Author Topic: !983 SR5 PU Tranny swap  (Read 1128 times)
83Camo
  • Turtle Points: -16
  • Male Posts: 47
  • Member since Jun '21
« on: Apr 09, 2023, 10:42:04 AM »
 :clap: Finally completed my Tranny swap  I replaced my old L-52 with a W56-B {rebuild} from an 87
Used a set of stock U-bolts cut away part of original crossmember mounts , welded plate onto forward part of stock crossmember and drilled out new mounting holes. Stock Front driveshaft from 87 fits . I have the rear DS being modified {shortened}
Have to do more mods on floor tunnel for shifters {waiting on a "Marlin short shifter} , all is good !
It's been a while since I've been able to be on the forum AND I want to thank one & all for the assistance
Thanks MC  :bowdown:
« Last Edit: Apr 09, 2023, 10:49:34 AM by 83Camo »
Unrepentant Fenian/Tattooed & Employed
toyodaaddict
  • Turtle Points: 399
  • Male Posts: 1,142
  • Member since Sep '08
Re: !983 SR5 PU Tranny swap
« Reply #1 on: Apr 09, 2023, 02:27:48 PM »
I've always been a big supporter of the w56 swap for first gens. Well worth the hassle . I'm certainly glad I went that route.
Now you just need some Marlin dual cases and your set .
83Camo [OP]
  • Male Posts: 47
« Reply #2 on: Apr 10, 2023, 09:59:26 AM »
Yeup T-addict , I had an old W-56 in shed thought I'd put it to good use. The old L-52 had worn out it's welcome
As far as "Duals" go I'll have to wait till this coming WildFire Season is over ......think we're gonna be busy  :yikes:
Thanks
83Camo [OP]
  • Male Posts: 47
« Reply #3 on: Apr 11, 2023, 01:28:55 PM »
Along with my tranny swap I have to get stock rear drive shaft shortened {re-tubed} about 5" . This truck is on a longbed chassis. My machinist tells me that because of beveled ends of the stock tube where they are welded to yoke mounts ...he will have to use a smaller diameter tube  {similar to the mid-late 80s 4x4 trucks} for modification .
This truck has a 22R 5Speed 5;29 gears centerforce II clutch and lockers and 34/10.5/15 swampers.
My concern ....will the smaller diameter tube hold up  ?
Anybody that has gone this route , appreciate your input, Thanx !
« Last Edit: Apr 11, 2023, 03:30:43 PM by 83Camo »
toyodaaddict
  • Male Posts: 1,142
« Reply #4 on: Apr 11, 2023, 07:21:27 PM »
Driveline shop should be able to set you up with thicker wall tube, making them much stronger than stock.
 I've always used HighAngle for my driveline work and they use thicker wall tube for the rear and even thicker for the front. I dont recall how thick but there is a limit for the rear of street driven trucks.
lone walker
  • Turtle Points: -26
  • Male Posts: 606
  • Member since Oct '09
  • we're there!
« Reply #5 on: Apr 12, 2023, 03:09:41 AM »
Factory is under .080 and the 2 options folks go with is .120 or .156
Going, going, gone
83Camo [OP]
  • Male Posts: 47
« Reply #6 on: Apr 12, 2023, 03:47:38 PM »
Much appreciated, spoke with machinist today , said he's  re-tubing it with .120
I'm limited out here in Northern NM as far as machinist /quality shops, This fella's been one of the good ones.
Thanx !
83Camo [OP]
  • Male Posts: 47
« Reply #7 on: Apr 22, 2023, 02:16:13 PM »
Change of plans.... had to go to Santa Fe {machinist in my area bailed} my Driveshaft finally got finished, Eric @ Santa Fe Auto Machine designed a very nice complete shaft for me . Driveshaft is 53" long  Used DOM tubing 1310 dana-Spicer u-joints new 1310 set up on yokes and slipjoint.
Very Nice Job, Bolted it on took up to mountains for test ride, Sweet !
 What a difference with the w56 tranny  :biggthumpup:
lone walker
  • Male Posts: 606
  • we're there!
« Reply #8 on: Apr 22, 2023, 04:33:47 PM »
Shop couldn't retube your factory? 1310 joint is weaker than the Toyota
Going, going, gone
Last post Dec 04, 2006, 06:23:48 PM
by Lonestar Honcho
Last post Nov 06, 2009, 04:46:33 PM
by trekkerpaul
Last post Jan 13, 2010, 06:27:37 PM
by Dirt Mover
Last post Aug 22, 2013, 04:38:29 AM
by R.DesJardin
Last post Dec 15, 2018, 06:44:36 AM
by jimbo74
