Located in Wilton, California 95693 pickup preferred $5,500 OBO Make me a reasonable offer. Parts to build the front axle today would be well over $5000 not including the truss work, tabs and bracing.
These axles were under my buggy for several seasons and served me well. Most of the photos I have are of the axles when they were still under the buggy. Please message me for any other details. I would like to sell as a set. Steering RAM NOT INCLUDED
Both axles were methodically built and maintained the Rear Gears only have 3 runs on them freshly installed January 2020 with new bearings/setup kit.
One of the studs on a rear wheel spacer needs to be replaced
Front
Ruff Stuff Fabricated 8” +5” width Housing, Passenger Drop
Custom Truss, Setup for 4 Link
Full Hydro Ram Mount, and bull bar set up for PSC 2.5x8” Ram Part Number: SC2212 (RAM NOT INCLUDED)
Front Range Offroad keyed steer arms and machined Knuckles, Double Sheer High Steer Bolt Setup
ARP High Steer Studs
Marlin Crawler 25mm Chromoly Pin Trunion Bearing Upgrade
Trail Gear Studless hubs,
Longfield 30 spline Chromo Shafts & Birfields
High Pinion, 5.29 Gears
Yukon Zip Locker
1.5” SpiderTrax Wheel Spacers
Fully Armored Gusseted and Braced
Brake Lines and Distribution Block Setup for -3 Ready to bolt in.
Vented Rotors
Tie Rod Links for Steering Included
WMS with spacers Approximately 64.5”
Rear
Toyota IFS Width 8” V6 Housing and Carrier
5.29Gears 29spline Pinion Spooled
Yukon Chromo Shafts,
2” Trail Gear Wheel Spacers,
Sky Offroad Disc Brake Conversion
Triple drilled pinion flange.
WMS with spacers Approximately 64.75”
Spares - Will go with these axles
Front: Brand New RCV 30spline Birfield
Front: Brand New LongField +5 width short side shaft
Rear: Stock rear Toyota axles shaft assembly complete with bearing and cup ready to bolt in.
$5500 OBO Make me a reasonable offer. Parts to build the front axle today would be well over $5000 not including the truss work, tabs and bracing.
Email tac1fab@gmail.com or txt 9-16-224-0553 for more info.. I'm not on here much
