Never seen an issue caused by the dash vss. Worked fine from our 85sr5 dash to t100 3rz ecu.
Nice work! Are you going to be able to close the hood?
When's the ref test? I would like to check this out.
I picked up a 95 t100 last weekend. I talked to the referee in Modesto and he said I need to take the donor truck to the dealership to have the ecu and some other things verified? Did you have to do that?
Interesting.... This guy said nothing about the ecu being 2wd or 4wd. I will have to go talk to him again. Don't want to get into the swap and then find out he won't allow it.
Do you guys really think the ref can visually ID a trans year by year? LolGet on your computer and print the 4wd comouter label if your guy is being a hard on.
They don't care exactly which transmission, just if it is a 2wd vs 4wd.Sent from my SM-G950U using Tapatalk
I will ask today. After work.
