Author Topic: R150F conversion to 2wd  (Read 1505 times)
EvilTech
  • Member since Jan '20
« on: Jan 27, 2020, 08:57:49 AM »
Hello,
I'll make this quick and painless.
i want a different manual transmission for my race truck.
it currently has a W58
i found a couple R150F 4wd trannys, and i want to know...
can i swap my bell housing and tail cone from my W58 to the R150f, or is there something else i need to do to convert it to 2wd? i do know that the R150F is 23 spline output shaft and my W58 is 21 spline, so i will be getting a new slip yoke.
i have a 22RE that why i need to swap the bell housing too
the truck:
« Last Edit: Jan 27, 2020, 09:12:52 AM by EvilTech »
T-Revv
  • Turtle Points: 722
  • Male Posts: 278
  • Member since Apr '17
  • Crawlin at work, Crawlin on the trails. best life.
Re: R150F conversion to 2wd
« Reply #1 on: Jan 28, 2020, 09:10:57 AM »
The W bellhousing pattern is different than the R bellhousing, you will not be able to use your bellhousing.  Also your W tailhousing will not work either. I would try to track down a R150 2wd, and than a a R151F bellhousing to go to your 22RE.  or you can get a bellhousing adapter like this one: http://www.northwestfab.com/Toyota-4-Cylinder-Bell-Housing-to-Toyota-R150R151-Transmission-Kit_p_1053.html  and use your bellhousing.  But definitly need to find a 2wd R150.   :thumbs:
"I dunno I just woke up from a lil nap, it's a lil dark but you guys silly? I'm still gonna send it."
EvilTech [OP]
« Reply #2 on: Jan 28, 2020, 09:50:04 AM »
i just found a 4cyl 2wd transmission from a 98 tacoma, which tranny code would it be? I'm assuming it should bolt up to my 22re, i would i still need a different bell housing?
Last post Aug 03, 2004, 12:21:40 AM
by WHITE_TRASH
Last post Jan 27, 2020, 09:29:18 AM
by gnob
Last post Jan 05, 2010, 06:51:29 PM
by COToy91
Last post Apr 11, 2019, 12:01:39 PM
by Dingman.
Last post Oct 25, 2014, 07:58:35 PM
by OVRAROK
