turtle Award
Turtle Points -518
Offline Offline
Gender: Male
Member since Jul 04
Shut-Up And Drive
WWW
« Reply #8 on: December 23, 2007, 11:20:23 AM »
I was just refering to 1985's comment about a bodylift and that your holes should line up.
Logged
Ninja
aka: Momentum Man
Gold Turtle Award
Turtle Points -518
Offline Offline
Gender: Male
Member since Jul 04
Shut-Up And Drive
WWW
« Reply #9 on: December 23, 2007, 11:23:35 AM »
It is odd that the holes don't lineup, has your truck ever been in an accident? Could have a bent frame, or maybe all that flexing tweaked it.
Logged
Ninja
KDXSR5
The 2.5K Group
Turtle Points -74
Offline Offline
Gender: Male
Member since Dec 06
The Good Ol' Days
« Reply #10 on: December 23, 2007, 11:32:44 AM »
If this truck has ever been in an accident, it was in the right rear corner. The bed side is rippled, and the frame is pushed over 1/4 of an inch. So, to my knowlage, no the truck has not been in an accident in the front. The carfax I did on it said there was no wrecks recorded, just smog stuff in colorado. I don't think this truck flexes enough to mess up the frame. The hole that it mounts to is right next to the body mount, and the bracket interferes with the body mount rubber between the frame and the radiator support. It is almost like the bracket was welded on upside down, or backwards, or is just off. The distance between the holes is narrower than the holes in the frame by about 1/2-3/4 of an inch, plus the bracket holes are about a 1/4 inch to far back. This just frustrates me a little bit, because I was not planning on doing this much work to put a bumper on.
Logged
Not A Toy
Rock Master
Turtle Points 0
Offline Offline
Gender: Male
Member since Mar 07
« Reply #11 on: December 23, 2007, 11:40:13 AM »
You should see what we had to do to get fearofrunners rear bumper to fit, took quite a bit of tweaking but in the end it was worth it we did alot of reaming, pushing pulling......could you get a angled drill in there with a uni bit?
Logged
_[O!!!!!O]_
People often ask how they stack crap so tall....
94MtnYote
Crawler Guru
Turtle Points -8
Offline Offline
Member since Oct 07
- 94 std cab - Inferior Front Suspension
« Reply #12 on: December 23, 2007, 11:42:11 AM »
 My buddy had a similar problem putting an All-pro bumper on his 84. (no body lift)
He ended up just hogging out the body mount holes a little, like you mentioned earlier.
 He was kinda  Mad
It sucks, but thats what had to be done after half a day of trying to make it fit.
The bumper came with an 89-95 sticker on it which was kinda weird too.
 But it ended up being the right year after all.
And looks great with the XD9000i all tucked in there. Thumbs Up
Logged
22RE .30 over, mild RV cam, K&N charger, LCE header, 2.25'' piping, high flow cat, Magnaflow.
 Marlin 1200LB clutch
KDXSR5
The 2.5K Group
Turtle Points -74
Offline Offline
Gender: Male
Member since Dec 06
The Good Ol' Days
« Reply #13 on: December 23, 2007, 11:46:40 AM »
the only way I am going to be able to drill it out is to lift the cab/rad support off the frame far enough to get a drill in there. It isn't a problem, because we have a couple of forklifts out at the shop, but it will take a lot of time, plus it is a PITA. The rear bumper I had no problems with, but this front one is kicking my Moon I think I will try to get a plasma cutter from a friend, because I may be able to fit that up in there. Or a torch. But I will try to drill it first. Taking cab/rad support loose is a last resort.
I still don't know what winch I want, I will probably buy myself one at tax time, or maybe next christmas. Maybe a Warn 9.5ti? I Dunno...
« Last Edit: December 23, 2007, 12:03:30 PM by KDXSR5 » Logged
Gold Turtle Award
Turtle Points -58
Offline Offline
Gender: Male
Member since Oct 04
« Reply #14 on: December 23, 2007, 01:15:33 PM »
I wonder if it's either a matter of the holes not being drilled properly or the tabs pulling from the heat when welded?
Logged
KDXSR5
The 2.5K Group
Turtle Points -74
Offline Offline
Gender: Male
Member since Dec 06
The Good Ol' Days
« Reply #15 on: December 23, 2007, 02:30:42 PM »
Well, I am going to go finish my electrical stuff I was working on, and finish taking my front axle off. I will hopefully get the axle back on after dinner, and I will drive the truck with just the six bolts for now. I will mess with the bumper tomorrow, maybe tuesday.
Logged
KDXSR5
The 2.5K Group
Turtle Points -74
Offline Offline
Gender: Male
Member since Dec 06
The Good Ol' Days
« Reply #16 on: December 23, 2007, 10:40:10 PM »
Ok, I finished with my electrical stuff. I took the front axle off to replace the spring tie bolts, but they were not broken, which is wierd if you have read my exhaust thread. I replaced them anyways, and put everything back together. Tomorrow is LCE header install day. Bumper will have to come next weekend, or some other time. Anyone use a Warn 9.5ti? I am thinking about using one, just looking for opinions.
Logged
94MtnYote
Crawler Guru
Turtle Points -8
Offline Offline
Member since Oct 07
« Reply #17 on: December 23, 2007, 11:09:02 PM »
 On the topic of LCE header install.
 Be very careful when removing the header nuts from the studs in the aluminum head.
 On mine some of the nuts were seized to the stud, and the whole stud came out of the head. which was fine since I purchased new studs.
However, through a combination of beer and excitement.
I ended up stripping the very outer threads one of the aluminum stud holes on the head.  Smack!
 It was just a few threads and I was able to chase the threads with the proper tap and install the new stud. I did not want to bother with a helicoil.
 All this might be obvious, but thought I'd just throw my  My Two Cents out there.
Logged
KDXSR5
The 2.5K Group
Turtle Points -74
Offline Offline
Gender: Male
Member since Dec 06
The Good Ol' Days
« Reply #18 on: December 23, 2007, 11:20:20 PM »
Thanks for the info. I probably should have bought new studs, but I didn't think of it at the time. I have been soaking the nuts in rust remover stuff a Toyota tech gave me over the last couple days. I am pretty sure it should be illegal. It smells so bad, and it burns when it gets on my skin, almost as bad as gasket remover. All the bolts were coated with mud and rust, but a couple sprays of that stuff, and all the rust/mud was gone! I think the stock manifolds were switched when the engine was replaced, but I am not sure. I guess I will find out.
Logged
Cheesemaker
The 2K Group
Turtle Points 159
Offline Offline
Gender: Male
Member since Sep 04
Dean Tyler, you were an inspiration to all!!
« Reply #19 on: December 23, 2007, 11:23:37 PM »
What I'd do, is call MarlinCrawler.  They will be more than willing to help out!  Which might be after Christmas!
Logged
Tool Pimp
The 1K Club
Turtle Points -10
Offline Offline
Gender: Male
Member since Jun 06
« Reply #20 on: December 23, 2007, 11:27:34 PM »
Just weld it on  Joke
Logged
KDXSR5
The 2.5K Group
Turtle Points -74
Offline Offline
Gender: Male
Member since Dec 06
The Good Ol' Days
« Reply #21 on: December 23, 2007, 11:34:19 PM »
I was going to call, but that is the problem, it is Christmas time. I want it done this long weekend, so I will probably egg out the holes in the frame enough to bolt the bumper on and call it good. Plus, if they want it back, I just wasted a good chunk of change on some high quality powder coating. I would weld it, but it is powder coated, so nah, thats ok. I will probably still call to tell them the kind of crap I had to go through to get it to line up.
Logged
DN1911
Rock Crawl'n
Turtle Points -3
Offline Offline
Member since Nov 05
Crawling with Marlin
« Reply #22 on: December 25, 2007, 06:53:54 PM »
the part probably just pulled some after welding. my best advice is to just oval the holes in the bumoer a bit and get over it. you are trying to install a man made part on a 20 year old truck, things start to vary more and more over time. as a fabricator this is a common problem as all tolerances can be 100% all the time.
Logged
Bazzi
The 1K Club
Turtle Points -44
Offline Offline
Gender: Male
Member since May 04
From Reykjavik Iceland...
« Reply #23 on: December 25, 2007, 06:58:48 PM »
congrats on your new bumper... I love how he looks...  I would recomend loose bolts a litle head. and some muscle.
And I would paint that thing after finding out that it fits.
Logged
 2,4 dti duals 2,28 x 2,28 to 8" 5.71 with arbīs  and 39,5" trxus
But you gotta get them started early!  My son is completely ape over anything off-road related.   Crazy Jumpy   Gap
If you are on you way on vacation, the Icelandic Krona is on the low side... large beer costs 2-4$ here
ToYocRawleR
Gettin' Loose!!
The 2.5K Group
Turtle Points -5
Offline Offline
Gender: Male
Member since Oct 05
The Homie!!!
« Reply #24 on: December 25, 2007, 07:53:27 PM »
If it were me and wanted to keep it strictly "bolt on" i would cut those tabs off bolt em up then bolt the bumper on and have em welded back to the bumper. just my  My Two Cents . Good luck with it.
Logged
Rigs:
05 F-250 Powerstroke
88 SAS toy
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
KDXSR5
The 2.5K Group
Turtle Points -74
Offline Offline
Gender: Male
Member since Dec 06
The Good Ol' Days
« Reply #25 on: December 26, 2007, 12:20:15 AM »
Ok, I got it on with six bolts. I am happy, it looks nice. I will worry about egging out those holes at a later time before I put a winch on it. Pics!
Logged
   Pages: [1]   Go Up
  Print
Jump to:
© All Content Copyright 1994-2010 Marlin Crawler, Inc. All products intended for Off-Road use. Prices subject to change without notice.
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Page created in 0.3 seconds with 19 queries.
