Author Topic: TECH: How I built my square driveshaft  (Read 71945 times)
MiniSimp
  • Outdoor Enthusiast
  • Turtle Points: 5
  • Male Posts: 5,119
  • Member since Jan '05
  • SimpsonBrothers.net
« on: Sep 14, 2005, 01:04:44 PM »
This Thread is Featured in our Tech from our Forum Members section!
This is also a permanant "How to" on ehow.com http://www.ehow.com/how_4475628_build-square-driveshaft.html
So, because of my "Rears up front" suspension, I needed a longer front driveshaft that had more travel in it.
The affordable answer: Square driveshaft
I'm not worried about the driveshaft being ballanced, because I won't be driving very fast in 4wd.
What you need:
1: Toyota front driveshaft
2: 2"x2"x0.25" square tube (slides into the 2.5" tube)
3: 2.5"X2.5"X0.25" receiver hitch tube (no seam inside)
4: Grinder
5: Portaband saw (helpful, but not necessary)
6: Flat file
7: Welder
Here is how it was built:
Start with one front driveshaft
Seperate it
Clean off what grease you can
Cut off the shaft approx. 3/4" from the yoke
Clean out the shavings
Cut a slice off the 2"x2"x0.25" tubing to trace out the square
Don't try to use paint to mark the square, it doesn't work. Use a thin black marker.
I used a cutting wheel to grind off the edges so it would be flatter
The 2" tube will have a weld line raised in the tube, you must file this down.
Line it up and weld it to the tube
One side done
Next do the Double Cardan side, cut approx 1/2"
The DC end will be 2.5"x2.5"x0.25" Receiver hitch tubing (no seam inside)
Again, cut a slice off to trace your square
File down any burs
Trace out your square
I used a portaband saw to cut this one, there was a lot more material to cut off, grinding would have taken forever. Then I used a grinder to clean it up.
Square cut out
The slice slides over it perfect
Slide it in the tube
Line it up and tack it in place
Finish weld it
Now you have a square driveshaft.
« Last Edit: Jun 18, 2014, 04:40:01 PM by BigMike »
Volcom
  • Turtle Points: 269
  • Male Posts: 2,394
  • Member since Sep '04
  • Colorado Rocks!
    • http://www.rockfrogs.org
Re: TECH: How I built my square driveshaft
« Reply #1 on: Sep 14, 2005, 01:45:29 PM »
Nice writeup!  Thanks!
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
  • Momentum Man
  • Turtle Points: 433
  • Male Posts: 13,800
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #2 on: Sep 14, 2005, 02:10:07 PM »
You didn't mention that the 2 pieces slide together and are not welded to each other. I had to re-read the buildup to figure that out. Wouldn't want someone to just take a single piece and weld the ends to it. :shocking:
:ninja: The Ninja
R.I.P. Paul Acosta: In work, In play, In life, a friend forever
Skinny_Pedal
  • Turtle Points: 89
  • Male Posts: 2,833
  • Member since Apr '04
  • work so I can support my lifestyle
« Reply #3 on: Sep 14, 2005, 06:31:22 PM »
 me> :slap: <rocksurfer      :shake:
Im an OG
  • Momentum Man
  • Lego Enforcement
« Reply #4 on: Sep 14, 2005, 06:38:01 PM »
I know, I know, but if you skim-read you miss that little unwritten part that there are 2 pieces of square tube, and you are welding them seperatly. Then there is no indication or full picture (I love pictures) of the finished shaft. I went whoa, wait a minute and re-read it and saw that there were 2 pieces. :qtip:
:ninja: The Ninja
Skinny_Pedal
  • Turtle Points: 89
  • Male Posts: 2,833
« Reply #5 on: Sep 14, 2005, 06:40:15 PM »
but he showed two different pieces of tube. its ok old age is catching up :rofl2: . i bet your thinking punk kids rights? :rofl:
Im an OG
  • Momentum Man
  • Lego Enforcement
« Reply #6 on: Sep 14, 2005, 06:46:24 PM »
Naw it's ok, I'll just laugh my  :moon: off when some kid reads it wrong like I did at first and just goes out and makes it out of a single piece and then jumps it or something. :shocking:
:ninja: The Ninja
  • Turtle Points: 1019
  • Male Posts: 9,720
  • Member since Oct '04
« Reply #7 on: Sep 14, 2005, 07:09:55 PM »
Minisimp, I love your new avatar but can only imagine it's only a matter of time...........
Yota4life
  • Turtle Points: -128
  • Male Posts: 1,461
  • Member since Nov '04
« Reply #8 on: Sep 14, 2005, 08:23:18 PM »
this is a great qrite up, i will be doing the same thing soon to increase my amount of slip
Shamb
  • Raisin in the making..
  • Turtle Points: 133
  • Male Posts: 3,413
  • Proud Parent
« Reply #9 on: Sep 14, 2005, 08:58:09 PM »
Made two of these this last weekend  :)
great write up for anyone who needs to build one and doesn't know how.
Good stuff.
I should probably make a writeup of my half doors but i'm to lazy   :D
Makman
  • Male Posts: 98
  • Member since Apr '05
« Reply #10 on: Sep 14, 2005, 09:21:15 PM »
Well written.  If you're at risk of making a one piece "long-travel" driveshaft, you probably need to learn that lesson the hard way.   :headscratch:
Another reference for similar tech over at PBB... http://www.pirate4x4.com/forum/showthread.php?t=90517
If it never breaks, people can only speculate how much it was overbuilt.
CTENG in KS
  • Turtle Points: -501
  • Male Posts: 4,295
  • Member since Jun '04
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #11 on: Sep 14, 2005, 11:42:00 PM »
That's HOT!...Mini, you are becoming a regular toyowhitetrash guru.  WELL DONE!
alwayzbroken
  • Turtle Points: 603
  • Male Posts: 1,905
  • Member since Feb '05
« Reply #12 on: Sep 21, 2005, 08:26:06 PM »
MiniSimp, how much does receiver tubing cost per foot? What are the lengths of the two tubes? Thanks.
MiniSimp [OP]
  • Turtle Points: 5
  • Male Posts: 5,119
« Reply #13 on: Sep 21, 2005, 08:45:54 PM »
It cost me $30 from a welding shop that I deal with all the time, so I can't really tell you what reality cost is.
I got 2 lengths of 36" because I figure if I have enough left over I might be able to make another one for a spare.
speedemon
  • Turtle Points: 13
  • Male Posts: 267
  • Member since Nov '05
  • When's winter?
« Reply #14 on: Dec 10, 2005, 09:38:16 PM »
i can get ten feet for about $15 (new) from this steel salvage company i get my metal from but other places i've called have quoted me 40 for the same shirt.  call around.  look in yellow pages under "steel" or "salvage".
2002 Tacoma sold
'84 pickup SOLD!!
'83 pickup will rise again
'86 sas runner DD
'89 runner project (for sale)
F-Toy build in progress
mudaddict
  • Turtle Points: -83
  • Male Posts: 1,829
  • Member since Dec '04
    • All Pro Off Road
« Reply #15 on: Dec 13, 2005, 08:32:14 PM »
i got 3 feet of each for 30 bucks from a place up the street that i found
I work At
All Pro Off Road
notajeep
  • Turtle Points: -108
  • Male Posts: 703
  • Crawler #3289
« Reply #16 on: Dec 14, 2005, 04:52:45 PM »
What do you need a spare for??? I did this mod last year and you can sit the whole truck right on it and it just scratches. :driving:
hi on lux
  • Male Posts: 208
  • Member since Jul '06
« Reply #17 on: May 12, 2007, 09:46:58 PM »
may i know what lenght did you used for the 2.5"? 2"?
btw isn't it supposed to be 0.25" or 1/4" and not .025" tube wall thickness ?
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,648
  • Member since Aug '04
  • I used to fit
« Reply #18 on: May 12, 2007, 09:55:54 PM »
It all depends on what the length is from your t-case flange to the pinion flange.  When I built mine, I bought 2' of each peice of tubing, I think I wound up using 15-18" of each one :dunno:  I don't remember for sure.  You just need to make sure the the smaller tubing isn't going to bottom out when your suspension compresses, or drops out when the suspension droops.
:psss: and yes, it is supposed to be 1/4" wall :thumbs:
              -Ronald Reagan
83yota
  • Turtle Points: 345
  • Member since Mar '04
  • rollin my nike's
« Reply #19 on: May 12, 2007, 09:59:33 PM »
ok call me stupid but you do grease it right when you put it together? maybe a dry lube. just asking for me i have ALWAYS had my drive shafts built for me and i would like to build one
MiniSimp [OP]
  • Turtle Points: 5
  • Male Posts: 5,119
« Reply #20 on: May 12, 2007, 10:03:40 PM »
MiniSimp [OP]
  • Turtle Points: 5
  • Male Posts: 5,119
« Reply #21 on: May 12, 2007, 10:05:18 PM »
Didn't grease mine. There is too much play in these shafts for grease to matter.
83yota
  • rollin my nike's
« Reply #22 on: May 12, 2007, 10:07:49 PM »
cool how much noise is there when you first let out the clutch? is there alot of noise when your rolling down the road? how about when you hit a bump? sorry about the ?s i am just tring to figure this out before i do it :headscratch: :dunno:
MiniSimp [OP]
  • Turtle Points: 5
  • Male Posts: 5,119
« Reply #23 on: May 12, 2007, 10:09:06 PM »
Only time I hear noise is when the hubs are locked and I'm in 2WD (rotational clicking). Other than that, not a peep.
83yota
  • rollin my nike's
« Reply #24 on: May 12, 2007, 10:18:17 PM »
cool sounds like a good deal
tom w.
  • Male Posts: 760
« Reply #25 on: May 12, 2007, 10:44:03 PM »
mine clicks at idle sometimes... other than that i never hear it.
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,648
  • I used to fit
« Reply #26 on: May 12, 2007, 10:52:37 PM »
the only noise that is noticable is in 2wd with the hubs locked.   Sometimes when you atart off it'll clank pretty loud one time, as it takes up the slop, but then it is silent while under load.  Following these directions, I recently found that 60mph is doable with no vibes as long as the truck is under load, and not coasting.  :thumbs:  I wouldn't bother using grease, it wouldn't help any.
              -Ronald Reagan
83yota
  • rollin my nike's
« Reply #27 on: May 12, 2007, 11:40:37 PM »
how about beveling the edges of the inner tube
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,648
  • I used to fit
« Reply #28 on: May 13, 2007, 12:11:47 AM »
:dunno:  why would you?  You want it to fit as tightly as possible, which is why Minisimp used those two tubes.  The outer dimensions of the small one are not much smaller than the inner dimensions of the bigger one, allowing for very little slop.  I don't see a point to beveling the edges, and if you beveled to much, you could wind up having the smaller shaft spinning inside the bigger shaft :dunno:  unlikely you'd bevel that much, but I just don't see a point :thumbs:
              -Ronald Reagan
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
« Reply #29 on: May 13, 2007, 01:34:00 AM »
Damn, how did I never see this thread before  Probably cause i searched "square drive line".   good Job Mini :thumbs:   even though it's two years late.   :hammerhead:
I like to Drive!
Last post Aug 01, 2005, 08:14:49 PM
by toymachine
Last post Sep 10, 2005, 11:41:35 PM
by Skinny_Pedal
Last post Oct 27, 2005, 06:10:37 PM
by Rocksurfer
Last post Sep 21, 2005, 02:46:13 AM
by guywithuglyyota
Last post Jun 25, 2006, 03:07:02 PM
by RustyToy
