About equal to a clutch job I would say.. Gotta pull the trans out, remove the nose cone, pop out the old seal, hit the shaft with some sand paper, grease the new seal and install it...............OHH THIS REMINDS ME!! With that Real T/Case output seal we were talking about, MAKE SURE that when ever you install a new seal, from cam to axle seals, that you GREASE THE NEW SEAL! This is important!! Just pack the groove with some grease and then put the seal in place............then put everything back together. You dont have to drain trans or tc oil and in fact dont even separate the tc from the trans. Heck, even keep the crossmember bolted to the tc.Heres some steps to give you an idea, and Im sure i will miss something:1) Disconnect the battery.2) Pull the ebrake or put down some blocks at the tires.3) Shift the trans into 4th and tcase into 4WD high and pull the shifters out from the cab.4) Remove speedocable from t/case and unplug reverse and 4WD light wires.5) Unbolt rear driveline from t/case, and completely remove front drive line. Either mark the slip yokes or be sure that they do not come apart or your drive lines will be out of balance.6) If this is an IFS, it may help to get the sway bar out of the way. That could be a pain later.7) Unbolt starter and let it rest next to the block with wires attached. (that's why we disconnect the battery)8 ) Unbolt clutch slave cylinder and let it hang around. Never undo any fluid pressure lines unless your replacing it.9) Place a tranny jack under the crossmember and remove all 8 frame bolts.10) Unbolt all visible bellhousing to engine bolts. Also check if you still have the exhaust hanger mount and remove that if necessary.11) Lower the entire tcase/trans/engine down a bit with the jack so you can access the two upper 17mm bolts atop the bellhousing with a very long extension and your strongest air gun.12) Now using help from someone else, or try to do it Rambo style and use your feet and apply pressure to the floor jack while your arms shake and pull the transmission off of the clutch disk and lower to your chest. The Trans weighs 100 dry, tcase is 80 dry, and add the crossmember. What ever oil is left is gotta be at least 10 lbs or so. Remember the jack will be supporting alot of the weight and you can handle the rest your self.13) Now set the trans to your side and on the ground and climb out from underneath the rig. Slide the trans/tcase outta there and go to work on it.14) Tilt the whole thing up a bit and rest it against a box or something. This is so the oil will not run out when we remove the nose cone.15) Remove the clutch fork and release bearing. The clip can sometimes be tricky if its your first time so note how it comes off and be sure to put it back on correctly.16) Get yourself a 12mm and remove the bolts to the nose cone and take the nose cone off. Its sometimes sticky from the silicone and a light tap with a soft rubber hammer to the side of the cone where the bearing slides is ok.17) Now carefully use a flat head screw driver and remove the old seal. Be sure not to scratch and scar the input shaft or your screwed.18) Lap some sand paper on the input shaft and put some grease on the new seal and slap it on. Make sure its mounted flat and even all around.19) Now just do everything in reverse order.Some notes on reinstalling:-Make sure when you reseal the nose cone, that the mating surfaces are clean from any oil. Spray some brake or carb cleaner on a clean rag and wipe down the two surfaces before using silicone.-I recommend against Blue and Orange silicone and advise Toyota Black or Super Gray silicone.-After the nose cone is back on, if you are not in the presence of a politician (aka environmentalist) blow out everywhere inside the bellhousing and blow out all the dust from the clutch.-Make sure you regrease the shift fork in three places: Where the ball joint pivots on the fork, and at the end of the two fingers of the fork where it touches the release bearing.-If you have some antiseaze, its a nice idea to apply a meager amount to the splines of the trans input so the clutch disk can move freely.-Remember we shifted the tcase and trans into gear before removing it? well that's because this can sometimes be the nastiest part right here: When you are installing the trans, you've gotta get both the angle correct and the splines to line up for the trans input to clutch disk before it wil install. So get some help, or again if you are he-man, brace the trans with your knee caps, and while one hand is turning the front output flange on the tcase, use your other hand to "gustimate" the correct approach angle of the input and use your knees to support and lift the trans into place. If you are a regular joe like me, then use your brain power and use a couple of floor jacks to get it into place while you turn the flanges to align the splines. It can be a bugger and your arms will turn to spaghetti but dont give up! keep trying or your have to do it all over again with tired arms.I think thats a good summary. Im sure we will get 101 more suggestions but thats a idea of the job. It'll take ya all day if its your first time so plan for a whole day and dont rush it. Take your time and learn how things work. Your be a happier man when its all done BigMike
I just went through that ... same motor ... 94 V6....The downey super clutch is only for the I4, the V6 is a little weak on options...A few things to consider:- Do NOT go over 1600 lbs pressure plate. It will destroy your crank bearings (large issue) and slave cyl (small issue). If just the leverage is offset and the pedal pressure is 1600 lbs but actual clamp load is 2500 lbs , then it will still destroy your bearings.- Get a quality pressure plate, like Exedy- I was looking into the marlin ceramic clutch. it looks good but I couldnt find out how it engages ... ceramic is often either IN or OUT. Thats not what you want for rock crawling or trailer maneuvering.- I ended up getting a Southbend Clutch Kevlar disc with Exedy 1600 lbs pressure plate. Havent installed it yet (long story).
1st. why on earth would you want more than 1600lb clutch and for the life of me i cant figure how that would have any effect on crankshaft main bearings 2nd. i have marlins 1200 NON ceramic, and its got right at 30,000 miles on it , when i had it out back in the summer, it showed no signs of wear, after 30,000 miles, i tow, i race, i drive it like a stole it, and now visible signs of wear3rd, how much did the exedy1600 and southbend clutch cost ya ??my marlin 1200 kit was $180 i think
I am saying that you do NOT want more than a 1600 lbs pressure plate. Read my post. The effect on the crank bearing is that it prevents oil to go to onw of the bearings, thus killing it. I could only find one reference to it and forgot the exact technical details. Be assured its true that over 1600 lbs will be bad for your crank bearings. Thats for the 3VZE.What motor are you running ? 22RE? 1200 is fine for that as is 1600 for the 3VZE.The Exedy kevlar setup was aorund $300 .. am happy to pay $100 more to have a lasting clutch. Organic OEM has worked for me but it was just time to try something new....Matt
But be my guest and install the 2500 lbs pressure plate if you wish.Matt
are the bearings in the Marlin Kit any good? i have heard they were cheap aftermarket and i have heard they are OEM Toyota. can anyone clerify?
that's what i thought, and also why i ordered from Marlin in the first place. i will be continuing my clutch install tomarrow.
Started by 84runner « 1 2 3 » Chit Chat Camp
Started by MidgetMike General 4WD Discussion
Started by BUBBA « 1 2 3 4 » Chit Chat Camp
Started by DAWGTOY Engine
Started by KYOTA Toyota Pickup/4Runner Tech 1979-95
