.... Is there a way to measure the bearing with a micrometer to determine what size it is?
If you are sure you are getting good spark and fuel, I'd look at cam timing and ignition timing. Cam timing (valve events) can affect compression. Can you verify cam timing and do a compression check?Webers are very finicky... proper fuel pressure is critical.Gnarls.
... i cant get this thing to fire. After 10 seconds of cranking it will attempt to start but wont.Things i have tried: ..... Changed out dizzy to another one. no change.
I didn't go back and read but is that a new cam in there? If its old those old rockers may have worn away at the cam lobes...
Started by sgt.majorcrash Parts For Sale
Started by iNfErNaL Chit Chat Camp
Started by 85toycrawler Rigs For Sale
Started by PadawanYota_Stovy RC Rock Crawler Tech
Started by UndefinedTaco Rigs For Sale
