Author Topic: Hydro Assist:box and pump mods  (Read 236207 times)
boblamborghini
  • Member since Apr '06
  • toy 81 22r
Re: Hydro Assist:box and pump mods
« Reply #120 on: Jul 20, 2006, 03:02:04 AM »
nice post ! i need to do it on my 81 because my diff is welded and i would like to know what size of ram you used ?
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
« Reply #121 on: Jul 20, 2006, 05:36:17 PM »
theres a link to the other thread ( Hyd assist on the cheap) in the very first post of this thread. These 2 threads are invaluable when doing hydro asst. add to favorites
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
  • Member since May '05
« Reply #122 on: Jul 26, 2006, 03:14:41 PM »
Has anyone done this set up, but with a late model Sawginaw pump? I am wondering if I will have the problem with cavitaion. The rest of my system is the same as most of you. I just happen to have a 4.3L vortec in my truck.
82 1st Gen with 4.3L vortec and 4l60e. Linked front and rear
My build up. Getting linked
http://board.marlincrawler.com/index.php?topic=50700.msg711361#msg711361
Tice
  • Turtle Points: 7
  • Male Posts: 879
  • Member since Feb '05
  • I named my son Wheeler!!!!
« Reply #123 on: Jul 26, 2006, 04:45:03 PM »
It should be the same. You may have to had more capacity to your resivour but other than that it should work.
I don't need a winch, I wheel a TOYOTA!!!!!!!
www.wheelingarizona.com
FIREBALL
  • Turtle Points: 221
  • Member since Feb '03
  • Hi Ho Marlin....u talkin to me
« Reply #124 on: Jul 26, 2006, 05:20:46 PM »
Works just fine. I have the exact setup on my rig and have no probs.
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
« Reply #125 on: Aug 17, 2006, 12:29:12 AM »
When I do my conversion on my 82 that has a Vortec with the Saginaw pump I will let you know what happened. I will ad a cooler to the return line to give some more capacity. I am also doing this to a 92 truck with Toy pump. I will enlarge the restrictor as mentioned in Hydro Assist On the Cheap. I will ad a cooler, but wondering if I can ad a secondary reservoir instead of brazing on an extension to the Toy Res.
freds40 [OP]
  • Turtle Points: 293
  • Male Posts: 2,330
  • Member since Dec '02
« Reply #126 on: Aug 17, 2006, 07:35:05 AM »
On the Sag pump, you can open up the restrictor as well. For your res. you can do a secondary canister, only down sides I could see would be it will need to be a flow through as a T in the line won't force the fluid through it and also it's 1 more thing to mount under the hood.
"between projects"
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
« Reply #127 on: Aug 17, 2006, 10:59:07 AM »
I think I will need to seriously consider running more capacity with my Sag. A few years ago I was ditching the man when I was wheelin where I shouldn't be at 2 a.m. I was haulin down a twisty fire road and that alone made my fluid boil over.
black92se
  • Member since May '06
  • at least I gots a yota steering box
« Reply #128 on: Aug 30, 2006, 02:57:29 PM »
I thought I would say that I just used this to port my box, I am wheeling a nissan so I gotta figure out how to open up my nissan pump. Anyways, this worked out great. I used a magnet to get most of the pieces, it worked gerat right after the hole was drilled.
1992 Pathfinder, cool stuff.
alwayzbroken
  • Turtle Points: 603
  • Male Posts: 1,905
« Reply #129 on: Sep 11, 2006, 10:40:27 AM »
Has anybody noticed an increase in internal box failure with hydro assist? The internals of my box exploded after 3 trail rides since it was ported.
Renaud33
  • Turtle Points: 2
  • Member since Aug '04
« Reply #130 on: Sep 11, 2006, 10:54:37 AM »
Guess I better keep my spare boxes.  Haven't had any issues yet.
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
« Reply #131 on: Sep 19, 2006, 10:25:48 AM »
So I succesfully finished the install on the 92. Worked out great. Bled the system with the wheels up in the air. Because I made the factory reservoir 3" taller I had to remove the EGR valve bracket. If you do this remember to put back the small bolt that held the bracket in or else you will have a idle problem because of a vacuum leak.
Now I am going to do it on my 82. Does any one have a source for a bolt on collar that goes on Marlins' tie rod so I can weld tabs for the ram.?
Renaud33
  • Turtle Points: 2
« Reply #132 on: Sep 19, 2006, 10:45:07 AM »
I don't know that this is quite what your looking for.  Maybe worth consideration.
http://www.pobcoplastics.com/pg_74.htm
I just welded tabs on the tie rod.  Purchased my tabs from this place.
http://www.aa-mfg.com/pdshop/shop/
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
« Reply #133 on: Sep 19, 2006, 11:47:23 AM »
Something like this.
http://www.mad4wd.com/tek9.asp?pg=products&specific=jrgrkme0
They just don't make it the size that fits Marlin's tie rod.
beafire
  • Male Posts: 22
  • Member since Aug '06
« Reply #134 on: Sep 29, 2006, 02:44:32 PM »
Very nice setup. Thanks
« Last Edit: Sep 30, 2006, 05:02:25 AM by beafire »
1992 Toy pickup solid axel swap with lock right front, 5.29s, spool rear, high cross over hydro steering, dual transfercases, 32 bolt Frankie beadlocks, 37 MTRs, Front Warn 8274,Rear mounted 9000 winch, 63 Chevy rear springs, Tube flat bed and front fenders with stinger.
BigBs84
  • Turtle Points: 3
  • Male Posts: 349
« Reply #135 on: Oct 18, 2006, 12:14:20 PM »
good job! this really helped save me $300 on a new predrilled box
Build it wright-wind it tight
   High-N-Tight offroad
http://board.marlincrawler.com/index.php?topic=45027.0 My truggy build
dov'd85
  • Turtle Points: -470
  • Male Posts: 348
  • Member since Dec '05
« Reply #136 on: Oct 18, 2006, 10:36:17 PM »
do the high temp hoses come with ends on them? i just bought a ram assist and i got a set of hoses with it but i want to carry a few extra's i have heard of people tearing them off and i don't want to spend 20+ a line for anothe set
great right up time to go fix some stuff on my set up...! :beer:
james
85 long bed: 30 spline long, hydro assist, hysteer, 223.1 twin sticks, 39.5 iroks, rear disk,
http://board.marlincrawler.com/index.php?topic=28696.msg344178#msg344178
Tice
  • Turtle Points: 7
  • Male Posts: 879
« Reply #137 on: Oct 19, 2006, 10:13:09 PM »
The hose's from Surplus Center come with ends on them, they only run about 8 bucks too.
dov'd85
  • Male Posts: 348
« Reply #138 on: Oct 19, 2006, 11:21:09 PM »
thanks man but we don't have a surplus store in washington like shmucks and napa? B&B?
freds40 [OP]
  • Male Posts: 2,330
« Reply #139 on: Oct 20, 2006, 12:22:31 AM »
Surplus Center is on the net. They are pretty quick about shipping and it'll still be cheaper than most kit form hoses.
"between projects"
dov'd85
  • Male Posts: 348
« Reply #140 on: Oct 20, 2006, 09:06:10 AM »
do you have a part number and a web site?
james
freds40 [OP]
  • Male Posts: 2,330
« Reply #141 on: Oct 20, 2006, 10:59:37 AM »
http://board.marlincrawler.com/index.php/topic,4699.0.html
The answers you seek are hidden within....     :talkingn:   :laugh:
Sorry, it's one of those mornings. If you take a peek in there, all the PNs I used are there, I just didn't feel like searching my old thread.  :hammerhead:
"between projects"
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
« Reply #142 on: Oct 26, 2006, 09:08:18 PM »
Here is a picture of the modified P.S. reservoir and the cooler I installed on Rokcrawlintoy's rig. No squeeling and it stays cool.
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
« Reply #143 on: Oct 26, 2006, 09:12:49 PM »
Here is the 6" ram, hoses, and fittings.
Mikeyg79
  • Turtle Points: -17
  • Male Posts: 25
  • Member since Apr '05
    • Webshots Pics
« Reply #144 on: Nov 04, 2006, 10:48:36 AM »
I've got an IFS box that I bought second hand, pre-tapped...
when looking into the empty box, it looks like the fitting in the "TOYODA" will be hit by the sector shaft gears as you turn.
is that a problem for anyone?
Elvota
  • Turtle Points: 59
« Reply #145 on: Dec 13, 2006, 02:14:49 PM »
So, how many of you would do this mod on a daily driver?  Would it be to twitchy to drive on the freeway?
Any thoughts as to how one might be able to turn the RAM off?  Just throwing out ideas here, but could a valve be installed somewhere that would essentially stop fluid going to the RAM assist when you were driving on road.  Then, just flip the switch and start crawling.
This of course may not be practical or impossible... but I would appreciate feedback if anyone has any.   :yesnod:
alwayzbroken
  • Male Posts: 1,905
« Reply #146 on: Dec 13, 2006, 11:21:01 PM »
You would still have to fight the drag of the ram pushing fluid back and forth in the lines. I think that is how it would work at least. I don't know if I would do it on a daily driver after how mine turned out. I was not able to drill my restrictor so it is pretty slow. I have had a few hairy incidents with hitting curbs while hot rodding around corners and coming close to entering the neighbor's yard.
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
« Reply #147 on: Dec 14, 2006, 02:09:01 AM »
Why were you not able to drill out your restrictor?
Elvota
  • Turtle Points: 59
« Reply #148 on: Dec 14, 2006, 11:44:31 AM »
Anyone think this idea would work...
In effect, would isolate the RAM unless the valves where open, and would allow the RAM to run in a closed loop when valves where shut which would allow the RAM to move freely against the stock steering box pressure... almost like a steering dampner if anything.
Just seems like this might be a good idea for a daily driver.  No change on road (valves closed) and full ability to crawl with low PSI, etc off road (valves open).  Off course this assumes such valves are even available.
alwayzbroken
  • Male Posts: 1,905
« Reply #149 on: Dec 14, 2006, 05:53:50 PM »
My pump would squeal terribly.
Last post Mar 31, 2005, 10:26:44 PM
by freds40
Last post Jan 29, 2006, 08:49:05 PM
by KYOTA
Last post Aug 18, 2006, 12:22:14 PM
by 4RnrRick
Last post Mar 10, 2010, 08:54:02 AM
by Rocksnail
Last post Feb 26, 2016, 09:20:14 PM
by T2crawlfun
