When you say power converter I am assuming you mean a 12V DC to 120V AC power inverter. To do it right, you need to first get a higher amp alternator. The stock alt will not adequately charge 2 batteries. I'm not sure what you mean by "super expensive dual battery charging kit" but yes, you should use some sort of battery isolator. There is no reason to use a high power relay to disconnect power to the inverter as it shouldn't draw any power when it is off, same for the winch.
Started by raptorman57 General 4WD Discussion
Started by toyoder Parts For Sale
Started by Bazzi Project Research and Build-Ups
Started by machine380 Parts Wanted
Started by 79crawler Toyota Pickup/4Runner Tech 1979-95
