If you discussed your problem and why its there he should know what to do talk to him and find out how bad it was and what he did
I communicate with any one That does work for me in the sense, I want to pin point why it failed (the first time ) and for the second all the more reason to talk it out. Typically they will tell you how much they had to take off to make it good, planing the head. (off the seating surface)
go spend the $40 for a toyota head gasket and do it again,also i think the toy heads are a 3 step torqmake sure you fallow the instructions
So.........replaced the head gasket and intake gasket with high quality Fel-Pro gaskets.
always use a MLS(multi-layer-steel) gasket, either Toyota or Rockproducts.com
...why buy when you can build?
felpro gaskets are just fine, so is victor gaskets, they are the most popular gaskets, rockproduct gaskets are on the cheaper side.
just curious if you say this from personal experience or just what you've heard?
Started by Rebeltilldeath3 Engine
Started by 8D3TOY Engine
Started by mlatrella Toyota Pickup/4Runner Tech 1979-95
Started by E120ER Engine
Started by Groundpounder17 « 1 2 3 4 » Engine
