Author Topic: Bearing Race Height on Knuckle  (Read 567 times)
Engi-nerd
  • Turtle Points: 55
  • Member since Aug '15
« on: Sep 25, 2018, 07:12:47 PM »
Going through and rebuilding my axles, does the height of this bearing race look correct on the knuckle? It is sitting over-flush by 1-2 mm.
It is sitting over flush, and I didn't take a picture of the old race. Before I go digging through the trash for the old race to compare heights, I thought I would ask you fine folks first.
This is the rebuild kit from Marlin, and the bearings are Nachi.
Cheers!
« Last Edit: Sep 25, 2018, 07:19:43 PM by Engi-nerd »
Engi-nerd [OP]
  • Turtle Points: 55
mudmaster
  • Online The 2.5K Group
  • Turtle Points: 2187
  • Male Posts: 2,612
  • Member since Feb '05
Re: Bearing Race Height on Knuckle
« Reply #2 on: Sep 26, 2018, 05:21:25 AM »
Pic doesn't work for me, but from what I remember it sounds like it's fine.
Time to go wheelin!
helipilot77
  • Turtle Points: 954
  • Male Posts: 1,498
  • Member since Jul '12
  • Seattle, WA
    • My build thread
« Reply #3 on: Sep 26, 2018, 07:38:07 AM »
-1987 SR5 4runner, 1KZ-te turbo diesel with custom 3" S.S. dump pipe, R-151f transmission, marlin dual ultimate transfer cases w/ triple shifter, SAS, 35's
-1984 SR5 Tercel 4wd wagon bone stock - given to my nephew
-My build thread http://board.marlincrawler.com/index.php?topic=98969.0
-My front axle service write-up http://board.marlincrawler.com/index.php?topic=97311.0[/ur
- Sales Employee -
TRevv
  • Hawk
  • Turtle Points: 196
  • Male Posts: 194
  • Member since Apr '17
  • Crawlin at work, Crawlin on the trails. best life.
« Reply #4 on: Oct 23, 2018, 02:38:19 PM »
The bearings and races in the marlin crawler axle rebuild kits are a different taper than factory.  The factory bearings are much tapered, which means they support top load.  However as toyotas are not very heavy and do not supply a lot of top load, but our tires hitting rocks cause lots of side load, Marlin Crawler gets bearings and races that have a steeper taper to support more side load.  The end result is a slightly taller bearing as well, but not so tall that it would make a difference for operation or install. The knuckle should still slide right over them.
"I dunno I just woke up from a lil nap, it's a lil dark but you guys silly? I'm still gonna send it."
Last post Jun 05, 2006, 06:52:23 AM
by Duffil
Last post Mar 23, 2010, 03:53:56 PM
by irork
Last post Oct 23, 2010, 10:32:51 AM
by 79coyotefrg
Last post Jul 24, 2013, 01:36:45 PM
by RyenMiller408
Last post Mar 01, 2015, 05:42:57 PM
by BobJ
