Author Topic: Brake light issues  (Read 308 times)
mountain,man1
  • Turtle Points: 163
  • Male Posts: 57
  • Member since Jan '19
Brake light issues
« on: Jan 14, 2019, 06:25:22 PM »
I was just informed by a state trooper of a brake light issue I'm having on my way home. When my headlighs are off both my brake lights work fine but when I have my headlights on my drivers side brake light comes on for a second then stops working. At first I thought it was a bad bulb I changed it in front of the trooper but didn't fix the problem. So now I figure its in the wiring I believe it may be a bad ground I obviously have power to the light. Any ideas where I should start when I finally get around to it
88 TurdRunner 22RE W56B 31x10.5R15 no lift rust assisted weight reduction 100% trail damage
gnob
  • Turtle Points: 395
Re: Brake light issues
« Reply #1 on: Jan 15, 2019, 04:36:03 AM »
It could be the other bulb. It could still be a dirty socket.
hold this. . .
mountain,man1 [OP]
  • Male Posts: 57
« Reply #2 on: Jan 15, 2019, 05:38:39 AM »
The other ball was just recently replaced I had to replace the whole fixture on the passenger side rear it broke when I got up against the tree off roading and all those bulbs are new but it is a junkyard fixture
liveoak
  • Turtle Points: 115
  • Member since Mar '08
« Reply #3 on: Jan 15, 2019, 09:58:59 AM »
do you have a trailer light converter installed for towing? when they go bad, weird things can happen. when your headlights are on, so are your running/parking lights which share harness wiring with brake, turn and reverse bulbs
my 3rz swap. http://board.marlincrawler.com/index.php?topic=97722.0
Let me start off with a basket of chips
mountain,man1 [OP]
  • Male Posts: 57
« Reply #4 on: Jan 15, 2019, 08:13:48 PM »
I have a 1 1/4 inch receiver hitch. I'm pretty sure I do not have a trailer wiring harness I didn't see one the only time I've ever towed with my 4Runner. Depending on how my work schedule looks at the end of the week I may pull the truck in the shop bust out my voltage meter and track it all down. Thank you guys for the ideas
mountain,man1 [OP]
  • Male Posts: 57
« Reply #5 on: Jan 19, 2019, 01:48:14 PM »
 Thank you everybody for the tips. I fixed my brake lights. I pulled both fixtures and sprayed all the sockets and connectors with CRC QD electronic cleaner and replaced both brake light tail light bulbs. Everything is working splendidly now thanks again
Last post Jan 19, 2019, 08:40:10 PM
by mountain,man1
Last post Sep 19, 2007, 09:41:37 PM
by yotaboy79
Last post Nov 04, 2007, 06:00:50 PM
by mudweiser
Last post Jan 11, 2008, 10:40:25 PM
by jimbo74
Last post Jan 21, 2012, 01:09:39 PM
by OVRAROK
