Where does it say that the timing should be 12 degrees advanced? If I remember correctly on my 84 I ran the stock 5 degrees of advance, then with the idle advance hooked up to the distributor it went to 12. The actual distributor timing should be 5 degrees though. I ran a weber on that truck and ran midgrade.It looks like I don't have the paper with the custom weber jet sizes on it either.
Is it the 32/36 Weber? My runs great with it on regular (lowest grade) fuel. Is it adjusted properly? If not try this site: redlineweber.com It's what I used and I've had no problems for the last 4 years.
I got my used so I don't know what jets are in it. I thought there were 2 adjustment screws? It's been a while though. Good luck
79-82 - 8* BTDC @ 950 RPM vac adv off83 - 5* BTDC @ 950 RPM vac adv off85 22R - 0*BTDC @ 950 RPM vac adv off85 22R-E 5* BTDC w/terminal T grounded
btdc=before top dead centerI ran a used weber as well, and the guy I bought it from helped me rebuild it and jet it. I couldn't tell you what the jetting is though. They do sell a weber carb that is pre jetted for toyota 22r's, so go searching for that info. To find out the jet size I believe you'd have to get into the carb and look on the actual jets.There should be both an idle speed and an idle mixture adjustment.
if it helps i live at 4800' ele. and use .115 main jet runs great i got jets from CARBS UNLIMITED 1800-994-CARB good luck!
Impressive reply...over 3 years after the previous post! That truck has been parted out.
bd is getting sassy of late!!
Started by blackdiamond General 4WD Discussion
Started by 1985ToyotaForLife Engine
Started by Zoomschwortz Toyota Pickup/4Runner Tech 1979-95
Started by 89toy « 1 2 3 4 » Toyota Pickup/4Runner Tech 1979-95
Started by Yota-Freak Newbie Questions
