Well for anyone rebuilding their box heres a "How too" http://web.archive.org/web/20050322011020/http://128.83.80.200/taco/box.htmlI got my box back together and believe it or not it works! For the square cut teflon o rings just use a hose clamp to make them smaller once you get them on. Theres a pretty easy way to get the 44 little balls back in place.On the piston the worm gear threads into, it has a cap that can be unthreaded and taken off. Then fill the little "tube with as many as you can and put the worm gear in an inch or so. Dump the bearing into the top of the piston and thread it in and they will fall into place. Took me about 5 minutes to get them all back in.
this is not a grinder mark it is from beating the sector shaft out with a hammer. one of the teeth scarred the housing because the teeth are off centered from the sector shaft and if the teeth are not centered when removing or installing they will scar the housing like this due to forcing the shaft.
well your ram is too big most people use a 6 in ram. and you need to increase the volume in your system by adding a cooler and/or cutting the resivoir and scabbing one together.
If your talking to me I have 3/4 ton Chevy axles! I have all ready scabbed one together you would know that if you read my whole post!
You do not deserve any response
If your Taco pump is like the one I worked on with 2 smaller holes next to each other rather than 1 in the middle, then you can't drill it out. The restrictor on the one I worked on had a large air gap in the middle so drilling into it just opened up the whole area. Kinda sucked..........but now I know.
well if you would have read the hydro assist thread you would know that you need to run a 1.5 in ram and not a 2 in one. and you would know that 8 in is also long no matter what axles you have.
then buy a jeep
My 10mm plug stripped out so I wust welded a nut to it. It came right out after that. (the heat helped)
anyone??? 3.4 motor... drilled mines out to 13/64 and now it makes a whine around 2500 rpms...should i put back a stock restricter? or is that normal...
when you drill the hole on top for the vein how far down do you go??
Started by KYOTA General 4WD Discussion
Started by 4RnrRick Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by Rocksnail Engine
Started by crazykooter Engine
Started by supermoto917 Axle/Differential/Steering
