Toyota for now.What is My best choice for a rear 14 bolt again? Is it the C&C ? I want it to be as close to what I have now as possible.
So I got some more done today. This is a popular mod on a lot of forums. Na, welded some scrap on the king pins and beat them off. I like that the grease in the pin burns when you weld it.
Chris if you ever pick one up you'll change your mind. Sob is heavy as hell.
I’m glad that worked. Did you have to use your torque multiplier?
Should do a 9 inch instead
Also I'm like a time traveler. I can quote things that haven't happened yet.
I got the 14bolt breather drilled out and tapped 1/4 npt.
I don't know if it's going to be beefy enough.
Great looking build. Cant wait to see this beast done. Itll be a monster. What engine are you driving those huge axles with?
Started by nicholas99350 Project Research and Build-Ups
Started by TIMS89CRAWLER « 1 2 ... 24 25 » Project Research and Build-Ups
Started by ToYocRawleR « 1 2 ... 10 11 » Project Research and Build-Ups
Started by Toyospearo « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by Jason E. « 1 2 » Project Research and Build-Ups
