Ready for an UPGRADE??
Front and rear built MINI axle set, TRD E-locker front and rear $2500 for the set, sold as a pair only. Morgan Hill, CA
Less than 3000 miles on the build and very minimum offloading (maybe like 5 miles of easy) Gears install and axle build was performed by a professional shop. If your looking for a mini axles set you cant get any better. E-lockers dont get air leaks and are selectable. if you plan to snow or ice drive its the setup to have.
Front Axle:
85 pickup Axle(85 is strongest of the mini), TRD E-locker, 4:88, Original Longfield axles (not Trail Gear, before they bought longfield), diff protector, gusset, IFS brake calipers and rotors (Larger upgrade rotors), new pads, High Steer, steering stabilizer. Multi Pattern drive flange, (needs new tie rod ends)
Rear Axle:
IFS Rear Axle (wider) TRD E-Locker, 4:88 Longfields axle (not Trail Gear), diff protector, Drum Brakes, Multi Pattern drive flange,
Still installed on truck can be tested.
$2500
will not ship
May consider trade for: 3rz-22re engine swap kit, wrecked tacoma, local fabrication/work or mechanic work.
