Author Topic: clutch not engaging  (Read 1671 times)
E YOTA
  • Male Posts: 690
  • Member since Jan '04
clutch not engaging
« on: Jan 06, 2019, 09:02:45 PM »
gotta 86 runner and when its cold the clutch is hard to shift into gear.... but when trucks been running for awhile it shifts fine. any info would be much appreciated , thanks
built lastnight, crawl today...
300k
  • Turtle Points: 3744
  • Male Posts: 623
  • Member since Jun '15
  • GREEN NAME MAN BAD!
    • Please ban me!
          OK!
      I am banned!
Re: clutch not engaging
« Reply #1 on: Jan 06, 2019, 09:08:48 PM »
What do you mean by running for a while? Idling or driving?
NotPossible907
  • Turtle Points: 261
  • Member since Sep '18
« Reply #2 on: Jan 07, 2019, 09:10:02 AM »
More info would help, but if it happens when it's cold and not been driving around enough to warm the gear oil up, I'd make sure you are using the right weight and not something too heavy.
Lewis Hein
  • Shoutbox Ban
  • Turtle Points: 273
  • Member since Feb '17
  • Trying to equal the wonderful one-hoss shay
« Reply #3 on: Jan 07, 2019, 05:17:09 PM »
Is the clutch hydraulic system bled?
E YOTA [OP]
  • Male Posts: 690
« Reply #4 on: Jan 07, 2019, 06:27:35 PM »
my bad, i can still shift into gears but with difficulty/pump on clutch a few times while trying to shift into first. after about 15 min. of driving around it shifts fine. i noticed when its been driven around all day and hot  it gets hard to shift into gear too. i use 80/90 gear oil. and i have a new ceramic clutch with marlin heavy duty transmission . it worked fine in the summer time but now its winter and cold so i  notice that. i havent tried bleeding the system yet though. im thinking it could be something else like maybe a warn slave or it need a different slave to push fork more...i dont know and looking for some advice or tech on it...
Lewis Hein
  • Shoutbox Ban
« Reply #5 on: Jan 07, 2019, 06:31:38 PM »
I would try the simple stuff first. Last time I saw a problem like this I was with a field crew in southern Peru and they were all scratching their heads about how to get our field truck to a mechanic when it wouldn't go into gear. I bled the clutch in ten minutes saved us all a big headache and earned me a lot of respect :greengrin:
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • Member since May '07
  • I'LL NEVER MAKE IT...
« Reply #6 on: Jan 07, 2019, 08:01:58 PM »
Yup Lewis is right, bleed the clutch.  Had the same thing in my '80 in the winter time when we would do lots of fording to go haul feed to horses. Had to bleed the system every once in a while.  Eventually I got a fresh clutch slave and some synthetic brake fluid for it.  The synthetic, although not necessary, doesn't suck up moisture as bad as regular brake fluid.
– Steve McQueen
187unlimited
  • Member since Apr '19
« Reply #7 on: Apr 15, 2019, 10:52:51 AM »
Def. look at the clutch system, Bleed, Fresh fluid, proper pedal adjustment etc.
Last post Mar 20, 2005, 08:09:58 AM
by 79coyotefrg
Last post Jul 07, 2007, 06:50:18 PM
by Zoomschwortz
Last post Aug 18, 2008, 02:18:58 PM
by BigMike
Last post Sep 21, 2009, 03:13:32 PM
by Larryb
Last post Dec 13, 2009, 10:40:38 AM
by Leg0nd
