1) can i reattach the thirds with hex bolts instead of studs? i dont see why this wouldnt work.
ok, i will use the studs then.i am working on my front axle now. is that gear oil in the knuckles? or is it liquidified grease?
Just supposed to be grease, if it is liquid the axle seals were leaking. Marlin has some aftermarket replacements that are a lot better then the OEM ones.
Be aware, if you use hard line and the Toyota tee you have two different threads metric for the tee and standard for the Caddy calipers. You will need to use standard hard brake line and reflair one end with the metric fittings.
anyone know where i can get a pic or exploded view of a 95 v6 front caliper? i bought just the calipers at the parts store, and i didnt even think about all the little extra stuff i need to run them on my 85 axle... shims, springs, etc... i dont have any of that! thanks!joe
right on.i cant wait to see this tracker on solids.
Started by GrenadedToy Toyota Pickup/4Runner Tech 1979-95
Started by FSAD Engine
Started by TOY087 Engine
Started by Hickory Nut Axle/Differential/Steering
Started by franky112665 General 4WD Discussion
