Author Topic: Marlin's SM420 to toyota tcase adapter for JEEPS!!  (Read 3903 times)
Brandon
  • Hawk
  • Turtle Points: 193
  • I believe in Life before Death
    • www.RiverCityRockCrawlers.com
« on: Oct 21, 2005, 10:43:12 AM »
Ok, that wasn't the intention but it sure works well..
http://rcrc4x4.com/mambo/index.php?option=com_content&task=view&id=67&Itemid=69
« Last Edit: Nov 01, 2005, 12:10:57 PM by Brandon »
Brandon Miller
RCRC, Sacramento, CA
RockSlayer
  • Turtle Points: 176
  • Male Posts: 101
  • Member since Jan '06
  • A mind is a terrible thing to taste.
    • Cal4wheelers
I was going to use an NP465 and a NP205 that I have, and stuff a Klune V in between, but since I saw your rig, I am totally rethinking the possibilities. :rockingout: Shorter, lower ratios, less weight. I'll be putting all this behind a 235 hp 4.3l, so it should hold up just fine. I have an SM420 and a Toyota t-case already too.
So, how do you like it? Would you change anything? :doh:
I ask because there is a guy around here with a buggy called "Digger". He's running the NP465/Klune-V/NP205 set up that I was planning on running. And he says he wouldn't change a thing. And he has a 502 CID Chevy crate motor running on propane in front of that. :booya:
Brandon [OP]
  • Hawk
if I were running a big block it might not be so great ;)
but, with all the yota stuff you can't go wrong with this setup..
With that said I did sell the jeep (more like gave it away :( ). I don't know anything about the kluneV 205 stuff so I can't speak for that but I might be looking into it since I have yet to find an adapter for the C6 in my latest rig..
Brandon Miller
RockSlayer
  • Male Posts: 101
    • Cal4wheelers
I guess the question would be, would you run the toybox again if you could? :confused:
Brandon [OP]
  • Hawk
well I never ran the toybox..
the toybox is the reduction box - all I ran was the adapter. I guess I ran a version of it but yea - definately. It was a slick setup!
Brandon Miller
Last post May 21, 2003, 03:45:15 AM
by Brandon
Last post Aug 03, 2002, 08:01:17 AM
by yota83
Last post Sep 03, 2005, 08:53:07 AM
by KYOTA
Last post Sep 25, 2010, 03:04:45 PM
by chardo
Last post Dec 30, 2009, 09:16:41 AM
by ROCK CRUSHER
