Ok, I put it in the order I think we should do it in....
Remove front valliance
Body Lift
Buy 1" body lift from Roger Brown
Install 1" body lift
Roll Cage
Buy roll cage from Marlin Crawler
Install roll cage
Remove roll cage
Weld entire roll cage
Reinstall roll cage
Build rear half of roll cage
Weld rear half of roll cage
Buy roll cage padding from local hardware store
Install roll cage padding
Front Suspension
Buy front spring hanger kit from Marlin Crawler
Remove all IFS componants
Save IFS Hubs, Calipers & Rotors
Remove front driveshaft
Grind bottom of front crossmember flat
Weld front spring hanger 1/2" forward of stock
Cut front spring shackle holes with jig 1/2" forward
Weld front spring shackle tubes
Install new front spring shackles 5.5" eye to eye
Install new bushings in front shackle tubes
Install new bushings in front springs
Build "Rears-up-front" spring pack
Install "Rears-up-front" spring pack in front
Front Differential
Buy Aussie Locker from Offroadlockers.com
Remove front 3rd member
Install Aussie Locker in Front 3rd Member
Set backlash in Front 3rd Member
Front Axle
Buy 1.5" spacers from Marlin Crawler
Buy 8" weld-on pipe cap
Buy brake pads
Buy front axle truss from Marlin Crawler
Buy front U-bolt flip kit from Marlin Crawler
Buy knuckle ball supports from Marlin Crawler
Buy knuckle rebuild kit from Marlin Crawler
Buy Crossover steering from Marlin Crawler
Install bare front axle
Install U-bolt flip kit front
Weld front axle truss
Weld knuckle ball supports
Weld 8" pipe cap differential guard front
Install knuckle rebuild kit
Install crossover steering
Replace brake pads
Install 1.5" spacers on front axle
Steering
Buy flat pitman arm from OTT industries
Buy steering box brace from Marlin Crawler
Remove steering box
Remove pitman arm
Install flat pitman arm
Mock up steering box location far forward as possible
Weld steering box brace
Remove center pin on steering shaft
Install steering box
Bleed power steering box
Attach drag link to pitman arm
Fuel Tank
Lift gas tank 2"+
Rear Frame
Remove tow hitch
Weld box rear frame
Install hitch mount tube
Install rear tow point
Rear Suspension
Buy rear spring bushings
Find chevy springs
Torch out old spring bushings
Remove rear driveshaft
Remove rear axle
Remove rear springs
Build rear shackle hanger
Weld rear chevy shackle hanger
Build rear spring hangers
Weld rear chevy spring hangers
Build rear shackles 5.5" eye to eye
Install new bushings in rear springs
Install chevy springs
Rear Differential
Remove rear 3rd member
Install Aussie Locker in Rear 3rd Member
Set backlash in Rear 3rd Member
Rear Axle
Buy brake shoes
Buy Pivot blocks from Dave's Offroad
Weld Pivot blocks to rear axle
Weld 8" pipe cap differential guard rear
Replace brake shoes
Install chevy springs to pivot block
Drivetrain
Remove Stock Transfer Case Crossmember
Remove Transfer Case
Remove Transmission
Remove motor
Install motor
Tune Motor
Install transmission
Crawler
Buy MC07-R10 transfer case adapter from Marlin Crawler
Buy 2 transfer case rebuild kits from Marlin Crawler
Buy twinstick shifter from Front Range Offroad Fabrication
Buy transfer case center section from Front Range Offroad Fabrication
Rebuild front crawlbox
Rebuild rear transfercase
Install MC07-R10 transfer case adapter
Install Transfer case center section
Build transfer case crossmember
Install twinstick shifter in rear transfer case
Driveshafts
Buy 3' 2"x0.25" square tubing from welding shop
Buy 3' 2.5"x0.25" square tubing from welding shop
Build square front driveshaft
Install square front driveshaft
Shorten rear driveshaft
Install rear driveshaft
Brakes
Buy extended brakelines from Marlin Crawler
Install extended brakelines
Bleed brakes
Shocks
Buy 14" Procomp ES1000 shocks from 4WheelParts
Build front shock hoops
Weld front shock hoops
Build rear shock tower
Weld rear shock tower
Install 14" travel shocks front & rear
Tires & Wheels
Buy 2" backspaced wheels from SummitRacing.com PN:USW-88-5860R-SPEC
Buy 35"+ tires
Buy 50oz of Airsoft BB's for balancing
Mount 35"+ tires to wheels
Mount tires & wheels
Driveable!Rock Sliders
Build rock sliders
Weld rock sliders
Can-Bak top
Remove fiberglass top
Buy Can-Bak vinyl top from ?
Install Can-Bak vinyl top
Interior
Buy Rhino Liner = from Walmart
Install Rhino Lining on floor
Skid Plate
Build flat belly frame
Buy HDPE from Tap Plastics or cheaper supplier
Install HDPE flat belly
Tube Doors
Buy front tube doors from ?
Buy rear tube doors from ?
Install front tube doors
Install rear tube doors
What dave will be doing...
Paint everything
