Hey P...Sounds like there's an "open" somewhere.Bypass the switch to eliminate that as bad.That block connector in the photo needs to be cleaned with some zero residue contact cleaner.Ohming out the wires may uncover an open. I'd rather get mauled by a mama grizzly bear than have to trace down an electrical wire!! Good luck.Gnarls.
remove the jumper at the b-bolt switch. when the bolt is in it opens the circuit, when the bolt is out, it closes the circuit. the jumper you put in(at the bolt switch, not the jumper in the picture you provided)is telling the truck that the top is off, rendering the window inoperable.
ahh, maybe i got it backwards or didn't realize there were 3 wires vs 2.
Started by punkrock crawler Parts For Sale
Started by motormouth559 Parts For Sale
Started by Black Runner Parts Wanted
Started by Aaronm Parts Wanted
Started by get r done Parts Wanted
