i belive there 18 mm
1985 Truck(LWB/SWB)/4Runner Chassis Dimensions
I cant find it.... whats the fluid capacity of a 3VZ-E Power Steering System?
Gas Tank Capacities?
"These dusty roads ain't streets of goldBut I'm a happy right where I'm at"
Marlin is like the Chuck Norris of the rock crawling world.
Inner Axle Lengths please?Hilux, Short Side:Hilux/FJ60, Long Side:FJ40/FJ60, Short Side:FJ40, Long Side:& Whats the Inside diameter of a toyota solid front axle?
does anyone know the weight of an 82 longbed?
my owner's manual for my 89 (1st gen) 4Runner says the gas tank holds 17.7 gal
Oh whoops, I think it's 0.8 quarts for a Crawl Box. So about 2.5 for a complete Dual Case.
other facts from the 1989 Toyota 4RUNNER Owner's manualDIMENSIONS AND WEIGHT in. (mm) overall length 174.8 (4440)overall width 66.5 (1690)overall height 66.1 (1680)wheelbase 103.3 (2625)front tread 56.3 (1430)rear tread 55.5 (1410)cargo weight lbs. (kg)rating 300 140 *vehicles with rear seats sold outside Canada 440 200 *vehicles with rear seats sold in Canada 700 320 *vehicles without rear seatsENGINEdisplacement, cu.in (cc) 22R-EC 144.4 (2366) 3VZ-E 180.5 (2958)valve clearance, in (mm) 22r-ec engine (engine hot) intake 0.008 (0.20) exhaust 0.012 (0.30) 3VZ-E engine (engine cold) intake 0.007-0.011 (0.18-0.28 ) exhaust 0.009-0.013 (0.22-0.32 ) Spark plug gap: 0.031in (0.8mm)ENGINE LUBRICATIONOil capacity, qt. (liter) 22R-EC engine Dry fill 5.1 (4.8 ) Drain and refill with filter 4.5 (4.3 ) Drain and refill without filter 4.0 (3.8 ) 3VZ-E engine Dry fill 5.6 (5.3 ) Drain and refill with filter 4.8 (4.5 ) Drain and refill without filter 4.4 (4.2 )MANUAL TRANSMISSIONOil capacity, qt. (liter) 3.2 (3.0)Oil type: multipurpose gear oil API GL-4 or GL-5Recommended oil viscosity:22R-EC engine SAE 75W-90 or 80W-903VZ-E engine SAE 75W-90AUTOMATIC TRANSMISSIONFluid capacity, qt. (liter) Dry fill 10.9 (10.3) Drain and refill Up to 4.8 (4.5)Fluid type: automatic transmission fluid DEXRON-IITRANSFER(vehicles with manual transmissions)Oil capacity, qt. (liter) 22R-EC engine 1.7 (1.6) 3VZ-E engine 1.2 (1.1)Oil type: Multipurpose gear oil API GL-4 or GL-5Recommended oil viscosity:22R-EC engine SAE 75W-90 or 80W-903VZ-E engine SAE 75W-90TRANSFER(vehicles with automatic transmissions)Oil capacity, qt. (liter) Dry fill 1.2 (1.1 ) Drain and refill 0.8 (0.8 )Fluid type: automatic transmission fluid DEXRON-IIDIFFERENTIALOil capacity, qt. (liter) front 1.7 (1.6 ) rear 2.3 (2.2 )Oil type: hypoid gear oil API GL-5 Above 0 degrees F (-18 degrees C) SAE90 Below 0 degrees F (-18 degrees C) SAE 80W or 80W-90COOLING SYSTEMTotal capacity, qt. (liter) 22R-EC engine with manual trans. 8.9 (8.4) with auto trans. 9.6 (9.1) 3VZ-E engine with manual trans. 11.1 (10.5) with auto trans. 10.9 (10.3)coolant type: Ethylene-glycol coolant (do not use alcohol type.)TIRES AND WHEELSTire size: 225/75R15Recommended cold tire inflation pressure: Front 26 psi (180 kPa) Rear 29 psi (200 kPa) for sustained high speeds above 75 mph (120 km/h), in countries where such speeds are permitted by law, add 3 psi (0.2kg/cm2,20 kPa), but never exceed the maximum cold tire pressure molded on the tire sidewallWheel size: Steel wheels 15 x 6JJ 6-JJ x 15 Aluminum wheels 15 x 7JJ 7-JJ x 15Wheel nut torque, 76 ft-lb (103 N.m)
Am I a dumbass? I put 4 rts in duals and 4 in my w56a? What's correct?
does your drivetrain even rotate?
Then ur good.Sent from the HO KID network using Tapatalk 2
TURBO, nice man
Started by CRS Project Research and Build-Ups
Started by rauern General 4WD Discussion
Started by superbutta808 Toyota Pickup/4Runner Tech 1979-95
Started by muddyblzr General 4WD Discussion
Started by peacesells Tire and Wheel Tech
