"These dusty roads ain't streets of goldBut I'm a happy right where I'm at"
Marlin is like the Chuck Norris of the rock crawling world.
Thought this might be useful to someone but I went to the dump today... my sas'd 93 runner with 36x12.5 and a full tank of gas weighs 4200lb
Oh whoops, I think it's 0.8 quarts for a Crawl Box. So about 2.5 for a complete Dual Case.
will it even out in side the cases??
It is 121.5", the same as 3rd gen X-cabs.
Automatic tranny/transfer case gear ratios? Pretty please
A340H(most likely what you are looking for)(Gear ratios 1st-2.80, 2nd-1.53, 3rd-1.00, 4th-0.71, Rev.-2.39)These have an integrated chain driven transfer case that gives a 2.66:1 gear reduction in 4lo.
http://www.marlincrawler.com/tech/transmission/transmission-gear-ratio-charthttp://en.wikipedia.org/wiki/Toyota_A_transmission#A3xxA340H(most likely what you are looking for)(Gear ratios 1st-2.80, 2nd-1.53, 3rd-1.00, 4th-0.71, Rev.-2.39)These have an integrated chain driven transfer case that gives a 2.56:1 gear reduction in 4lo.
Toyota Leaf Springs Flat length Front Half Rear Half Width SOA / SUA 80-85 Toyota front 45" 22.5" 22.5" 2.36" SOA 80-85 Rancho 3" Toyota front 45.12" 22.56" 22.56" 2.36" SOA SkyJacker 5" Toyota front 46" 23" 23" 2.36" SOA 80-88 Toy rear 48" 20.5" 27.5" 2.36" SOA 80-88 4" SkyJacker Rear 49" 21" 28" 2.36" SOA 80-88 5" SkyJacker Rear 49.5" 21.25" 28.25" 2.36" SOA 89-95 Toy Rear 51" 21.5" 29.5" 2.36" SOA Source: DRM
Incorrect Sir.The Autos with an integrated case.... have a 2.66:1
Good catch!In the quote I used, he states 2.56, but then states 2.66 later in the post.I have fixed the screw up.
idk if this is a common sense question, but since the wheel base on the xtra cab and longbeds have a longer wheel base does that mean both the front and rear driveshafts are longer? i wanted longer driveshafts and if i can get one from a long bed or xtra cab that would save me some money.
Started by CRS Project Research and Build-Ups
Started by rauern General 4WD Discussion
Started by peacesells Tire and Wheel Tech
Started by Bambino840 Transfer Case/Drive Line
Started by idahank 1979-1983: How-To Guides
