i would adjust your afm. that could also cause the miss. to check your codes there going to be a black boc on the passenger fender the said DIAGNOSTIC, if you dont have that setup, then go to your drivers side fender and your going to have about 3 or 4 unused yellow plugs. if memory serves me right its going to be a smaller one with only to straight holes in it. thats what you ground out to check your codes.
I have the motor and the truck and it runs! Now I just need to get the darn thing to run right. It runs VERY rich. I checked the MAF, and it is very clean. The vacuum system is hooked up correctly. Now it runs very rich and seems like it is missing. Also, the check engine light is on, but I can't seem to find the computer to short it and check the codes. The check engine light does, however, flash when I push on the accelerator peddle. The old diagnostic port was on the passenger fender connected to the wiring harness, but the new harness doesn't have it in the same spot (truck is an 87, motor is an 86). I am at a loss, any other ideas as to what may be wrong would be greatly appreciated
you've discovered the same problem I have.22re trucks have the diagnostics plug on the engine harness, 22rte trucks have the diagnostics plug(s) on the body harness. you used a rte engine harnes with a re body harness, hence, you now have no check connector. fun, huh?check your 02 sensor. the 22re harness has the wire for the 02 sensor comingform the passenger fender and the 22rte wire for the o2 sensor is part of the engine harness. make sure you hooked up the right wire, I'll bet you've got an extra really long singe wire connector hanging off the top of you engine and you don't know where it goes
right now I'm running a spliced in jumper lead between the T1 and E1 feds to the ECU. I have a $2 toggle switch hidden behind the passenger side kick panel that covers the computer. it works, but I'm gonna try to properly work in a diagnostic port now that the weather's warmer.here's some pics of the motor when I built it and after I installed it.mine's pretty modded. I run a bigger t3 turbo from a merkur xr4ti and a top mount intercooler I swiped from a Supra. there's internal engine and exhaust upgrades to help that all along, too.dwas the 02 sensor the problem for you?be careful, these pictures are hugehttp://www.dana60.com/sundowner/intercool1.JPGhttp://www.dana60.com/sundowner/intercool3.JPGhttp://www.dana60.com/sundowner/hood1.JPGhttp://www.dana60.com/sundowner/turbo1.jpghttp://www.dana60.com/sundowner/turbo3.jpg
Started by Dirty_Harry Project Research and Build-Ups
Started by rebel racer Parts For Sale
Started by sten_mitchell Parts For Sale
Started by CrazyYota Project Research and Build-Ups
Started by indica4r Toyota Pickup/4Runner Tech 1979-95
