... 22REC. I pulled the motor a few weeks ago to helicoil a broken intake bolt....
The idle screw DOES have an effect on the idle, but it is maxed out now, and still @ ~1,100RPM
What style of IAC valve does a 89 have? The older hot water/electric heater under the manifold or the more modern one that actually controls the idle?The older ones will give you a high idle when they fail (usually the electrical part).
... I am fairly certain it't the timing. ... Every time I was at a stop, and turned the wheel, the engine would struggle badly. It would put-put for ~10 seconds and then the RPMs would get high enough and it would start to go, and have no issues. Didn't matter if it was left or right, 1st or reverse.
- Adjusted distributor all the way. Timing is still at the beginning of the timing block.
Started by DeMented Toys Toyota Pickup/4Runner Tech 1979-95
Started by buckeye1437 Toyota Pickup/4Runner Tech 1979-95
Started by oddball Engine
Started by rmoore Toyota Pickup/4Runner Tech 1979-95
Started by konarider1993 Engine
