Author Topic: tacoma SAS with toyota axle?  (Read 19627 times)
yota-tota
  • Turtle Points: 17
  • Male Posts: 232
  • Member since Oct '05
  • Crawling over Marlin
« on: Jan 29, 2007, 02:49:10 PM »
Thinking on retiring my 91 toyota D.D. and starting over with a 99 tacoma ex cab with the 3rz 5 speed. My toy axles are built with lockers front and rear and 5.29's so i'd like to be able to use the front axle and maybe the rear third if it'll fit.
Bascily does a w56 bolt up to the w59 bellhousing from the taco to give me the passenger drop needed?
Also would my 8" third fit the taco rear axle?
For the front width difference i'm just going to run my IFS wheel hubs then my 1.5" spacers and that should give me the 60" to match the rear. Add some 30 spliners and i think the axle will hold up for a while.
91 toy truggy on h2 injection, hacked n chopped n locked n SAS'd rolling 36" IROKS........doubler comming soon
wslytoy
  • Turtle Points: 36
  • Male Posts: 308
  • Member since Aug '02
Re: tacoma SAS with toyota axle?
« Reply #1 on: Feb 08, 2007, 07:32:35 PM »
I can't remember for sure if the W56 will bolt up to the W59, but for some reason it seems like it will??? Just remember, you'll have a weaker transmission. Your rear 3rd WILL NOT BOLT UP, PERIOD, END OF STORY! You can use the rear ring and pinion on an e-locker 3rd member, but a 3RZ w/ a TRUE TRD package is EXTREMELY RARE. The stock rear Tacoma 3rd is much stronger than what you've got anyway, so why mess w/ it? Just get a lunchbox locker, slap it in and call it done. Or you could always go w/ an ARB ;).
gabriul
  • Male Posts: 100
  • Member since Apr '06
« Reply #2 on: Jul 20, 2008, 11:04:00 PM »
As I tested earlier this evening, the bell housing on the back of a 22re 5spd (w56) will bolt directly up to the bell housing of my 3RZ (w59). So, yes, you can put a w59 behind your 2.7l 3RZ.
But this setup is weaker than the w59.
I am looking at the 27-4gt adapter so I can stick with my w59, and then step up to duel cases and such down the road. But I'm still confused.
Why bother swapping thirds when you can swap the entire axle housing with thirds and axles in it. The Taco and post 85 rear axle is the same width, same axle shaft, and same brake drum/shoes.
lilbuddy
  • Turtle Points: -234
  • Male Posts: 5,720
  • Member since Aug '04
  • Hella....
« Reply #3 on: Jul 21, 2008, 10:27:07 AM »
This is a false statement...
This is what they really are
The 79-85 rear axle housings are 55"
The 86-95 rear axle housings are 58"
The 95.5-04 (tacoma) rear axle housings are 60"
Also from BigMike:
Toyota Rear Axle Widths:
55" wide, '79-85 trucks/4runners
55.1" wide, '60-83 FJ40
57.9" wide, '81-87 FJ60
58.5" wide, '86-95 trucks/4runners
60" wide, '95.5-up Tacomas/4runners
62.2" wide, '91-92 FJ80
63" wide, '93-97 FZJ80
66.75" wide, '93-98 T100 trucks
RIP Kyota.... you are the man
GET IT!!!
jc052685
  • Member since Sep '08
« Reply #4 on: Sep 27, 2008, 09:08:25 PM »
i am intrested in your thirds if you want to sell them
thanks
jeff
832-892-1782
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • Member since Dec '05
  • California livin'
« Reply #5 on: Sep 27, 2008, 09:31:27 PM »
This is a guy I met on the Rubicon that bought a 2WD, 3rz 4runner and then swapped in a W56 and mini truck dual cases, so he was able to use a Toyota front axle.
COToy91
  • Turtle Points: -21
  • Male Posts: 1,241
  • Member since May '07
  • Rollin on 37's
« Reply #6 on: Sep 27, 2008, 10:20:12 PM »
Yes you can, not as strong as getting marlins R-series bellhousing and going that route. Then again i had a w56 behind a 4.3L never had an issue
No, do not even try not only is the width different, it is a different axle all together. From what i recall it is the 8.4 cause the ring gear is bigger
My first question is how you are dealing with the tcase crossmember since you are changing the truck from driver to passenger side drop on the tcase? Exhaust issue? Plumbing issues? sounds like a lot of work
legand71
  • Male Posts: 15
  • Member since Oct '08
  • /Users/admin/Pictures/iPhoto Library/Originals/200
« Reply #7 on: Oct 29, 2008, 11:42:50 AM »
does anyone know can i use the sas kit from marlin on my 2003 tacoma it sounds like i cant but not really sure?
COToy91
  • Male Posts: 1,241
  • Rollin on 37's
« Reply #8 on: Oct 29, 2008, 01:09:10 PM »
Look at Allprooffroad.com
then go to the tacoma section and you will see what you need
84TanToy
  • Turtle Points: -90
  • Male Posts: 44
  • Member since Jan '06
« Reply #9 on: Oct 30, 2008, 04:54:58 AM »
The tacoma frame is wider then the sas kit from marlin. I think that the frame is 3" wider if I remember right front range offroad makes a nice hanger kit for the tacoma that is what I have on my truck I also did my sas with a 1984 front axle housing with 1.5 " wheel spacers to match the 8.4 rear end I will post pictures later today. I hope that this helps you
My Wife Is Mean!!!
GJToyotabug
  • Male Posts: 969
  • Member since Jan '08
  • The bug is deep in this one
    • Alcan Spring
« Reply #10 on: Oct 31, 2008, 09:58:37 PM »
i think this will be an awesome build id love to see it.
as they say:
If you build it, they will come. :thumbs:
84TanToy
  • Male Posts: 44
« Reply #11 on: Nov 17, 2008, 10:44:15 AM »
Dude I spaced that I was going to post pictures of my truck so here they are lol. Some of the images are before I put 35" MRT's on my poopbox.
Doing the dirty.
The greatness of 44044's and 31" tires.
3" lift blocks and 33/14.5/15 SSR's.
35" MTR's and a JCB forklift.
My Wife Is Mean!!!
GJToyotabug
  • Male Posts: 969
    • Alcan Spring
« Reply #12 on: Nov 17, 2008, 11:30:03 AM »
oh wow that shackle angle is bad you might want to move it back like 4 inches on the drivers and 6+ scary man
84TanToy
  • Male Posts: 44
« Reply #13 on: Nov 17, 2008, 08:53:48 PM »
GJToyotabug The shackles have been moved back when it was on its "lets drive it in the field and hope nothing is wrong drive" and I seen that it was a problem. Good looking out
« Last Edit: Nov 17, 2008, 09:01:43 PM by 84TanToy »
My Wife Is Mean!!!
00taco
  • Male Posts: 156
  • Member since Feb '09
  • Cant wait to do SAS!!!
« Reply #14 on: Nov 24, 2009, 09:33:19 PM »
how can you tell and what is the optimum shackle angle? Cool build i am going to sas my taco also!
swapped89
  • Turtle Points: 270
  • Male Posts: 1,221
  • Member since Aug '09
  • Not all who wander...are lost
« Reply #15 on: Nov 24, 2009, 11:27:26 PM »
scuba??
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
Scuba
  • Member since Nov '09
« Reply #16 on: Nov 25, 2009, 11:00:05 PM »
scuba??
Naw man, That wasnt me
Saw that and had to sign up just to say that :)
So now Im on the MC board, Lets get this party started !
Some chant and meditate, I shift into 4Low.
Rockin a 99 Single Cab Taco, Locked lifted and armored sittin on 35" MTR Kevlars.
00taco
  • Male Posts: 156
« Reply #17 on: Dec 04, 2009, 04:21:31 PM »
anyone know
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
« Reply #18 on: Dec 04, 2009, 06:14:40 PM »
Where did you get that info from? It bolts up, but as for weaker, I dont think so. I ran that combo for 10 years while driving on freeways and crawling the Hammers and never had a problem. If Marlin thinks its weaker than i shut the heck up, but they are both W series and are almost Identical inside. Thats what I've seen FIRST hand.
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
<MIKE>
  • Turtle Points: 41
  • Male Posts: 618
  • Member since Dec '09
  • Swap, Lock, and Rock it
« Reply #19 on: Dec 06, 2009, 09:51:18 PM »
after seeing that 4runner i want to use a toy axle instead of my waggy 44 now.. hmm i hope to see your build so i can convince myself to go to a toy axle..
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89’s
249:1
TacoRunner
  • Male Posts: 2,324
    • 4wheelunderground
« Reply #20 on: Dec 14, 2009, 10:13:07 AM »
Have you thought about a Diamond Axle.
http://www.diamondaxle.com
<MIKE>
  • Turtle Points: 41
  • Male Posts: 618
« Reply #21 on: Feb 25, 2010, 09:26:33 PM »
ya i have..  only prob is $$$$$.
1987 4runner
249:1
Last post Apr 06, 2005, 10:07:33 PM
by yunaderis
Last post Mar 19, 2007, 06:49:47 PM
by ncrc
Last post Nov 25, 2010, 05:16:51 PM
by 97_tacoma
Last post Jan 18, 2013, 10:27:05 PM
by TEXCRAWLER
Last post Nov 18, 2015, 07:22:35 AM
by tyes
