We currently are not offering Customer Support on our Forum.
Please use our Store website for: Customer Contact.
Author Topic: New Discounted New & Used Parts @ Marlin Crawler  (Read 1067 times)
Marlin Crawler
  • Hawk
  • Turtle Points: 70
  • Member since Dec '17
    • Marlin Crawler, Inc.
« on: Aug 08, 2022, 05:58:41 PM »
We've been rearranging and cleaning our two warehouses and have added many new & used discounted parts to our site!
Check each item for more details. View the full listing here: MarlinCrawler.com/discounted-parts
First come, first serve!
1 1/4" Heim Joint - LH
Only $25!
1 1/4" Weld In Tube
Adapter - LH
Only $12!
1 1/4" Weld In Tube
Adapter - RH
Only $12!
21 spline 4.7 Comp Input
Gear
Only $150!
3/4" Heim Joint - LH
Only $12!
3/4" Jam Nut - Left Hand
Only $2!
3/4" Jam Nut - Right
Hand
Only $2!
3/4" Weld In Tube
Adapter - LH
Only $7!
4.0 Automatic
Transmission Adapter
Only $350!
Bilstein 24-186636
Only $75!
Bilstein 24-187183
Only $75!
Bilstein 24-232173
Only $100!
Bilstein 33-170794
Only $75!
Bilstein 33-230375
Only $175!
Bilstein 33-230399
Only $75!
Bilstein 33-247724
Only $75!
CV Joint Double Cardan
Cores
Only $50!
G & W Series Bell
Housing
Only $50!
HD Transfer Case Mount
Only $100!
High Misalignment
Spacers
Only $10!
Land Cruiser 3-speed
T/Case Input Seal
Only $4!
Land Cruiser Split Case
Output Shaft Nut
Only $7!
MOOG EV800529 Tacoma Tie
Rod End
Only $25!
NEW L52 Shift Handle
Only $150!
Nachi 6306N Bearing
Only $5!
New 225C-135A Detroit
Locker for GM 9.5" 14
Bolt
Only $750!
New Clutch Master
Cylinder Land Cruiser
Only $45!
New Clutch Master
Only $45!
New Clutch Master
Only $45!
New Clutch Master
Only $55!
New Clutch Slave
Only $30!
New Clutch Slave
Only $30!
New Clutch Slave
Only $30!
New Disc Brake Pads for
Lexus and Land Cruiser
Only $15!
Toyota Cressida and
Pickup
Only $15!
Toyota and Lexus
Only $15!
Toyota pickup, 4Runner,
and Land Cruiser
Only $15!
New FJ60 Brake Rotor
Only $60!
New H55F Transmission
Main Shaft
Only $200!
Private Messages are not monitored
Please contact us at MarlinCrawler.com/contact or (559) 25-CRAWL / 559-252-7295
Marlin Crawler [OP]
  • Hawk
  • Turtle Points: 70
To view the full list: https://www.marlincrawler.com/discounted-parts
New MOOG ES80895
Only $10!
New Nitro Gear MKTV6-B
Only $250!
New Nitro Gear
T100-456-NG
Only $200!
New Nitro Gear
T7.5-411-NG
Only $225!
New Nitro Gear
T8R-456R-NG
Only $225!
New Nitro Gear
T8S-456RT-NG
Only $275!
New T360 3.0 Chain Case
Adapter
Only $375!
New USA Standard ZK
REV-B
Only $450!
New USA Standard
ZK-TLC-A
Only $275!
OEM High Pinion 4.11
Ring & Pinion
Only $150!
OEM V6 4.11 Ring &
Pinion
Only $150!
Procomp 321518 Shock
Only $30!
Procomp OE14125 Struts
with P-Pack
Only $70!
R150F (3.0L 3VZE) Bell
Housing
Only $99!
R154 Bell Housing
Only $350!
Shifter Boot Ring
Only $10!
Steering Stabilizer kit
Only $65!
Stock FJ80 Drive Flanges
Only $40!
Tacoma 3.4 Pressure
Plate and Disc
Only $150!
Tacoma R150F Bell
Housing
Only $150!
U-Bolt Plates
Only $25!
VSS for 3.0 Chain
Transfer Case
Only $75!
We have already sold and removed over 20 products from the site, including some used 4.70:1 gear sets, 23-spline Turbo input gears, and a couple Dual Case adapter kits that were missing some pieces. Subscribe to our Newsletter to be the first to hear about offerings like this!
MarlinCrawler.com/newsletter
Marlin Crawler [OP]
  • Hawk
  • Turtle Points: 70
Got some new 2" wheel spacers for all you Toyota and GM owners out there!
These were purchased for a customer who then changed plans.
6x5.5 pattern, lug centric. M12x1.50 class 12.9 studs
- 2" Wide Wheel Spacers Only $45! -
Last post Jul 07, 2004, 05:19:59 PM
by brainlessfool
Last post Sep 15, 2006, 08:38:16 PM
by MocKKnighT
Last post Nov 20, 2006, 06:10:21 AM
by Gittinit
Last post Oct 17, 2012, 08:24:11 AM
by BigMike
Last post May 24, 2018, 07:20:18 AM
by lone walker
