Lots of questions so I'll just hit on a few that are obvious. The ac, you'll need a top plate for that compressor for a 2nd gen truck like an 87(that's what mine came from) to have the correct fittings to connect OEM ac lines. Just hit a junk yard and snag the whole under dash ac and heater box. The black wire at the water neck goes to that temp sensor. The bolts you see missing on the intake are normal. Nothing to worry about.
Yes lots of questions! Sorry, been trying to get it all figured out. Still trying to find random small items at the junkyard has seemed to take most of my time. Wondering if there is a source to buy new electrical plugs for this motor? A bunch of the plugs have been chopped off =/
https://www.rockauto.com/en/catalog/toyota,1998,4runner,2.7l+l4,1317453,electrical-connector
Going crazy trying to find this piece... No luck at any junkyard near me and i have been going for weeks. Anyone have one they can sell me?
On it's way, be there Monday
Thats the one! Thank you! 3rz's near my place is like gold around here. Sent from my Nexus 6P using Tapatalk
I may have that transfer case part. Need to dig into my stash.., I let you know in the next day or so...
https://www.tacomaworld.com/threads/sticky-oem-mini-header-and-heat-shield.367929/
I used the Tacoma downpipe
79 4wd, 83 2wd sas, 85 4wd, 87 2wd, 91 2wd sas, 94 4wd sas, and another 94 4wd ifs. All have Tacoma downpipe and factory mini header except 94 sas he opted for a pace setter header for a 96 Tacoma and we had to modify it because it hit the frame.
Awesome then built a custom crossover pipe? Do you know what the distance between o2's need to be or am I being overly cautious? Thanks, Any chance you have this? If not i think im going to pay someone to weld it for me. Thanks OVRAROK.
Started by Dr.Maxwe001 Toyota Pickup/4Runner Tech 1979-95
Started by Gadzooks Toyota Pickup/4Runner Tech 1979-95
Started by jrock « 1 2 » Engine
Started by IMMUDDY Project Research and Build-Ups
Started by 4runnerRob New Member Check-In!
