Author Topic: The official rig height thread  (Read 85244 times)
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Member since Oct '06
  • Oodelally
Re: The official rig height thread
« Reply #120 on: Mar 19, 2010, 09:47:10 AM »
I'll be adding a leaf to my front pack, that will put me right at that your height :) . You compensated for tire size?
MiniSimp [OP]
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
« Reply #121 on: Mar 19, 2010, 09:58:01 AM »
I didn't count tires, just the distance between the bottom of the diff and the front hanger.
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #122 on: Mar 19, 2010, 10:11:12 AM »
Shoot. Then your way lower than me. I'm still on 33s.
MiniSimp [OP]
  • Male Posts: 5,120
« Reply #123 on: Mar 19, 2010, 10:16:17 AM »
Probably then, I'm on 36.8's at 0psi :D
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #124 on: Mar 19, 2010, 10:17:38 AM »
What is the height of the center of your headlight? Mine is 39.5in.
MiniSimp [OP]
  • Male Posts: 5,120
« Reply #125 on: Mar 19, 2010, 10:19:07 AM »
No idea, I can look tonight, if I remember
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #126 on: Mar 19, 2010, 10:25:45 AM »
I'll have to get measurements of it weighed down. The offroading height :)
  • Administrator
  • Turtle Points: 2124
  • Male Posts: 18,289
  • Member since Apr '02
  • 511:1 Club
« Reply #127 on: Mar 19, 2010, 12:19:00 PM »
Stickied.
jss
  • Male Posts: 36
  • Member since Jun '09
« Reply #128 on: Mar 20, 2010, 11:10:34 AM »
Here's my numbers  -   :thumbs:
Make  -  Yota
Year -  85
Model - 4Runner
Height to Front Spring Hanger  -  25.5"
Height to very rear of frame  -  34"
Height to Bottom of Frame Door  -  25"
Height of Transfer Case Skid Plate  -  22.5"
Height to Bottom of Front Diff  -  11"
Height of Tires at 30psi  -  35"
Wheelbase  -  105"
Hold my beer and watch this....
Yoat Goat
  • Turtle Points: 37
  • Male Posts: 731
  • Member since Aug '07
  • Someday my truck will look like this
« Reply #129 on: May 02, 2010, 06:13:03 PM »
Make - Toyota
Year - 1980
Model - Truck
Height to front spring hanger - 27 3/4" stock crossmember
Height to very rear of frame - 30 3/4" (might be off due to driveway  :talkingn:)
Height to bottom of frame under door -22 1/4"
Height of transfer case skid plate (or just case if no skid) - 18 1/4" to drain plug
Height of tires at "X"PSI - 33 1/4" at 15 psi
Height to bottom of front diff - 10 3/4"
Wheelbase - 114"
T urning
O ver after
Y ears
O f
T rail
A buse
weakyota91
  • Male Posts: 118
  • Member since Nov '09
« Reply #130 on: May 03, 2010, 08:26:50 PM »
Make - toyota extended cab
Year - 1991
Model - p/u
Height to front spring hanger - 27.5
Height to very rear of frame - 34.5
Height to bottom of frame under door - 27
Height of transfer case skid plate (or just case if no skid) - 21.5
Height of tires at "X"PSI - 33.2
Height to bottom of front diff -10.5
Wheelbase - 121.9
Yoat Goat
  • Turtle Points: 37
  • Male Posts: 731
« Reply #131 on: May 03, 2010, 10:13:41 PM »
Maybe some peple get the frame measurement wrong, is it the bottom of the frame or bottom of the door? Im getting conflicting measurements with different peoples measurements. Maybe frame height is different on diff years...
T urning
O ver after
Y ears
O f
T rail
A buse
MiniSimp [OP]
  • Male Posts: 5,120
« Reply #132 on: May 04, 2010, 06:35:14 AM »
For this measurement it is the bottom of the frame, definetly not the door.
Yoat Goat
  • Turtle Points: 37
  • Male Posts: 731
« Reply #133 on: May 04, 2010, 05:07:39 PM »
ok, just making sure.
T urning
O ver after
Y ears
O f
T rail
A buse
  • Turtle Points: 679
  • Member since Feb '03
  • Don't blame me, I didn't vote for this crap.
« Reply #134 on: May 05, 2010, 12:35:40 AM »
80 long box
128.5" wheelbase
25" to the frame, flat belly nothing hanging down.
44's
73ish inches to the top of the roof.
That's the best I can do sitting in CA at a truck stop. :gap:
exxon
  • Member since Mar '10
« Reply #135 on: May 13, 2010, 06:54:01 PM »
anybody have stock measurements on a 86 'runner? I looked and haven't seen anything.
'86 4runner 22re
'04 TJ
'78 Ramcharger 440 35's
MiniSimp [OP]
  • Male Posts: 5,120
« Reply #136 on: May 15, 2010, 10:37:45 PM »
Finally got to this. :gap:
With the 37's aired up to 25psi (street pressure) the center of the headlight is 39" even.
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
« Reply #137 on: May 16, 2010, 12:44:32 AM »
35psi
37" tires
42.5" headlights
5"s of lift
26" at frame under door.
« Last Edit: Aug 10, 2011, 04:17:37 AM by TacoRunner »
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
Yota Rolla
  • Turtle Points: -3
  • Male Posts: 340
  • Member since Sep '10
« Reply #138 on: Sep 30, 2010, 10:35:48 PM »
Year -82 pickup
Height to front spring hanger -29 1/8
Height to very rear of frame -35 7/8
Height to bottom of frame under door -27 1/4
Height of transfer case skid plate (or just case if no skid) -27 3/4  :yesnod:
Height of tires at "X"PSI -35 1/4
Height to bottom of front diff -12 5/8
Wheelbase - 108''
« Last Edit: Sep 30, 2010, 10:41:54 PM by Yota Rolla »
82 locked,geared,cased,caged daily
muddywaters
  • Male Posts: 73
  • Member since Jan '08
  • back to basics
« Reply #139 on: Oct 08, 2010, 02:05:49 PM »
Year-81 pickup
Height to front spring hanger-24 1/4
Height to very rear of frame-30
Height to bottom of frame under door-22 3/4
Height of transfer case skid-forgot to measure will update
Height of tires at "X" psi-34.5
Height to bottom of front diff-almost 12
Wheelbase-107.5
Im like Hugh Hefner minus everything good about his life.
*** YELLER ***
  • BIGMIKE SAID I WAS A CLOWN SO .... GUESS THATS THAT
  • Turtle Points: 314
  • Male Posts: 4,686
  • Member since Oct '05
  • USMC NO BETTER FRIEND NO WORSE ENEMY
    • Buy me a soda
« Reply #140 on: Jul 20, 2011, 07:29:51 PM »
bringing this back from the grave :gap:
um stock runner height ???
I'll post mine tomorrow :thumbs:
except BACON
*** YELLER ***
  • Male Posts: 4,686
    • Buy me a soda
« Reply #141 on: Jul 25, 2011, 11:22:11 AM »
Make - Toyota
Year - 1987
Model - 4 Runner
Height to front spring hanger - 25 1/2"
Height to very rear of frame -  ???
Height to bottom of frame under door -  24 1/4"
Height of transfer case skid plate (or just case if no skid) - 19"
Height of tires at "X"PSI -  35 lbs
Height to bottom of front diff - 12"
Wheelbase - 109"
except BACON
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
« Reply #142 on: Jul 25, 2011, 11:24:25 AM »
 :blah:
[img]http://bo
Dingman.
  • Turtle Points: 1125
  • Male Posts: 3,448
  • Member since Oct '08
« Reply #143 on: Jul 25, 2011, 11:25:50 AM »
Cannot post here,  truck is on jack stands.  lol
*** YELLER ***
  • Male Posts: 4,686
    • Buy me a soda
except BACON
rockin86runner
  • Turtle Points: -18
  • Male Posts: 871
  • Member since Nov '07
« Reply #145 on: Jul 25, 2011, 11:48:36 AM »
Make - Toyota
Year - 1986
Model - 4 Runner
Height to front spring hanger - 25"
Height to very rear of frame -  or to rear shackle 27"
Height to bottom of frame under door - 26 1/4
Height of transfer case skid plate (to tcase drain plug ) - 23"
Height of tires at "X"PSI -  36.5
Height to bottom of front diff - 12.5"
Wheelbase - 110"
85 toy runner tons 4link front and rear ORIs 42 pitbulls
86 runner some other things  pained orange STOLEN REWARD IF FOUND
70 cj-5 renegade1 buick 231 v-6 t-18 dana20 dana 30,44 32in BFG at
 :usa: USN SEABEE EO2 SCW .....We Build.We Fight.We Defend....Hoo-Rah  GOD BLESS OUR TROOPS :usa:
patches
  • Male Posts: 144
  • This guy needs a beer
« Reply #146 on: Aug 23, 2011, 07:52:20 PM »
this is a sweet idea. too bad im not at home to give measurements! but that would be a good idea to do before i lower mine.
I don't trust anything that bleeds for 5 days and doesn't die....
TURBO
  • Turbo Extremist
  • Turtle Points: 65475
  • Male Posts: 706
  • Member since Sep '04
  • Capt. Insaino shows no mercy
« Reply #147 on: Nov 02, 2011, 03:13:37 PM »
i have a bone stock 82 longbed...(except the 31" bfg at's) will post up when the trans/t-case is back in
MY BUILDS: http://board.marlincrawler.com/index.php?topic=76463.0 :woohoo:
More than tread lightly, leave it like you were never there, nor anyone else.
I AM :screwy:!!!
"These dusty roads ain't streets of gold
But I'm a happy right where I'm at"
Marlin is like the Chuck Norris of the rock crawling world.
rattlers
  • Turtle Points: -68
  • Member since Mar '11
« Reply #148 on: Nov 26, 2011, 05:41:05 PM »
hello , I have a stock white 85 4runner sr5,22re,  5speed w56a ,brown interior,  235/75/15 tires . I only was able to measure 3 locations
1. 17 inches from bottom of frame under front door to floor
2.  8 inches from bottom of the lowest part of rear  axle , not sure if the front would be the same measurement or not
3.  25 inches from bottom of tailgate to floor
« Last Edit: Nov 26, 2011, 08:50:02 PM by rattlers »
__________________________
ll_______ll_______ll__TOYOTA_ll
ll_______ll_______ll____85____l
HI34
  • Member since Oct '15
« Reply #149 on: Nov 14, 2015, 01:44:20 PM »
Make - Toyota
Year - 1988
Model - Single Cab Pickup
Height to front spring hanger - 29"
Height to very rear of frame - 33 3/4"
Height to bottom of frame under door - 26 1/4"
Height of transfer case skid plate (or just case if no skid) - skid 19 5/8"
Height of tires at "X"PSI - 34" @23psi
Height to bottom of front diff -11"
Wheelbase - 102"
Aloha
Last post Feb 05, 2017, 10:33:53 AM
by joeyf
Last post Mar 19, 2010, 02:32:29 AM
by Rocksurfer
Last post Jun 27, 2019, 12:06:42 PM
by *FFC*
Last post Jul 31, 2009, 06:34:52 PM
by unclejpl4x4
Last post Nov 02, 2011, 10:01:31 AM
by Rydell
