Author Topic: Interior lights problem  (Read 1730 times)
Jarhead
  • Turtle Points: 435
  • Member since Jul '12
« on: Nov 08, 2018, 03:12:04 PM »
Just recently my interior cluster stopped working. I thought it was the dimmer but it looks like it’s working fine. While troubleshooting I found that my rear lights and fro t marker lights are not working when I turn them on with the interior switch. The only way my lights work is when I press the breaks or turn on the signals. I checked the fuses inside and out and they look good. Does anyone know if there is relays I need to check inside or in the engine bay?
This is on My 85 4runner.
94Yota22re
  • Turtle Points: 1185
  • Male Posts: 18
  • Member since Jan '17
Re: Interior lights problem
« Reply #1 on: Nov 09, 2018, 08:40:29 AM »
There is the taillight relay. Located on the interior fuse panel, beside the flasher. It should be makes "TAIL"
Jarhead [OP]
« Reply #2 on: Nov 11, 2018, 07:12:37 AM »
Thanks, i will look at that.
Jarhead [OP]
« Reply #3 on: Nov 13, 2018, 03:15:52 PM »
That was  not the problem, I replaced it and still didn’t work. I think now it might be the actual switch in the steering column. I’m gonna have to look at that next.
« Last Edit: Nov 13, 2018, 07:27:45 PM by Jarhead »
Yotadekime
  • Turtle Points: 17
  • Member since Aug '18
  • Danger first
« Reply #4 on: Nov 14, 2018, 05:54:08 AM »
I would look up a wiring diagram, but definitely look at the switches. I like to check for continuity across lengths of wire in circuit.
Naturally a realist, preferably an optimist.
Jarhead [OP]
« Reply #5 on: Nov 14, 2018, 08:33:48 AM »
I will look at  continuity, thanks.
OVRAROK
  • Turtle Points: 26852
  • Male Posts: 3,506
  • Member since Dec '10
« Reply #6 on: Nov 14, 2018, 10:05:34 AM »
I had a similar problem on my 84 with taillights, ended up being corrosion in the taillight sockets
Last post Dec 15, 2004, 09:37:16 PM
by reklund5
Last post Feb 23, 2006, 05:04:00 PM
by 4xtoy
Last post Feb 12, 2008, 11:11:32 PM
by KDXSR5
Last post Sep 27, 2011, 07:05:13 PM
by Squeebs
Last post Aug 15, 2013, 09:24:49 PM
by Cheesemaker
