4 teeth, Man I can't believe that.. I would think it would for sure tap the valves that far off
I have a rebuilt 22re with EB head, CAM, and doug thorley header. Just put a new cat on, oil an filter, air filter, sparkplugs, 91oct, and retarted the timming 2 degrees. does that all sound sufficiant enouph to pass smog? I havent tried to smog it in 2 years so i dont really know what to expect. Could the CAM really throw it off?
depending on how big your cam is, you bet! if its loping, they probably wont even put the sniffer in it. does your header have a CARB number on it somewhere? they will also be looking for that.
if the header has a CARB stamp on it, there is no need for paperwork, the guy is giving you a hard time. as for the cam, if its idleing smooth, you should pass with no problem. i know california passed a law jan. 09 that called for a different cat, which makes just about every cat not abide by the new law, but if the cat was on there before the law passed, they can't say anything. don't tell them you just put a new cat on. i have some friends in sac and roseville area, i'll see if i can get a recomendation on a shop.
Started by SLIVER Engine
Started by Redcheetah Toyota Pickup/4Runner Tech 1979-95
Started by Serenity now! Toyota Pickup/4Runner Tech 1979-95
Started by Caboose Parts Wanted
Started by 1980firstgen20r 1979-1983: How-To Guides
