I thought you were using Excel?
I used excell but you cant attach an excell file on this site, only jpeg,bmp, txt, and a few other styles. I even tried to attach it in word but it wouldnt take that either. I have the excel file with all the data in it if anyone wants/needs it I can email it.
Sweet, you are in charge of updating it and reposting the results!Thanks!
From the ground to the center of the crossmember, not the bottom of the spring hanger brackets.
My wheelbase is 106" incase ya want to update.
I'll get my wheelbase when I get home tonight.Then what the heck is up with everyone's rig?? My tires only measure 35.875" and my height is nearly 4.5 inches higher than everyone elses..If you remove my figure from the average, then the new average is 26.4975".How is my truck 30.375" with 35.875" tires, when yotaboy79's rig is only 27.75" with 39.5" tall tires?Sorry to point fingers at ya yotaboy, its just that you've got the largest tires out of the submitted values He's got 1.8125" more tire height but his frame is 2.625" lower That means that if we had the same tires, then his frame would be 4.4375" lower than mine, and I've got 4" springs installed.What is everyone running, like factory front Toyota springs with a couple leafs removed or something?
and my truck is a 1979 not a 1978 lol
check out my 1st post again.
i like my truck low and stable i have enouph problems keeping 4 wheels down
Height to front spring hanger – 30 ¾”
but it is just REALLY surprising to me to see that I have one of the tallest frame measurements here
It's not really all that surprising since you have not had to cut your fenders yet. Your truck does sit pretty high, but you haven't rolled it yet so no problem.So if you have a 4" lift and if you subtract the height difference of our front spring hangers minus our diff heights, then my lift = 0.7" with your truck having a 3.3" height difference in suspension. If that makes any sense.BigMike's height difference between spring hanger and bottom of diff = 18.3"MiniSimp's height difference between spring hanger and bottom of diff = 15.0"Right? My math may be all fubar'dThat is why I wanted the measurements of a bone stock truck, is so I could figure out my actual lift height.
Of course the body lift has nothing to do with my frame measurements, but it is just REALLY surprising to me to see that I have one of the tallest frame measurements here
Wheelbase - 126''
Started by cruzila « 1 2 ... 32 33 » Rig Gallery
Started by yotaboy79 « 1 2 ... 32 33 » Chit Chat Camp
Started by BLACKDOG « 1 2 ... 11 12 » Chit Chat Camp
Started by Willy Mammoth « 1 2 3 4 5 » Chit Chat Camp
Started by Rydell Project Research and Build-Ups
