Author Topic: Removing rear axle with out using the SST?  (Read 43453 times)
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Member since Nov '04
  • Drinking me beer
Re: Removing rear axle with out using the SST?
« Reply #30 on: Jan 19, 2009, 02:28:53 PM »
When I did mine I pulled the axle removed the snap ring then bolted the axle back in. Attached a slide hammer to two lug studs and "hammered" the axle away from the housing. Worked great.
-Jake-
  • Turtle Points: 9
  • Male Posts: 538
  • Member since Oct '09
« Reply #31 on: Mar 02, 2010, 08:10:54 AM »
I also swapped in my Tacoma rear since it was setup for an e-locker.  It desperately needed a wheel bearing and I am poor so no way was I going to take it to a shop.  I made up a SST for myself.
This bolts on to the backing plate
Then you place it in the press and begin pressing on the axle
Red_Runner
  • Turtle Points: 35
  • Member since Dec '03
  • BODY DAMAGE! I love body damage.
« Reply #32 on: Jan 28, 2011, 10:07:51 AM »
you no its funny i built that tool before i got any feed back on this thread and it worked great looks like crap then thought i cant wait tell i have a spar rear end I'm going to cut it up and make me a SST here it is 2 years later and i finally have one to make it
LarryWannamaker
  • Turtle Points: 2
  • Member since Mar '11
« Reply #33 on: Apr 01, 2011, 03:43:18 AM »
Really the easiest is a SST and a12t press (minimum  - barley fits with a DIY SST), then there are the methods described in the previous posts.
helipilot77
  • Turtle Points: 1018
  • Male Posts: 1,725
  • Member since Jul '12
  • Seattle, WA
    • My build thread
« Reply #34 on: Jun 30, 2015, 05:34:40 PM »
Plumbing fittings:
- 2" schedule 40 pipe 20" long threaded on both ends
- 3" floor flange
- 3" x 2" bushing (reducer)
- 2" floor flange
The holes need just a little grinding to line up. I use it in a hydraulic press, but it could just as easily be used with four lengths of all-thread and a a piece of flat stock across the top of the axle.
« Last Edit: Aug 13, 2019, 03:09:08 PM by helipilot77 »
OOPS
  • Turtle Points: 1233
  • Male Posts: 2,561
« Reply #35 on: Jul 07, 2015, 02:53:54 PM »
Nice idea but I do not know if I would trust those cast flanges.
helipilot77
  • Male Posts: 1,725
  • Seattle, WA
    • My build thread
« Reply #36 on: Jul 07, 2015, 07:31:23 PM »
They worked very well. It was really seized in the flange and the whole assembly jumped when the bearing finally came out.
OOPS
  • Male Posts: 2,561
« Reply #37 on: Jul 08, 2015, 07:40:31 PM »
Cool, I made mine out of two flat pieces of .250 steel and a piece of 2.5 DOM. Had a real tight one and bent the plate so I welded a piece of .375 channel on top of it. No more bending.
zippo
  • Turtle Points: 569
  • Male Posts: 1,554
  • Member since Nov '08
    • oppiz.net
« Reply #38 on: Jul 12, 2015, 12:00:25 AM »
I use the slam method!
If you see it, its for sale.
82toyojr
  • Turtle Points: 42
  • Member since Jul '17
« Reply #39 on: Aug 09, 2017, 08:44:29 PM »
I had no problem pressing it off without making any special puller type thing. I just slapped my axle shaft assembly on the press at work. I set it up with the shaft able to slide out but the backing plate on the press cross bars. I put around 1200 lbs of force on before it started to slide out. Make sure to pull the snap ring!!!!!
2G4R
  • Turtle Points: -16
  • Member since Sep '21
« Reply #40 on: Jan 19, 2022, 01:47:01 PM »
chek youtube, dudes doing it using the sidewalk and a 2x4
Last post Jul 31, 2005, 04:31:34 PM
by mudmaster
Last post Apr 22, 2006, 08:40:05 AM
by mt_goat
Last post Aug 14, 2011, 01:25:08 PM
by 93REDCRAWLER
Last post Sep 29, 2013, 07:12:16 PM
by 84Flatbed
Last post May 09, 2013, 03:07:53 PM
by amm9130
