"I still have to secure the lines/wiring for the drive to CA"Driving it to the race? no trailer and tow vehicle?
I would not trust that spoiler to hold up to KOH. It's mostly plastic, with only a few small bolts at each end.My opinion would be to mount the rear light to the roof structure inside the rear hatch. You won't have glass in there anyway, so it should work just as well. You may even end up with it mounted to the cage once that's done.
I would agree. that spoiler is gonna get a work out with that light on there. I would also install inside on the cage
Tha's what I was thinking, but once I put stronger bolts with washers/lock washers on the sides, it ended up really sturdy. It has internal clips that hold it from coming out and the bolts lock it to the clips. It'd take a ton of force to get it to come off...but KOH may still do it. Note the light bar is extremely light, so the entire setup is ~5lbs or so max.If it flies off in testing at JV, we'll pull it and mount on the cage. For now, it's surprisingly sturdy.
Also in the unlikely event you flop the spoiler may break as well.
Tell us about that Sexy 1st gen in the back ground?Hey there good looking.
Started by BigMike New Announcements and Info
Started by jakesooy Rigs For Sale
Started by hiltu Project Research and Build-Ups
Started by Scott hartman New Announcements and Info
Started by SORS Project Research and Build-Ups
