Author Topic: 22r Timing Problems  (Read 1826 times)
Yotaoverland
  • Male Posts: 208
  • Member since Feb '15
22r Timing Problems
« on: Oct 08, 2018, 06:39:58 PM »
I have a remanufactured 22r in my 1980. I recently put the motor in, buttoned everything up and turned it on to set the timing, but there's been many issues.
I set the engine to 0* TDC on the compression stroke, I then insert the distributor with the rotor pointing up at 12* and slide it in. It seats and appears to be pointing at the number one plug on the cap. I tighten everything down, set up the timing light and start the truck and when I check the timing it is way off. It doesn't even idle at the 0* mark, it idles poorly far to the right if you are facing the truck. I can rotate the distributor a small amount, which helps, but it's not enough to even get the mark to 0*. I feel that I may be doing something wrong, but I don't know what it is. I've attached a link to a short video.
https://www.youtube.com/watch?v=6pjpCPkmEc4
1980 pickup LWB
22reperformance 22r
L-52 5spd
4.7 Tcase
Detroit Trutrac
Slabzilla
  • Turtle Points: 1355
  • Male Posts: 539
  • Member since Dec '13
Re: 22r Timing Problems
« Reply #1 on: Oct 08, 2018, 07:29:17 PM »
When you put the crank on 0* and the rotor at 12 o'clock, the dizzy adjustment slot should be centered not hard to either side, then slide it in and the rotor should move to the Vac. advance position, ie. #1. Hope this helps.
'85 Xtra-cab, 4.5" Downey Off-Road lift, 12-15 KM2's on American Racing Baja's, Marlin's-4.88's & 4.7's, Downey Off-Road CAI, Marlin rear bumper & sliders
Snowtoy
  • Online The 2.5K Group
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
« Reply #2 on: Oct 08, 2018, 09:32:17 PM »
The rotor should look like this when installed.
With it a reman engine, it might be worth it to pull the valve cover and check that the #1 valves are loose and #4 are tight when the engine is at TDC.
Yotaoverland [OP]
  • Male Posts: 208
« Reply #3 on: Oct 09, 2018, 02:36:54 PM »
Thanks for the replies. I am most likely off one tooth. It's embarrassing, but I guess it happens.
1980 pickup LWB
22reperformance 22r
L-52 5spd
4.7 Tcase
Detroit Trutrac
Timing
Last post Apr 19, 2004, 05:28:29 PM
by YotaYota
Last post Jul 30, 2004, 04:31:30 PM
by Skinny_Pedal
Last post Mar 11, 2007, 06:35:33 PM
by wrenchtech
Last post Nov 27, 2007, 09:26:28 PM
by highridin4x4
Last post Dec 09, 2007, 06:31:53 PM
by Wermz84
