Author Topic: Flatbed designs and pics!!  (Read 66778 times)
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
« on: May 13, 2007, 01:09:09 PM »
I'm looking for a flatbed design.  I've done a search on the site, but most of them have a step up design for tire clearance.  What I want is a total flat bed design.  So, I can use sideboards for hauling debris, garbage or firewood.  I also want to use a rack system on it, for when I need to haul some lumber or a ladder.  I want to have two sideboards, a tall and a short design, depending on what I want to haul.  So, how far above the frame should a build it?  For tire articulation!  But at the same time I want to keep the flatbed as low as I can for center of gravity!  I got a basic design in my head, but I haven't put it down on paper yet.  And I was wanting to use wood for the decking!  So things won't rattle in the bed when driving!   So post up some pics and some designs for me to get a better idea of what parameters I'll be looking at!
Thanks, Cheesemaker
Rockdiver
  • Turtle Points: -118
  • Male Posts: 671
  • Member since Apr '04
Re: Flatbed designs and pics!!
« Reply #1 on: May 13, 2007, 08:55:09 PM »
Here are some pics  I think 2x3 rect tube with round post sideboard and rack will work for you . if you make it right you can pull up a 35" under the bed like marlin for a spare too. Following pics borrowed from where i found them ;-)
Rockdiver
  • Male Posts: 671
« Reply #2 on: May 13, 2007, 09:00:20 PM »
More   Just take the best parts and make work for your needs
toy4x4ota
  • Turtle Points: 31
  • Male Posts: 468
  • Member since May '05
  • learning how to drive
« Reply #3 on: May 13, 2007, 09:03:02 PM »
i have always loved that rig by the tinbenders
LIFTED TRUCKS ARE GAY
Jud
  • Scumbaggin
  • Turtle Points: -261
  • Male Posts: 3,067
  • Member since Oct '05
  • Gettin it since 1990
« Reply #4 on: May 13, 2007, 09:29:56 PM »
Wow! Theres some nice flat beds in those pics!
"bout tree fiddy"
rednk1980
  • Male Posts: 1,295
  • Member since Mar '06
  • Pull Your Panties to the side!
« Reply #5 on: May 13, 2007, 09:38:46 PM »
Heres mine :thumbs:
redrocket93
  • Turtle Points: 3
  • Male Posts: 690
« Reply #6 on: May 13, 2007, 10:42:19 PM »
Here are some pics of mine.
Cheesemaker [OP]
  • Male Posts: 4,525
« Reply #7 on: May 14, 2007, 01:12:05 PM »
I'm looking at one like Rednck1980's!  I like the total flatbed design.  So what size of tires you running and how much distance is between the frame and the bottom of the bed frame?  And how far have you had the tires stuffed into the flatbed?  And at rest how much distance is between the tire and bottom of the flatbed?  I'm not building a full on rock crawler, but a truck that is capable of doing the Rubicon and haul a load of firewood around my place when needed.  A more universal style of flatbed.  I love some of the other styles that were posted, and I appreciate those pics.  Thanks!
86turboyota
  • Male Posts: 1,079
  • Member since Jul '05
« Reply #8 on: May 14, 2007, 02:06:45 PM »
all these pics make me want a 1st gen with a flatbed...
My Build 1986 4runner SAS 36s etc
http://board.marlincrawler.com/index.php?topic=22625.0
"Later, I learned that even though I engage 4WD my hubs are not automatically locking? Something about manual locking hubs I think. What's manual mean? I need to read a manual to lock them? lol  So I found these neat autolocking hubs and installed them. Sometimes they dont stay locked while I am backing up, but that's fine because I dont have a backup camera to see where Im going (like our RV) so I just simply dont ever back up"- BigMike
Rockdiver
  • Male Posts: 671
« Reply #9 on: May 14, 2007, 02:11:02 PM »
Cheesemaker show us a pic of the truck it is going on. Body lift?  Lift? Tire size? If you can find some shelving from a home depot it is rect tube with a drop edge for wood.  Works good for flatbeds. you can get pockets and other stuff from redneck trailer
Fongs
  • Male Posts: 299
  • that`s the way to hell
« Reply #10 on: May 14, 2007, 02:49:38 PM »
Here the FLAT build by Loafi and Zappel
 :beerchug:
topar
  • Male Posts: 1,909
  • Member since Aug '06
  • One Toyota + One Mopar = Topar
« Reply #11 on: May 14, 2007, 02:57:53 PM »
 :thumbs: Some nice flatbeds on here!
rednk1980
  • Male Posts: 1,295
« Reply #12 on: May 14, 2007, 04:21:18 PM »
Tire size: 37's
Distance between frame and bed: 8 in
Tires have been stuffed all the way into the bed
Distance between tire and bed: 9in
If i could build it over again i would make it somewhere between 10-12 inches off the frame instead of 8 because the tires rub really bad.  :thumbs:
John Doe
  • Turtle Points: 469
  • Male Posts: 1,587
  • Member since Jun '05
    • Bored In Iraq.
« Reply #13 on: May 14, 2007, 07:43:50 PM »
Rockdiver's flatbed, 1 of my favorite. :love:
http://board.marlincrawler.com/index.php?topic=13200.0
« Last Edit: May 14, 2007, 07:49:26 PM by John Doe »
Rockdiver
  • Male Posts: 671
« Reply #14 on: May 14, 2007, 08:25:44 PM »
Thanks John   Actually I visioned something like rednk1980's truck  but......... once you start the ideas go crazy
Last post Aug 07, 2004, 07:17:10 PM
by SWAMPER
Last post Sep 04, 2006, 08:51:54 PM
by Rockdiver
Last post Feb 08, 2007, 01:02:36 PM
by 88Rokyoat
Last post Nov 21, 2009, 05:13:26 PM
by gmack192
Last post Feb 28, 2012, 03:19:01 PM
by Volcom
