Author Topic: Not another 3rz swap question  (Read 2807 times)
sjelite
  • Male Posts: 93
  • Member since Aug '11
« on: Jul 30, 2018, 04:41:21 PM »
I have an 82 4x4 pickup; 22r (82-84 block), dual cases, w56 trans, 4:88s on 33’s and hopefully 36’s soon (36s for offroad only and driving to trail) im on the fence on if I should do the 22re swap or just go balls out and get a 3rz. I definetly want to upgrade to a fuel injected motor… the question is comparing a swap from a 22r to a 22re or 3rz. Im planning on buying the stand alone harness from ORS and purchasing the “bolt in” 3rz motormounts.  I know the 3rz is the way to go, but is it worth the extra  headace?
Big question here
Can you CA BAR CERT a JDM 3rz without knowing the specific donor vehicle?
22re swap pros:
Lots of rebuilt long blocks avaliable
Easier to pass CA BAR CERT
Lots of used options
3RZ pros:
JDM imports are cheaper than a rebuilt 22re
More HP
Cleaner setup
Updating to a newer engine
I know there is a 3rz thread  :stopit:
  • Turtle Points: 452
  • Male Posts: 3,554
  • I'LL NEVER MAKE IT...
Re: Not another 3rz swap question
« Reply #1 on: Jul 31, 2018, 04:04:30 AM »
Probably only slightly more trouble to do a 3RZ.  With the 22re you are still putting an efi setup in there with tons of wiring to make fit just like a 3RZ.  I would go for the 3RZ and get the most bang for your trouble.  I ran one and they are good.
Or just go old school and stay carb :).
gnob
  • Turtle Points: 486
« Reply #2 on: Jul 31, 2018, 05:45:24 AM »
I would recommend finding a clean donor so you can get all the stuff you need and also consider swapping the entire vehicle harness, which would ultimately help the BS CA BAR.
3RZ is the way to go, especially if you have any wrenching skills whatsoever.
hold this. . .
sjelite [OP]
  • Male Posts: 93
« Reply #3 on: Jul 31, 2018, 07:39:35 AM »
I guess my main question is the JDM engine and the referee process. One of my main issues is lack of room to drag a donor vehicle home to strip down. Im hoping to get by with a $1600 JDM and call it a day. That 3rz with the extra 40 ish+ HP will be awesome.
Pat
  • Turtle Points: 786
  • Male Posts: 944
  • Member since Jun '02
  • Oroville, Ca
« Reply #4 on: Jul 31, 2018, 10:42:17 AM »
the 3rz is only truly a little more work but has much bigger rewards then just going fuel injected 22r.  the ref has no idea where the motor came from vehicle or junk yard.   The big thing is just make sure everything matches for a certain vehicle if you want your life easy with the swap.  As said before is you can swing it find a complete rig rolled or crashed.  Store it at a friends or what ever.  I just picked up a complete low miles 2000 Tacoma to do my next one for $1300 and had everything plus extras to recoup the cost or buying truck.
Sharing time between Northern Ca and Western Tn..
sjelite [OP]
  • Male Posts: 93
« Reply #5 on: Jul 31, 2018, 01:26:04 PM »
Thanks for the reply’s gentlemen
So the Ref only wants to know the donor vehicle year, so he can follow the smog diagram/requirements etc. There’s no actual VIN database etc that they look up in the system?  Awesome!
Donor vehicle is a good way to go, plus you have a visual reference for for where all the connections are supposed to be.
Thank you!
Pat
  • Male Posts: 944
  • Oroville, Ca
« Reply #6 on: Jul 31, 2018, 01:32:24 PM »
The motor itself does not have a vin..  the vin would be more associated with the computer and cats.   Having a vin can make it more straight forward for the REF.  On my last Swap I had a binder with receipts, VINS, pictures, references etc..  I just handed it to the ref and he was able to put the story together of what I did and had real well.  My swap was perfect and they still screwed it up.  Had to come back 2 times and in the end the rig ened up being exactly as I took it in the first time  :)
toy_tek
  • Turtle Points: 25
  • Member since Feb '17
    • Instagram: toy_tek
« Reply #7 on: Jul 31, 2018, 04:02:04 PM »
I've been working on a 3RZ swap for way too long now... because I didn't get an entire donor vehicle.  I wouldn't advise this route.
IF you don't get a donor vehicle, be prepared to either 1:  wait a long time for certain parts to show up at a reasonable price (if at all), or 2: pay out the wazoo for stuff from dealer, etc.
NO comment on CA refs, I live in AZ.
83 Toyota Longbed
97 Toyota 4Runner
89 Toyota Landcruiser FJ62
IG:  toy_tek
Pat
  • Male Posts: 944
  • Oroville, Ca
« Reply #8 on: Jul 31, 2018, 04:14:02 PM »
So the Ref only wants to know the donor vehicle year, so he can follow the smog diagram/requirements etc. There’s no actual VIN database etc that they look up in the system? So i could choose a Tacoma or a T-100 and none would be the wiser as long as I used the appropriate diagrams and air box etc
Thank you
They can and will look up vins if available. The best way to look at it is.  Your rig needs to be a different vehicle.  What ever motor, computer, emissions etc all needs to match to make your life the easiest.  It is that simple.   So either buy a complete wrecked donor or pick all the parts to make your just like a certain year make model.
sjelite [OP]
  • Male Posts: 93
« Reply #9 on: Aug 01, 2018, 07:20:37 AM »
This is real good advice Pat, I greatly appreciate it. If your ever in Morgan Hill ill buy you a beer and or lunch.
sjelite [OP]
  • Male Posts: 93
« Reply #10 on: Aug 01, 2018, 07:21:39 AM »
Thanks Toy Tek buying parts from the stealership is no bueno
sjelite [OP]
  • Male Posts: 93
« Reply #11 on: Aug 01, 2018, 07:24:20 AM »
So is the Tacoma setup easier to swap into a 1st gen compared to the T-100? The T-100 has a bigger air box? I have a feeling a T-100 would be much easier to find in my area.
gnob
« Reply #12 on: Aug 01, 2018, 07:54:20 AM »
With all the wasted time in legislation in CA.  It might be worth finding a "friend" to help get you guys BAR bull crap fixed.
Having to deal with :pokinit: like a 4wd or not engine is just a ridiculous conversation.  Also pointless conversation when most of the parts are the same# just in different cars.  So i guess in cali i would fail for among other things, using a camry ignitor on my tacoma 3.4.
freakin' lol
hold this. . .
Pat
  • Male Posts: 944
  • Oroville, Ca
« Reply #13 on: Aug 01, 2018, 08:27:40 AM »
I'm not sure if the ECU needs to be 4x4, I just didn't want to give bad advice. It would be a good idea to check on that unless someone here knows.  I'm actually surprised they let us swap motors here at all and I feel it's only a matter of time that they don't allow it at all. I have about 8 more years before I can retire and get the hell out of here.
That's the problem too,  You get one story from one ref and another from the next ref.  It is almost as if they don't all play from the same rule book.  I have first hand experience with this being told one thing then another by the next guy.    And you are 1 year ahead of me on getting out of here :)
sjelite [OP]
  • Male Posts: 93
« Reply #14 on: Aug 01, 2018, 11:35:59 AM »
Where you guys heading, hard to imagine living outside "the golden state" I tried it for 2 years, didn't work out so good.
sjelite [OP]
  • Male Posts: 93
« Reply #15 on: Aug 01, 2018, 11:40:28 AM »
And the exhaust routing is another PTA, i sifted thru the 3RZ thread (all 50 pages)  but didn't find the specific requirements. Im almost tempted to relocate the gas tank to the Driver side. do you guys have any pictures of your exhaust routing? I guess it all depends on your BAR REF
Pat
  • Male Posts: 944
  • Oroville, Ca
« Reply #16 on: Aug 01, 2018, 11:45:31 AM »
Swilson has some great pics of his BAR certified exhaust in his thread. Go check it out.. :)
Last post Oct 18, 2004, 11:00:37 PM
by iNfErNaL
Last post Sep 09, 2007, 07:18:31 PM
by Duffil
Last post Apr 20, 2008, 10:14:06 PM
by Yoat Goat
Last post Apr 05, 2022, 11:50:46 AM
by liveoak
Last post Jun 01, 2023, 08:56:51 PM
by H8PVMNT
