No, They give you the spline with a yolk at the end. You Get a new U Joint and use the stack yolk (that bolts to the pinion flange) Then you take your factory drive shaft, Cut it right where those splines end and weld in the female end of the New spline shaft into that tube. I went ahead and spent an extra $90 i think it was?? And i bought the CV eliminator kit and he sent me the female end of the new spline kit already welded together.
Here is the link... I forget the guy that helped me over the phone, But he was super nice.
http://www.customdrivelines.com/index.html Tell him Hayes up in Washington Sent ya, He is very helpful.
Logged
Finally Straight Axled, e-Locker, 5.29's, Lockright Rear, 13" travel tractor spline driveshaft, CV eliminator, Fully Gusseted front axle, Marlins almighty 5" Trail Flex lift Kit, 36" TSL's
In Marlin Crawler, I trust.
If you got the Nuts, Follow my Ruts!
Lift It, Fat Chicks Can't Jump!
Motocross, Because it Requires 2!
