Author Topic: How to Pass Smog  (Read 180676 times)
Goose
  • Turtle Points: 73
  • Male Posts: 1,029
  • Member since Mar '07
  • >>Goose maN<<
Re: How to Pass Smog
« Reply #150 on: Feb 05, 2008, 10:05:11 PM »
This is why I just go out and get the $30 Bosch one at my local mom and pop auto parts store.   :yesnod:
Ive heard the universal bosch's are a big no-no...
I guess they dont read right for toyotas like the oem ones do or somthing...
idk, ill have to look it up. Theyre way cheaper but i heard theyre bad...
Baller Status: Coming Soon To A Toyota Near You!...   :afro:
My Life Is A Very Complicated Drinking Game... -Me
90 ext. cab v6, SAS'd, 37's
94 4runner -work in progress
www.slagfactory.com
My Buildups:
'90 ext. cab
http://board.marlincrawler.com/index.php?topic=38260.new#new
'94 4Runner
http://board.marlincrawler.com/index.php?topic=53882.new#new
emsvitil
  • Turtle Points: 5150
  • Male Posts: 3,280
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #151 on: Feb 05, 2008, 11:26:14 PM »
I'm using a Bosch with no problems
I did however upgrade it to a heated 3-wire...........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
drabnor
  • Male Posts: 30
  • Member since Nov '07
« Reply #152 on: Feb 06, 2008, 11:41:15 AM »
Hey guys, I could use a bit of help with my '86 22rte 4runner, my first 22r series yota. It failed a pretest yesterday. First thing that surprised me was the timing, with the terminals shorted its at 15 * BTDC, unshorted its about 22* advanced :yikes: So I figure thats my first thing to do is to time it correct. Heres the #s it got:
test ------ rpm --- HC max --- HC measured --- CO max --- CO measured --- NO max --- NO measured
15mph --- 1761 --- 131 ---------- 67 ---------- .87 ---------- 0.00 -------- 1085 ------ 1868(fail)
25mph --- 1727 --- 103 ---------- 52 --- ------1.10 ---------- 0.00 -------- 1120 ------ 1933(fail)
notice the complete lack of CO and the high NO... would the timing so far out of whack cause the high NO?
its got new plugs/wires, i seafoamed it about 500 miles ago, running 87 octane.
it also failed CA's new evap system test so i plan to replace all the hoses in the system.
tia for the help!
86 4runner
00 Tacoma
Goose
  • Turtle Points: 73
  • Male Posts: 1,029
  • >>Goose maN<<
« Reply #153 on: Feb 06, 2008, 02:06:40 PM »
details on that  :bull crap: ??
Hows the sea foam work for you?
I usually dump some propynal alcohol (Spelling?) in a fresh tank every few months... cleans the valves and what not nicely..
How old is the cat?
www.slagfactory.com
My Buildups:
'90 ext. cab
'94 4Runner
drabnor
  • Male Posts: 30
« Reply #154 on: Feb 06, 2008, 02:36:18 PM »
details on that  :bull:pokinit:: ??
How old is the cat?
its a new test they just started doing on the 1st of Jan, pressure tests the entire evap system, if it doesn't hold x pressure for x time you fail
seafoam worked great, suck it into the throttle body and it cleans the intake tract/combustion chamber of carbon, also put it in the gas to clean the injectors
unsure of the cat's age, its prob original as well as the o2 sensor...
i plan on changing the o2 just to be sure. something is making it run lean, very lean ~15.7 a/f ratio
86 4runner
00 Tacoma
emsvitil
  • Male Posts: 3,280
    • emsvitil's album
    • Buy me a soda
« Reply #155 on: Feb 06, 2008, 05:36:50 PM »
NOx goes up with advanced timing.    Back off the timing to 2-3 degrees BTDC (spec is 5 BTDC  and you're allowed +- 3)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Goose
  • Turtle Points: 73
  • Male Posts: 1,029
  • >>Goose maN<<
« Reply #156 on: Feb 06, 2008, 07:35:40 PM »
Id definetly replace the cat.
Sometimes a brand new Nice n hot cat can burn off.. or hold back, alot of nasty stuff.
The o2 sensors are spendy, but well worth it.
Espesially if its running lean like that..
14.7's perfect right?
www.slagfactory.com
My Buildups:
'90 ext. cab
'94 4Runner
drabnor
  • Male Posts: 30
« Reply #157 on: Feb 07, 2008, 12:49:36 PM »
Thank you! I'll give it a shot and see what happens...
86 4runner
00 Tacoma
Plekto
  • Turtle Points: 27
  • Male Posts: 862
  • Member since Aug '07
« Reply #158 on: Feb 12, 2008, 05:05:46 PM »
I think for a 22RE, they are fine if you get the right one.  It was the only one listed in the computer and the item looks identical to the OEM as well.
Other types that plug in near the cat are a whole other story, you're right.  All I know is I passed smog, if barely.  NOx is O2 sensor most likely of if you're running stock exhaust, look for leaks and cracks near the sensor.(also cat, but O2 is usually much cheaper and you're not far off.
superyota
  • Prestige Worldwide
  • Turtle Points: 3
  • Male Posts: 3,350
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
« Reply #159 on: Feb 20, 2008, 09:39:41 AM »
any idea if the smog year will ever change again?
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
Plekto
  • Turtle Points: 27
  • Male Posts: 862
« Reply #160 on: Feb 21, 2008, 05:00:26 PM »
Whenever Feinstein and Boxer leave office.  They hate diesels and old cars with a passion.
P.S. The real reason they sued the EPA for stricter limits was because they want to keep the Mercedes bluetec and other similar lean burning diesels out of California.  It doesn't matter to them if you could suck off of the pipe and get cleaner air than by opening the window - they are on a mission to get rid of every last one.
Thankfully the EPA kicked them in the shins.
  • Turtle Points: 1019
  • Male Posts: 9,719
  • Member since Oct '04
« Reply #161 on: Feb 21, 2008, 05:32:37 PM »
Doubtfull, they're already up to years that started to have a decent amount of smog control crap.
Orowheeler
  • Male Posts: 29
  • Member since Feb '08
  • yeah
« Reply #162 on: Feb 21, 2008, 08:53:46 PM »
my 22re is completely rebuilt and i didn't pass smog because of my o2 sensor i from a pick and pull. so it is worth spending 100 bucks for a brand new one.
davidr34
  • Male Posts: 121
« Reply #163 on: Mar 10, 2008, 01:32:56 PM »
to get the hc down, retard the timing correct? And can anyone send me some pics of where the 2 hoses go from the a/c line? ive look at the diagram i just can figure it out. thanks
fordh8r
  • Turtle Points: 808
  • Male Posts: 2,581
  • Member since Jan '07
  • when my toyota grows up it'll be just like my chevy!
« Reply #164 on: Mar 10, 2008, 03:34:26 PM »
:yesnod:  BUT! You can't be more than +/- 2 degrees from the spec.
emsvitil
  • Male Posts: 3,280
    • emsvitil's album
    • Buy me a soda
« Reply #165 on: Mar 10, 2008, 03:43:32 PM »
You retard for high NOx.
HC & CO are the opposite, so I think you advance a little
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Misfit4Runner
  • Male Posts: 313
  • Member since Jul '07
  • This line intentionally left blank
« Reply #166 on: Apr 17, 2008, 03:49:20 PM »
well i tried to get my runner 3.4 smogged and blew over 200 points on my NO at 15mph. so i sprayed a half can of STP choke and carb cleaner (sensor safe) in the carb and a pint of rubbing alchol in the tank and knock off my air cleaner. 20 min later I passed 293 out 512 at 15mph and 222 out of 765 at 25. im not sure if guy at the 1st place was a complete yahoo or the carb cleaning and alchol was what did it. I was gonna change the oil but after 120 on smog tests I said to hell with it.
If you dont stand behind our troops, Please feel free to stand in front of them.
88 xtra cab sas'd dual cases flatbed
superyota
  • Turtle Points: 3
  • Male Posts: 3,350
  • what happened?
« Reply #167 on: Apr 18, 2008, 09:58:04 AM »
3.4 with a carb?
ABD Motorsports
#4475
KK6QDW
Duffil
  • *lurker*
  • Turtle Points: 88
  • Male Posts: 4,832
  • Member since Nov '04
  • -Hack-
    • PhotoBucket
    • Buy me a soda
« Reply #168 on: Apr 18, 2008, 09:43:06 PM »
3.4 with a carb?
i think he means he sprayed carb cleaner in the throttle body
85toyrunner_rockrig
  • Male Posts: 44
  • Member since Apr '09
« Reply #169 on: Apr 29, 2009, 05:24:41 PM »
i love living in SW colorado, no smog req.
johnstrings
  • Member since May '09
« Reply #170 on: May 01, 2009, 06:50:39 PM »
Thanks...
That is VERY informative...
 :thumbs:
Johnstrings
potter85
  • Male Posts: 257
  • complete disregard for sheet metal.....
« Reply #171 on: May 25, 2009, 08:08:15 PM »
smog is just another way to drain money from people....It has a great idea behind it but unlike what everone assumes not all smog comes from cars. I dont see grandpa smogging his tractor every 2 years... Same with laws like the beadlock law... They enforce it for the money
3rz in the making
looking for 38s
2 tundra 4.7l v8 soon to be sas'ed
86rustbucket
  • Turtle Points: 5
  • Member since Jun '09
    • Buy me a soda
« Reply #172 on: Jun 07, 2009, 02:22:17 AM »
yes smog is bull crap.go smog your black n white piggy
86rustbucket
  • Turtle Points: 5
    • Buy me a soda
« Reply #173 on: Jun 07, 2009, 02:30:21 AM »
iv had good luck by filling up with chavron 91 and a bottle of berrymans fuel system cleaner.run out most of the tank and go to the smog shop with the engine goog and warm and let the engine idle while your waiting
usmc4runner
  • Male Posts: 4
  • Member since Oct '09
« Reply #174 on: Oct 07, 2009, 09:10:30 AM »
Im in atlanta and i failed horribly the first time.. popped a vacuum leak and passeed she did
superyota
  • Turtle Points: 3
  • Male Posts: 3,350
  • what happened?
« Reply #175 on: Oct 16, 2009, 04:10:39 PM »
just took my 90 4runner with 3.0 in for smag today and it failed horribly.  i put new ngk plugs in it yesterday, new cap/rotor/wires, 91 octane chevron, and 1 bottle of rubbing alcohol, cleaned the air filter(k&n), turned the idle up to 1000 rpm, and also retarded the timing 2 deg. Also used a infrared gun today to check the temp before and after the cat and it was almost 100 deg. hotter after the cat, so i'm assuming its working right.  here are the numbers:
                            %CO2    %O2    ( HC----------PPM)  (-----------CO%-----------)
Test          RPM       MEAS    MEAS    MAX    GP    MEAS    MAX    GP    MEAS    Results
Idle           991        11.32    0.5       120    270    2376    1.00    2.50   4.92     GROSS POL
2500 RPM   2683       12.26    0.2       180    330    324     1.00    2.50   3.97     GROSS POL
GP=Gross Polluter Limits
MAX=Max Allowable
MEAS=Amount Measured
any suggestions?  just went to dmv and got a 30 day pass for it.
ABD Motorsports
#4475
KK6QDW
Pat
  • Turtle Points: 331
  • Male Posts: 848
  • Member since Jun '02
  • Oroville, Ca
« Reply #176 on: Oct 16, 2009, 04:58:37 PM »
it is running extremely rich..  Check you efi system..  It is so rich it is causing the Hc to be extremely high..  Does this truck seem like it even runs good?  High hydrocarbons mean you are in a misfire condition when it is that high..
Most EFI toyotas when running correct are close to .00 to .03 on the co% even if you took the cat off :hammerhead:
« Last Edit: Oct 16, 2009, 05:04:13 PM by Pat »
Oroville CA, 80 miles north of Sacramento
superyota
  • Turtle Points: 3
  • Male Posts: 3,350
  • what happened?
« Reply #177 on: Oct 16, 2009, 05:13:03 PM »
runs a little rough at idle.  but off idle it runs great.  i still havn't figured out why it runs ruff.  do you think a new cat would even come close to cleaning it up?
ABD Motorsports
#4475
KK6QDW
Pat
  • Male Posts: 848
  • Oroville, Ca
« Reply #178 on: Oct 16, 2009, 05:20:52 PM »
no, not running that rich..  You either have a real issue with way too much fuel or a cylinder that needs attention..  Do a compression test before you go to crazy in the troubleshooting ares..  Does it use water at all?
how many miles are on this motor?
superyota
  • Turtle Points: 3
  • Male Posts: 3,350
  • what happened?
« Reply #179 on: Oct 16, 2009, 05:26:00 PM »
no, the old motor had bad gaskets, just replaced it with one i got off priate from a guy in placerville, supposed to have 110k on it. it was in his 4runner and it was his daily driver.  ran great.  he pulled it out after i paid for it.  doesn't use any water, or oil.  i'm wondering if the old motor with bad gaskets and buring oil could ruin the cat, but if it won't lower the emissions, i don't see the point of changing the cat.  i'll try a comp. test.  thanks for the info.  i'll keep posted.
ABD Motorsports
#4475
KK6QDW
Last post Jun 27, 2009, 07:16:17 PM
by kneedownnate
Last post Oct 06, 2009, 11:43:28 PM
by Snowtoy
Last post Apr 23, 2010, 02:16:53 PM
by emsvitil
Last post Dec 20, 2010, 06:33:23 PM
by yotatough
Last post Dec 07, 2013, 03:51:05 AM
by Vang530
