I have a pair of 1991-93 Fj 80 axles that have been outfitted with Nitro 5.29 gears and Aussie lunch box lockers. Front axle has Slee Offroad high steer arms and a RHD lower arm to capture the tierod in double shear for additional strength. Instead of having 4-5 bolts holding the steering arms together this has 7 per side! The axles have been cleaned of all OEM brackets.
*Front diff is a hi pinion 8", best for driveshaft clearance from the rocks and it has massive birdied axles compared to a mini truck front axle!
*Rear axle has a huge 9.5" ring gear, biggest ring gear toyota put in a vehicle aside from a Tundra 10.5". The rear axle also has full float outers and disc brakes!
Gears, bearings, lockers, knuckle service kit have NO miles on them. Brand new!
Will trade for built GM 1 ton axles only.
Located in Sultan WA, 98294. Price is $2200 firm.
I can email or text pics if you're interested, just let me know.
