Author Topic: The Official 3RZ Knowledge and Database Thread  (Read 897431 times)
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Member since Oct '06
  • Raised suspension
Does anyone have info on how to make a 4 coil 3rz work with a 22re tach?
jmsdad
  • Turtle Points: -132
  • Male Posts: 201
  • Member since Dec '04
coffee boy
  • Member since Feb '07
3RZ Swap lower radiator hose part number : 16572-0W030
2WD 3RZ T100 hose
I could not find this when I needed it. This looks like a good place for it.
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
  • Member since Oct '07
  • BORN TO WHEEL, FORCED TO WORK...
here is a quick question.... does anybody know if the 2wd t-100 oil pan and pick-up will work on the 2rz??? I know the T-100 comes with the 3rz but I was not sure if the oil pan and all that is the same??? if anyone knows if that will work out I would appreciate the info..... :beer:
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
TacoRunner
  • Male Posts: 2,324
    • 4wheelunderground
I dont know for certain, but I'd guess yes.
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
 :thumbs: ya thats what I was thinkin too... well I will keep my fingers crossed and just try it I guess  :crossed:
www.choptechfab.com
CHECK THE BUILD
808-Yota
  • Member since May '07
Does anyone know if they are motor mounts made by marlin yet??? I read a while back that there was something like a prototype being made.
Nothingface5384
  • Male Posts: 434
  • Member since Mar '06
  • Dun! Dun!! Dun!!!
    • CarDomain
perhaps, but nothing publicly
i love your sig your down to a half of a maverick
73 Maverick(jointly owned w/ lil bro)
64 LeSabre(sold)
82 RX7 (scrapped)
92 Toyota p/u 4x4 (dead) resurrecting underway
72 Skylark (dead) resurrecting underway
87 Grand AM (junked)
79 Regal (sold)
90 Geo Prizm (R.I.P)
E-9
  • Turtle Points: 79
  • Member since Apr '03
  • I love Marlin Crawler!
The T-100 2wd oil pan will fit the 2rz engine. I have one bolted to my 2rz at this moment. I am waiting for the pickup tube to arrive and see no reason it will not work also. I am going to try to use the original dipstick, hope it works.
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
  • Member since Jul '05
E-9, the original dipstick won't work.  You have to use the t100 one and cap off the old dipstick hole with a little aluminum plug.  (a little advise: freeze the plug first or it will just mushroom out when you tap it in)
E-9
  • Turtle Points: 79
Where does the t-100 dipstick go? Does it use the hole in the side of the pan?
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
Nope, that hole in the side of the pan is for a oil level sensor (if it's a large hole you are talking about) - I think I just got a block off plate for that - can't remember  :headscratch:.  The T100 dipstick goes into the block on the driver's side - there should be an aluminum plug to knock out for the hole.  I drilled the motor mount bracket and used it to hold the little mounting tab on the dipstick - pretty easy process really.
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
sweeet man thats good to know i think i will go order my parts today...wooo hooo
www.choptechfab.com
CHECK THE BUILD
oldbluecrawler
  • Member since Mar '08
Hello Everybody, I am new to this forum but have read it for the last year. I have a 1979 4x4 20r that I am trying to convert to a 3rz. I have found a 2002 Tacoma 3rz engine in a wrecked vehicle. What other parts should I request off of this vehicle? Whatever help I can get would be appreciated.
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
oldbluecrawler,  get the bellhousing, clutch fork, clutch slave cylinder, engine wirring harness, evap lines, charcoal canister, intake, ECU, p/s line, this list will still probably go on....
Big Mike will probably be of more help since he has done a couple of 3rz conversions on first gens.
opie
  • Turtle Points: 12
  • Member since Mar '07
Does anyone have a list of what trucks came through with the 3RZ? Has anyone put a 3RZ in a 3rd gen 2wd truck? I am rebuild my 1994 2wd and want to put a 3RZ in it. Does anyone know what transmission my truck might have and would it bolt up to a 3RZ? So any info would be great.
Thanks Opie
BigMike [OP]
  • Administrator
  • Turtle Points: 2124
  • Male Posts: 18,291
  • Member since Apr '02
  • 511:1 Club
I've recently got some rear wheel dyno graphs on the 3RZ-FE and 22R-E engines :circle:
We recently ran a 1986 22R-E, did a 1996 3RZ conversion, and then ran the same truck again on the dyno with the 1996 3RZ.
Here are the results! 1986 22R-E vs. 1996 3RZ-FE
As you can see, the 1996 3RZ makes 41.7 more horsepower and 49.4 more torque at the wheels than the 1986 22R-E, in the same truck.
And the dyno technician said that by reading the torque band of the 3RZ, you can see it build torque, then drop torque, then build torque, then drop torque, etc., and this means that the engine is detonating. He said if we had better fuel in the tank (I believe this fuel is a good 5 or 6 months old and is most likely 87 oct), then it would have put up even more impressive numbers.
Here is Bevin's 2004 3RZ rear wheel dyno graph from his 1984 Shortbed pickup:
Bevin's 2004 3RZ dyno pull is a lot different than the 1996 3RZ. The 2004 Torque band peaked much later than the 1996 Torque band. Marlin and I want to get our 3RZ's tested soon, so having a couple more graphs to compare would certainly be a good thing :thumbs:
Nothingface5384
  • Male Posts: 434
  • Dun! Dun!! Dun!!!
    • CarDomain
that's awsome
time i'm ready for a new engine you guys will be swapping in the vvt version
64 LeSabre(sold)
82 RX7 (scrapped)
79 Regal (sold)
coffee boy
Finally finished my project. I have a couple cosmetic things left and AC things but its smogged, registered and gets over 20MPG.
Engine front
SMOG and fuse box in factory Tacoma positions
MAF and resonators
Side view; E-Locker switches that still need to be mounted
Passenger side view; Still trying to figure out the radio, no speakers, no sound. The Tacoma AC/heater and blower motor are under that dash.
Drivers side view; Tilt wheel works, Speedometer is 2 MPH off with Marlin signal converter.
The only 4-runner wiring left is for the rear window. The rest in all new from the 2000 Tacoma donor.
Exhaust crossover; driveshaft clearance is an issue with the HP 3rd
Front clearance; Electic fan was a must. There was 3" too little room for mechanical.
Rear is tight. Just like I like it. Harness in factory position.
85 4Runner
2000 3RZ
2000 Tacoma dash, wiring harness, AC/Heater system
Front Diamond Axle with 5.29 HP E-locker, Longfield 30's, Kongs Hi Steer,
Rear Tacoma axle with 5.29 E-locker, Front Range Off Road Full Float Axle Kit
Marlin Dual case, Marlin 4.7 gears in rear case
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
So here it is - as promised!!!! The 3RZ wiring notes.
Wiring Harness: 2000 Tacoma 4wd Automatic 3RZ-FE
ECU: 2000 Tacoma 4wd Manual Tranny 3RZ-FE
D7 - OBDII Data link
Pin#, Color, Description
1, None
2, None
3, None
4, W/B, Ground
5, Br., Ground
6, None
7, W.., ECU SIL to E5 Plug pin #19
8, None
9, None
10, None
11, None
12, None
13, None
14, None
15, None
16, V.., OBD Fuse 10A from Battery
E5 - Plugs into ECU
1, None
2, B/Y, Batt, EFI Fuse 20A from Battery
3, V.., A/T Oil Temp (Remove)
4, V/R, Check Engine Light
5, L/O, A/T OD Lamp (Remove)
6, L/B, AC Amplifier (Remove)
7, L/Y, AC Amplifier (Remove)
8, G/O, SP1 to speed sensor in cluster
9, None
10, R/W, 4WD T-case Position (Remove)
11, B/W, STA, 7.5A STA Fuse from Battery
12, W/R, B+ EFI Relay #3
13, R/G, TFN, (T-case neurtal) (Remove)
14, G.., A/T Normal or Power (Remove)
15, V/W, A/T Low (Remove)
16, P.., A/T 2nd (Remove)
17, R/B, A/T Reverse (Remove)
18, R/Y, A/T OD Cruise (Remove)
19, W.., ECU SIL to D7 Plug pin #7
20, None
21, G/W, Stop Light Switch (Remove)
22, B/R, NSW, Neutral Switch, 7.5A STA Fuse
E6 - Plugs into ECU
E7 - Plugs into ECU
E8 - Plug into ECU
1K2 - Junction plug from Motor to Dash Harness
1, G.., A/T OD Switch (Remove)
2, Br., Taco Water Temp Gauge Ground (Remove)
3, Y/R, Water Temp
4, Y/L, Oil Pressure
5, G/Y, COR #4
6, Br., Ground to D7 Plug pin #7
7, B.., Tach
8, B/R, IGN #2
9, W/B, T-case Neutral Shift (Remove)
10, G/R, IDL Cruise (Remove)
11, P/B, Air Bag {LA} (Remove)
12, Y/B, Cruise {TC} (Remove)
13, None
14, R-W, 4wd (Remove)
15, None
16, W/R, COR #2
17, B/W, ST Relay #1 (Remove)
18, B/O, 10A Gauge Fuse, Backup Light Switch Power
19, R/B, To Backup Light or Relay
20, B/R, Ac Clutch or York, OBA
21, None
22, None
23, G/B, ADD (Remove)
24, B/O, A/T Speed Sensor (Remove)
25, L.., A/T Speed Sensor (Remove)
26, G/R, A/T Speed Sensor (Remove)
1K3 - Junction plug from Motor to Dash Harness
1, LG., Cruise (Remove)
2, V/Y, NEW 4WD Indicator Light (was A/T Park)
3, B-W, A/T Park/Neurtal Cruise (Remove)
4, P.., A/T 2nd (Remove)
6, None
7, G/R, A/T Park Light (Remove)
8, B-R, Park/Neutral Switch (Remove)
9, R/G, T-case Neutral (Remove)
10, None
P1 - Use to plug into Taco Auto Tranny
1, Do nothing
2, Do nothing
3, Do nothing
4, R.., Batt power to Tranny Backup switch
5, Do nothing
6, Do nothing
7, V.., T-case 4wd Switch
8, R/B, From Tranny Backup Swicth to Lights or Relay
9, Do nothing
10, Do nothing
Since the donor vehicle in my conversion is for a truck that orignally had a 22RTE (turbo motor), the wiring harness and cluster is different than the standard and very common 22R or 22RE motors, I decided not to list the vehicle connections I made on my vehicle because I'm sure it would cause more confusion than good. Plus since I don't have an actual wiring diagram for the donor truck, I can't label the plugs correctly which would just double the confusion. And please don't email me in the future asking me where I connect such and such a wire - because I'm sure in a month I won't remember...
any idea how much different the harness in a 1996 would be from this one.... I know the 96 is a distributor motor and the 2000 is a twin coil but I am not sure how much of the wiring carrys over??? If anyone has any idea or a list of what wires are needed in the 1996 application I would appreciate the info....
www.choptechfab.com
CHECK THE BUILD
TacoRunner
  • Male Posts: 2,324
    • 4wheelunderground
Coffee Boy: Im very happy for you. You did a great job putting that together. Though I must say Im a little surprised that you did the dash swap. (Glad to someone other than me did it.)   I cant wait to see it.
How did you get a rear sump oil pan to accept a front end dip-stick?
coffee boy
Thanks for the advice you gave me. You were right, it was really a nightmare at times. Totally worth it though.
I just never took out the old dipstick. I just installed the T100 stick on the side and left the other one alone. You can just see it at the bottom of pisture 2.
jmsdad
  • Male Posts: 201
I'm currently putting in a 96 3RZ into my 86 4Runner.  Got most of the wires sorted/labled but have not splice them in yet.  After I bought my 96 EWD manual, I found this link @ TTORA for the 96Tacoma wiring manual.  (Wish I had found it sooner!)
http://www.norcalttora.com/~chris/articles/96_electrical.pdf
I can tell you that the 96 does not have the IK3 connector, but a larger IK1 connector.  Most of the wires are the same color with the same function, but they are in a different spot on the connectors.  I hope this link helps you.
I may be starting on the wiring this weekend, but I still have a lot of small loose ends to take care of.
jmsdad
  • Male Posts: 201
Mine's not running yet, but I didn't bother putting in a T100 dipstick/guide.  I left the tacoma front end dipstick in and with 6qts of oil, it reads fine.  I read somewhere that those who used the front end dipstick with a rear sump T100 pan had to cut a bit off the end.  I didn't cut mine and it goes in fine.
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
thanks a million for that link man that is a life saver.... :biggthumpup:
www.choptechfab.com
CHECK THE BUILD
TacoRunner
  • Male Posts: 2,324
    • 4wheelunderground
Toyota sells the block pluges for that. It about a $5 part. FYI
coffee boy
Yeah, the moron (being me) forgot to do that until the oil pan was on. I have the plug.
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
any idea what the part number is for the block plug?? I better get one in before I put my new oil pan on
www.choptechfab.com
CHECK THE BUILD
davidr34
  • Male Posts: 121
I’m just getting started on mine. I have a 95 t-100 the whole thing I bought off nate  its  going into my 86 runner. jmsdad did you cut and make new engine mounts on your frame or just use the old one. I think I’m just going to cut mine off and make some new ones since i already got rid of the ifs just to clean it up. Thanks for that link I’m going to have to see how much alike the t100 and tacoma are wired that would be seat if that diagram works.
Last post Feb 05, 2017, 10:33:53 AM
by joeyf
Last post Mar 19, 2010, 02:32:29 AM
by Rocksurfer
Last post Jun 27, 2019, 12:06:42 PM
by *FFC*
Last post Jul 31, 2009, 06:34:52 PM
by unclejpl4x4
Last post Mar 29, 2009, 08:34:41 AM
by Rocksurfer
