As for the Ultimate setup, if you are unsure, then just go with a reg. dual setup for now, and later if you desire to be slower, then drop in a gear set-
BTT - Also, did the V6 adapter leak get solved? (internal leak from trans to t-case that is - ATF mixing with gear oil)
Started by surlynkid Project Research and Build-Ups
Started by buddha Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by coyote4u Engine
Started by Motorrad Toyota Pickup/4Runner Tech 1979-95
Started by toyotawheeler Toyota Pickup/4Runner Tech 1979-95
