As for my Project, sadly, my girlfriend will be leaving to return back home in Japan for at least a YEAR!!!!!!!!!!!!!!!!!!!!!!!!!!!! LEJW KJ WEKJR WIHF SH WHR LJK#$Y RTI#$JH@$KL%^J#$K^J $ WHAT AM I GOING TO DO!!!!!! Her flight leaves in the first week of July, so I have between then and now to spend every second and every breath with her before she leaves ,BigMike with BigPlans
Looking forward to seeing it, what type of paintjob you looking at? I like the looks of the one you got now
This is the highly sought after Twin V Compressor that I talked about back in my 1st Project threadThis compressor was taken off of a 1973 Chrysler Newport boat car. According to legend, this compressor is capable of inflating 35" tires using a small 3 gallon air tank while the compressor is CYCLING on and off. It can actually out compress the inflation of the tire!! Even with such a small reserve tank.
YES! That's Awesome! Thanks for the info!!
Kenworth is #KA1480
DOH! Hold the phone!!That was the wrong part number.. The right number is KA1480
DOH! Hold the phone!!That was the wrong part number.. The right number is KA1480If you go this route take some pictures of what you decide to do in regards to the magnetic coil. I ended up using the RV2 coil and not the kenworth/york coil but I believe the york one is probably stronger. Not sure that it’s absolutely necessary but bigger/stronger is better right??
.........Hey those are the same numbers, so is that the one I need?Thanks
Summer Projects Include, but not limited to:....Convert my cab into a 1st Gen Extra Cab.....
Hey that guy .....
Started by BigMike « 1 2 ... 38 39 » Project Research and Build-Ups
Started by 6.72:1 Rig Gallery
Started by ZukIzzy Chit Chat Camp
Started by 82rustbeast « 1 2 » Project Research and Build-Ups
